How can I put multiple line equations inside a box in Latex?
  • Context: LaTeX
  • Thread starter Thread starter kdv
    Box Latex
kdv
I am not sure if this is the right place to post a Latex question. If not, tell me where I should go.
I would like to put equations inside a box. Now, I have found two ways to do this butthey work only for single line equations. The best method is to simply put the equations between boxed braces, i.e. \boxed{ equation}
this works if I am in an equation array i.e.
\begin{equation} \boxed{equation} \end{equation}
I have tried the same thing in an eqnarray but I get compilations errors. I would like to have equations spanning several lines which would be inside a box.
Anybody can help?
Thanks
Anybody can help?
Thanks
There are instructions in the https://www.physicsforums.com/showthread.php?t=8997" here at the forum. I haven't read the entire thing. There are over 700 posts.
Anybody can help?
Thanks
I found a way but I am not sure if it will work on the forums here, so here's the trick:
[tex] \begin{equation*}<br /> \addtolength{\fboxsep}{5pt}<br /> \boxed{<br /> \begin{gathered}<br /> \Pi_{i=1}^m \int d^4x_i \, e^{-i (k \cdot x)_i} ~\Pi_{j=1}^n \int d^4y_j \, e^{+ i (p \cdot y)_j} \\<br /> <0| T\{ \phi(x_1) \ldots \phi(x_m) \phi(y_1) \ldots \phi(y_n) \} |0><br /> \\ = \biggl( \Pi_{i=1}^m \frac{i \sqrt{Z}}{k_i^2 - m^2} \biggr) \biggl(\Pi_{j=1}^n \frac{i \sqrt{Z}}{p_j^2 - m^2} \biggr) ~<\vec{p}_1 \ldots \vec{p_n}|i T| \vec{k_1} \ldots \vec{k_m}><br /> \end{gathered}<br /> }<br /> \end{equation*}[/tex]
It worked!
(For anybody interested, left click on the equation to see the source code)
Thanks a lot for this tip kdv I'd been wondering how to get boxes around multiline equations.
Also, for alignment you can use the 'split' environment rather than 'gathered'.
[tex] \begin{equation*}<br /> \addtolength{\fboxsep}{10pt}<br /> \boxed{<br /> \begin{split}<br /> \int \frac{d^D P}{(2\pi)^D} \frac{{\cal P}_n(P)}<br /> {P^{2\alpha}(P-Q)^{2\beta}} =<br /> &\frac{1}{(4\pi)^2}(Q^2)^{D/2-\alpha-\beta}\sum_{\sigma \ge 0}^{[n/2]}<br /> G(\alpha,\beta,n,\sigma) \cdot \\<br /> &\cdot Q^{2\sigma} \left\{ \frac{1}{\sigma !}<br /> \left( \frac {\Box} {4} \right) ^\sigma {\cal P}_n(P)\right\}_{P=Q}<br /> \end{split}<br /> }<br /> \end{equation*}[/tex]
For anybody compiling this remember to include \usepackage{amsmath} in your preamble and for this particular example also \usepackage{amssymb} for the D'Alembertian.
Thanks again.
kdv, thanks for posting your answer after finding it. Google funneled me here, and your post has helped me out.
