How Can I Solve Problem #7 from Chapter 1 of Ince's ODE Treatise?
  • Thread starter Thread starter psholtz
    Ode
The discussion revolves around Problem #7 from Chapter 1 of Ince's treatise on ordinary differential equations (ODEs). The problem involves a function z(x,y) and requires participants to demonstrate two specific equalities involving mixed and second derivatives.
  • Mixed, Assumption checking, Conceptual clarification
  • Participants explore the differentiation of the function z(x,y) and check the equality of mixed partial derivatives. There is a focus on the second part of the problem, where participants express difficulty in proving the equality involving the product of second derivatives.
Some participants have confirmed the equality of mixed derivatives, while others express skepticism about the validity of the second equality, suggesting it may only hold for specific functions. There is ongoing exploration of potential typos in the original problem statement, with some participants proposing alternative forms of the function to investigate the conditions under which the equality might hold.
Participants note that the original problem may contain a typo, specifically regarding the power of the second term in the function z(x,y). This has led to discussions about the implications of such errors on the validity of the problem's requirements.
psholtz
I'm working through the classic treatise on ODEs by Ince. I know that this is a somewhat dated text, but (imho) there are some real "gems" on the subject of ODEs here, well worthy of careful study.
I'm looking at Problem #7 at the end of Chapter 1. In it, we are given a function z(x,y):
<br /> z(x,y) = 3xy - y^2 + (y^2-2x)^{3/2}<br />
and we are asked to show two things. First, that:
<br /> \frac{\partial^2 z}{\partial x \partial y} = \frac{\partial^2 z}{\partial y \partial x}<br />
and second that:
<br /> \frac{\partial^2 z}{\partial x^2} \cdot \frac{\partial^2 z}{\partial y^2} = \left( \frac{\partial^2z}{\partial x \partial y} \right)^2<br />
The first one is a no-brainer. It's the second one that I'm having trouble with..
All are given above.
Differentiating the above expression, we have:
<br /> z_x = 3y + \left( \frac{3}{2} \right)\left(y^2-2x \right)^{1/2}(-2)<br />
<br /> z_x = 3y - 3\left(y^2- 2x\right)^{1/2}<br />
and differentiating again:
z_{xy} = 3 - 3\left(\frac{1}{2}\right) \left(y^2-2x\right) ^ {-1/2}(2y)
z_{xy} = 3 - \frac{3y}{\sqrt{y^2-2x}}
Now differentiating with respect to y first, we have:
z_y = 3x - 2y + \left(\frac{3}{2}\right) \left(y^2-2x\right)^{1/2}(2y)
z_y = 3x - 2y + 3y\sqrt{y^2-2x}
z_{yx} = 3 +3y\left(\frac{1}{2}\right)\left(y^2-2x\right)^{-1/2}(-2)
z_{yx} = 3 - \frac{3y}{\sqrt{y^2-2x}}
So yes, we have z_{yx} = z_{xy} as expected.
Now, moving on to the second part of this problem, we square this expression:
\left(\frac{\partial^2z}{\partial x \partial y}\right)^2 = 9 + \frac{9y^2}{y^2-2x} - \frac{18y}{\sqrt{y^2-2x}}
\left(\frac{\partial^2z}{\partial x \partial y}\right)^2 = \frac{18(y^2-x)}{y^2-2x} - \frac{18y}{\sqrt{y^2-2x}}
Now, going back to the expression for z_x:
z_x = 3y - 3\sqrt{y^2-2x}
and differentiating again with respect to x, we have:
z_{xx} = -3\left(\frac{1}{2}\right)\left(y^2-2x\right)^{-1/2}(-2)
z_{xx} = \frac{3}{\sqrt{y^2-2x}}
And going back to the expression for z_y:
and differentiating with respect to y:
z_{yy} = -2 + 3\left[\sqrt{y^2-2x} + y \left(\frac{1}{2}\right)\left(y^2-2x\right)^{-1/2}(2y)\right]
z_{yy} = - 2 + 3 \left[\sqrt{y^2-2x} + \frac{y^2}{\sqrt{y^2-2x}}\right]
z_{yy} = - 2 + 3 \left[\frac{2(y^2-x)}{\sqrt{y^2-2x}}\right]
z_{yy} = - 2 + \frac{6(y^2-x)}{\sqrt{y^2-2x}}
Multiplying these together, we get:
z_{xx} \cdot z_{yy} = \frac{18(y^2-x)}{y^2-2x}- \frac{6}{\sqrt{y^2-2x}}
Comparing this to what we derived above for \left(z_{xy}\right)^2, we see it's close, but not exact. The first term is correct, but the second term is off by a factor of 3y.
What am I doing wrong?
Or is there a typo in Ince?
I'm not sure that it is a valid equality in the first place. Imagine our function is a little bit more simple:
z(x,y)=3xy-y^2+x^2
Then
z_{xx}=2, z_{yy}=-2 \rightarrow z_{xx}\cdot z_{yy}=-4
compared to
z_{yx}=3\rightarrow z_{yx}^2=9
so these two are not equal. Unless, that is, this equality is specifically for this function only. In this latter case, I get the same results you do, that there is a missing 3y in the second term.
