How can I simplify this Convolution through a limit change?
11 replies · 3K views
ElijahRockers
Compute the convolution y[n] = x[n] * h[n]
if discrete signals:
[itex]x[n] = \alpha^nu[n][/itex]
[itex]h[n] = \beta^nu[n][/itex]
Where [itex]\alpha \neq \beta[/itex].
[itex]y[n] = \sum_{k=-\infty}^{\infty} h[n-k]x[k][/itex]
I plugged the two equations into the above convolution formula and got
[itex]y[n] = \sum_{k=-\infty}^{\infty} \beta^{h-k}u[n-k]\alpha^ku[k][/itex]
Simplifying, I get
[itex]y[n] = \beta^n \sum_{k=-\infty}^{\infty} (\frac{\alpha}{\beta})^ku[n-k]u[k][/itex]
And that's as far as I understand. The solution is supposed to be:
[itex]y[n] = \beta^n \sum_{k=0}^n(\frac{\alpha}{\beta})^k , n\geq0[/itex]
[itex]y[n] = (\frac{\beta^{n+1} - \alpha^{n+1}}{\beta - \alpha})u[n] , \alpha \neq \beta[/itex]
But I'm not sure how to get there. I see that the change in limits somehow facilitates this, but I just can't wrap my head around how to arrive at that, especially the part where α≠β.
I see that for each n, k goes through all possible values and sums each result, but I don't see why the lower limit for the solution is 0, or the upper limit is n.
There's obviously something fundamental about convolutions that I'm not getting.
Simplifying, I get
Are the equations [itex]x[n] = \alpha^nu[n], \; y[n] = \beta^nu[n][/itex] supposed to hold for all integer n from -∞ to +∞, or are they supposed to hold only for integer n ≥ 0? (The answer makes a BIG difference.)
Why? The u(n) says n > = 0 only, does it not?
Simplifying, I get
It seems to me that you're almost there. You just need to take into account the values of ##k## for which ##u[k]## and ##u[n-k]## are nonzero, and change the limits on the sum accordingly. Assuming the definition
$$u[k] = \begin{cases}
1 & \textrm{ if }k \geq 0 \\
0 & \textrm{ otherwise} \\
\end{cases}$$
then for what values of ##k## is ##u[n-k]## nonzero? And then what about the product ##u[k]u[n-k]##?
u[n-k] = 1 when k is ≤ n
u[k] is 1 when k ≥ 0
ok, so k only matters from 0≤k≤n, so i see where the limits are... and 1 times 1 is 1...
ok. its clicking.
but why is the restriction on n≥0?
Also, I used a formula for the sum when A/B ≠ 1 to get
[itex]\beta^n(\frac{1-(\frac{\alpha}{\beta})^{n+1}}{1-\frac{\alpha}{\beta}})[/itex]
But... is it just a matter of simplifying this to get the expression given as the solution?
ok. its clicking.
This is because if ##n < 0##, there are no values of ##k## which satisfy ##0 \leq k \leq n##, or putting it another way, ##u(k)u(n-k) = 0## for all ##k##. Therefore ##y[n] = 0## if ##n < 0##. This is why there is a ##u[n]## in the expression for the solution.
Yes. Try multiplying through by ##\beta^n##, and clearing denominators.
Ok, after grinding my gears for a bit, I get why n>0 for the first expression, duh, the sum upper limit can't be less than the lower limit,
but where does the u[n] come from in the second expression?
By the way, as you noted, your expression is invalid if ##\alpha = \beta##. But there is a valid solution if ##\alpha = \beta##. For completeness, you might consider finding a separate formula for that special case.
That's part B), already figured that one out,
y[n] = (n+1)αn...
but the solution has u[n] also, just like in part A)... not sure where either of those comes from.
y[n] = (n+1)αn...
See the remark I made above regarding why the expression only holds for ##n \geq 0##:
Ok, that makes some kind of sense... it's kind of hard to visualize what's actually happening but I see where you are coming from.
Thanks for your help!
