How can I properly name and open multiple files in Fortran based on user input?
  • Topic: Fortran
  • Thread starter Thread starter LucasCampos
    Fortran
7 replies · 6K views
LucasCampos
Hello there. I've doing a program that I do not know how many files will be needed, because it'll depend on user's choice. So, how to name them?
I tought that a command like, where n is a user-input number
Code:
Do While (i .LE. n)
Open (Unit=i, File=i'.dat')
i=i+1
EndDo
Would be enough, but I can't name my files this way. Any ideas?
I've been thinking about this program (many thanks to emes) and tought thet I could do something like this
Code:
Subroutine Opener (n,i)
Implicit None
Integer n,i
Character (LEN=15) :: files
Open (unit=500,File='Files1.dat')
Open (unit=501,File='Files2.dat')
i=1
Do While (i .LE. n)
	Write (500,*) i,'.dat'
	Write (501,*) 'mov',i,'.dat'
	i=i+1
End
i=1
Do While (i .LE. n)
	Read (500,*) files
	Open (Unit=i,File=files)
	Read (501,*)
	Open (Unit=i+n,File=files)
	i=i+1
EndDo
End
But would it read line after line of the files?
Hehe. I've turned this Open problem into a Read one.
I have a post somewhere on here as a way to do it. Basically, you can use the WRITE command to concatenate a string with a variable. You can then OPEN the file with the filename as the variable. It's something like this:
Code:
DO i=1,10
  WRITE(fname,'I2,A4') i,'.dat'
  OPEN(10,file=filename,form='formatted')
END DO
When I use
Code:
i=1
Do While (i .LE. n)
	i=i+1
End
I'll have a file like this
Code:
1.dat
2.dat
3.dat
n.dat
When I read it with
Code:
i=1
Do While (i .LE. n)
	Read (500,*) files(i)
	i=i+1
EndDo
Will I get a array with like 1.dat, on index 1, 2.dat, on index 2, ... n.dat, on index n, or I'll receive '1.dat 2.dat 3.dat ... n.dat' in every index?
I have solved many issues on this program already, but new ones keep rising.
On this 'subprogram', when it goes into the third loop it can't get out. But it does open all files it should open
Code:
Program Lennard2
Implicit None
Double Precision dt,e,sigma,x(20),y(20),vx(20),vy(20),tet(20),omeg(20),&
rad(20),mass(20)
Integer n,i,show
Character (LEN=15) :: files(20),files2(20)
Call Inserter (dt,e,sigma,x,y,vx,vy,tet,omeg,rad,mass,n,i,show)
Call Opener (n,i,files,files2)
End
Subroutine Opener (n,i,files,files2)
Implicit None
Integer n,i
i=01
10 format (i2,A4)
20 format (i2,A7)
Open (Unit=500,File="uia.dat",Action='Write')
Open (Unit=501,File="duia.dat",Action='Write')
Do While (i .LE. n)
	Write (500,10) i,'.dat'
	Write (501,20) i,'mov.dat'
	Write (*,*) 'First Loop'
	i=i+1
EndDo
Close (Unit=500)
Close (Unit=501)
i=1
Open (Unit=500,File="uia.dat",Action='Read')
Open (Unit=501,File="duia.dat",Action='Read')
Do While (i .LE. n)
	Read (501,*) files2(i)
	Write (*,*) 'Second Loop'
	i=i+1
EndDo
i=1
Do While (i .LE.n)
	Open (Unit=i,File=files(i))
	Open (Unit=i+n,File=files2(i))
	Write (*,*) 'Third Loop'
	i=i+1
EndDo
i=1
Do While (i .LE. n)
	Write (i,*) i
	Write (i+n,*) i+n
	i=i+1
	Write (*,*) 'Forth Loop'
EndDo
Write (*,*) 'Opener'
End
Subroutine Inserter (dt,e,sigma,x,y,vx,vy,tet,omeg,rad,mass,n,i,show)
Implicit None
rad(20),mass(20)
Integer n,i,show
Write (*,*) 'Insert time step'
Read (*,*) dt
Write (*,*) 'Insert sigma (distance at which the inter-particle &
potential is zero)'
Read (*,*) sigma
Write (*,*) 'Insert epislon (depth of the potential well)'
Read (*,*) e
Write (*,*) 'Insert steps between output'
Read (*,*) show
200 Write (*,*) 'Insert how many particles (2~20)'
Read (*,*) n
If (n .GT. 20) then
Write (*,*) 'Invalid Input'
Go to 200
End If
If (n .LT. 2) then
Go to 200
End If
i=1
Do While (i .LE. n)
Write (*,*) "Insert ",i," disk's mass"
Read (*,*) mass(i)
Write (*,*) "Insert ",i," disk's radius"
Read (*,*) rad(i)
Write (*,*) "Insert ",i," disk's initial vertical speed"
Read (*,*) vy(i)
Write (*,*) "Insert ",i," disk's initial horizontal speed"
Read (*,*) vx(i)
Write (*,*) "Insert ",i," disk's initial vertical position"
Read (*,*) y(i)
Write (*,*) "Insert ",i," disk's initial horizontal positon"
Read (*,*) x(i)
Write (*,*) "Insert ",i," disk's initial angular speed"
Read (*,*) omeg(i)
Write (*,*) "Insert ",i," disk's initial angular position"
Read (*,*) tet(i)
i=i+1
Write(*,*) 'Inserter'
EndDo
End
Strangely, when I use up to 4 particles, it works ok. But anything above that won't do the job.
You cannot open an array of files in one unit number. Each unit number must correspond to a single file that its operating on. Reading the files in as you described won't work...for several reasons. You can use the same unit number. Just close the file at the end of the do-loop and reopen it after you've changed the filename. After you write out the files, the read would look like:
Code:
DO i=1,n
  !-- writing routines
END DO
DO i=1,n
  WRITE(fname,'A3,I2,A4') 'mov',i,'.dat'
  OPEN(10,file=fname,form='formatted')
  !--Read the file here
  CLOSE(10)
END DO
Be careful using unit numbers above 99. I wasn't even sure that you could do that. I'm fairly sure that many compilers will have issues with it.
Looking through your code it appears you have some issues. Firstly, you have a DO loop where i < n, but n doesn't appear to be defined, nor does it change. Your arrays that hold the data are only dimensioned to 20, but your program is written so that a general number, n, can be called. If you want this, you should change your arrays to ALLOCATABLE.
I fail to see where I was trying to open twice using the same unit. Could you show me more detailed? On the subject of the array of 20, I've put a few Ifs on Inserter to deal with that, but I'll make some research on Allocatables Arrays, it seems quite interesting.
Code:
Read (*,*) n
If (n .GT. 20) then
Go to 200
End If
If (n .LT. 2) then
Go to 200
End If
I didn't say that you were opening two files with the same unit number, I said that in your example, you were trying to open an array of files, quote:
Code:
i=1
Do While (i .LE. n)
	[b]Open (Unit=i,File=files)[/b]
	i=i+1
EndDo
files here is defined as an array. This implicitly means that you're attempting to open up all files, (files(i),i=1,imax).