I think it's supposed to be for this function only..
As you showed, one can easily construct functions for which the equality does not hold.. for instance:
z = x^3 + y^3
z_{xx} = 6x
z_{yy} = 6y
and hence:
z_{xx} \cdot z_{yy} = 36xy
but
z_{xy} = 0
It is interesting, nonetheless, to ask the question: for what kinds of functions does the equality, z_{xx} \cdot z_{yy} = \left(z_{xy}\right)^2 hold? i.e., what conditions would the function have to meet, in order for the equality to hold?
The Ince text, while deep and powerful, has typos in it that can be frustrating. In Question #2 in Chapter 1, he asks you to prove that given a (different) y (I won't go through the whole problem statement here), that:
(y-x)y&#039;&#039; = 2y(1+y&#039;)
In fact, this is impossible (given the problem statement), and the correct answer is:
(y-x)y&#039;&#039; = 2y&#039;(1+y&#039;)
It took me about a week of staring at that problem to figure out that it was a typo.
I'm stating this only in case other people are reading this text as well.
I started thinking that it might be for this function only after I typed my response. I would think, then, that there must be a typo in the problem. What the error is, I can't be sure; perhaps the power should be something else?
I tried using a power of 5/2, and it doesn't seem to get anywhere useful.
In terms of the kinds of functions that do satisfy the general relation, z_{xx} \cdot z_{yy} = \left(z_{xy}\right)^2, there are the following observations:
z = x + y
z_{xx} = z_{yy} = z_{xy} = 0
But that's a sort of "trivial" case.
I also thought you might be able to use something like:
z = kx^4y^4
z_{xx} = 12kx^2y^4
z_{yy} = 12kx^4y^2
and hence that:
z_{xx} \cdot z_{yy} = 144k^2x^6y^6
and likewise that:
z_{xy} = 16kx^3y^3
so that:
\left(z_{xy}\right)^2 = 256k^2x^6y^6
so the degrees of the polynomials come out correctly, but the trouble is that you can't get the coefficients to come out right.
The typo is in one digit. Rather than using:
z = 3xy - y^2 + \left(y^2-2x\right)^{3/2}
we must use:
z = 3xy - y^3 + \left(y^2-2x\right)^{3/2}
In other words, the second term is raised to the third power, not the second power.
Using this, we have:
z_x = 3y + \left(\frac{3}{2}\right)\left(y^2-2x\right)^{1/2}(-2)
z_x = 3y - 3\left(y^2-2x\right)^{1/2}
and taking the second derivatives:
z_{xx} = \frac{3}{\sqrt{y^2-x}}
and
z_{xy} = 3 - 3 \left(\frac{1}{2}\right)\left(y^2-2x\right)^{-1/2}(2y)
Taking the y-derivatives:
z_y = 3x - 3y^2 + \left(\frac{3}{2}\right)\left(y^2-2x\right)^{1/2}(2y)
z_y = 3x - 3y^2 + 3y\left(y^2-2x\right)^{1/2}
and its second derivatives:
z_{yx} = 3 + 3y\left(\frac{1}{2}\right)\left(y^2-2x\right)^{-1/2}(-2)
and
z_{yy} = -6y + 3 \left[\sqrt{y^2-2x} + y \left(\frac{1}{2}\right)\left(y^2-2x\right)^{-1/2}(2y)\right]
z_{yy} = -6y + 3 \left[\sqrt{y^2-2x} + \frac{y^2}{\sqrt{y^2-2x}}\right]
z_{yy} = -6y +3\left[\frac{2(y^2-x)}{\sqrt{y^2-2x}}\right]
z_{yy} = -6y + \frac{6(y^2-x)}{\sqrt{y^2-2x}}
So clearly we have z_{xy} = z_{yx}, as expected, and we also have:
\left(z_{xy}\right)^2 = 9 + \frac{9y^2}{y^2-2x} - \frac{18y}{\sqrt{y^2-2x}}
\left(z_{xy}\right)^2 = \frac{18(y^2-x)}{y^2-2x} - \frac{18y}{\sqrt{y^2-2x}}
and we also have:
z_{xx} \cdot z_{yy} = \frac{3}{\sqrt{y^2-2x}} \cdot \left(-6y + \frac{6(y^2-x)}{\sqrt{y^2-2x}}\right)
z_{xx} \cdot z_{yy} = \frac{18(y^2-x)}{y^2-2x} - \frac{18y}{\sqrt{y^2-2x}}
and so z_{xx} \cdot z_{yy} = \left(z_{xy}\right)^2 as desired.
Ince can be a very frustrating text. It's filled w/ great information, but this is the second (serious) typo in just the first problem set...
we must use:
Woohoo, I was right! It just wasn't the power I was thinking of (you already pointed out the 3/2 power should be as is due to the 5/2 not working). I'm glad you were able to figure the solution out. I imagine that there's plenty more typos in that text, and am very surprised that the text made it through 4 editions with zero (it seems) corrections to such egregious errors. I did a quick google search for errata, but found none.
  • · Replies 18 ·
  • · Replies 25 ·
