How can I implement a Pseudo Arclength Continuation method for my system?
  • Context: Graduate
  • Thread starter Thread starter nylonsmile
    Arclength
The discussion focuses on implementing a Pseudo Arclength Continuation (PCA) method for solving the system of equations F(x, λ) = 0. The user initially struggles with parameterization and the linearized normalization equation, N(x, λ, s). The key breakthrough involves recognizing the need for an explicit predictor step, where the normalization equation is modified to incorporate previous iteration values. The user also highlights the importance of using a tangent vector for predictions and suggests starting with natural parameter continuation for the initial step.
  • Understanding of Pseudo Arclength Continuation (PCA) methods
  • Familiarity with Newton-type methods for solving nonlinear equations
  • Knowledge of linearization techniques in numerical analysis
  • Basic concepts of parameter continuation in numerical methods
  • Study the detailed algorithm for Pseudo Arclength Continuation in the provided paper: IOPscience Paper
  • Learn about numerical methods for updating step lengths in continuation methods
  • Explore tangent vector calculations for predictor steps in numerical simulations
  • Investigate advanced techniques in nonlinear equation solving, focusing on predictor-corrector methods
Mathematicians, numerical analysts, and engineers involved in computational modeling and simulation, particularly those working with nonlinear systems and continuation methods.
nylonsmile
I'm struggling to implement a pseudo arclength continuation method for my system. Here is what I have so far.
I am trying solve the system of equations [tex]F(x, \lambda) = 0[/tex] but if I parameterise only by using lambda, I can't get around turning points, so I paramterise by "arclength" s and attempt to solve the system of equations:
[tex]F(x(s), \lambda (s)) = 0\\<br /> N(x, \lambda, s) = 0[/tex]
Where N is the linearised normalisation equation (' denotes differentiation with respect to s):
[tex]N(x, \lambda, s) \equiv x' \delta x + \lambda ' \delta \lambda - \delta s = 0[/tex]
Where ds is a specified step length. I solve these using a Newton-type method:
[tex] \begin{pmatrix}<br /> <br /> F_{\textbf{x}} & F_{\lambda} \\<br /> <br /> N_{\textbf{x}} & N_{\lambda}<br /> <br /> \end{pmatrix}<br /> <br /> \begin{pmatrix}<br /> <br /> \delta x \\<br /> <br /> \delta \lambda<br /> <br /> \end{pmatrix}<br /> <br /> = -\begin{pmatrix}<br /> <br /> F_0 \\<br /> <br /> N_0<br /> <br /> \end{pmatrix}[/tex]
Where the subscripts denote differentiation. So far so normal, this is the scheme as it is usually presented. I'm having difficulty figuring out exactly what to do though, particularly with the bottom half of the right hand side vector. What should go in there? The unlinearised normalisation? [tex]||x'||^2 + \lambda '^2 - 1[/tex] But if I use that, then where does the step length come into it? I think I'm getting confused by the linearisation - usually with this type of thing I'd only have [tex]\delta[/tex] for variables I'm trying to solve for, but here we also have it for s. It's a constant, and is confusing me no end.
Any help would be greatly appreciated, even just pointers to books/papers. Feeling pretty stupid atm!
Thanks for the post! Sorry you aren't generating responses at the moment. Do you have any further information, come to any new conclusions or is it possible to reword the post?
Ok I figured it out. The main problem I had is that I didn't realize that I needed an explicit predictor step. In natural continuation the "predictor" you would normally use is just the value from the previous iteration, but with the new lambda. For Pseudo-arclength continuation (PCA) you need an explicit predictor. Instead of
I should have written:
[tex]N(x, \lambda, s) \equiv x' (x_i - x_0) + \lambda ' ( \lambda _i - \lambda _0) - \delta s = 0[/tex]
Because those things are not the same as the ##\delta x## and ##\delta \lambda## on the LHS. The way it works is this.
  1. Make a prediction using euler-style predictor
  2. Use that prediction to get the ##x_i##, ##\lambda _i## for the right hand side
  3. Iterate using a Newton type method (you iterate on ##i## only).
You can use the tangent as the predictor:$$x_{i+1} = x_i + \delta s T$$ where ##T## is the tangent. To get the tangent I just do it numerically:$$T = \frac{(z_i - z_{i-1})}{\delta s} = \frac{(z_i - z_{i-1})}{||z_i - z_{i-1}||}$$ Of course the obvious question is how to start the whole thing? I just use natural parameter continuation for the first step.
This isn't everything I figured out, but it's about as much as I want to type. An in-depth algorithm can be found at http://iopscience.iop.org/1742-6596/385/1/012008/pdf/1742-6596_385_1_012008.pdf
I'm currently trying to figure out how to update ##\delta s## in a sensible way for when it fails...
