How Can I Solve These Physics Problems on Forces and Tensions?
  • Thread starter Thread starter premed
The discussion focuses on solving physics problems related to forces and tensions. The first problem involves a woman pushing two crates, where the force exerted on the smaller crate results in a 30 N force on the larger crate due to the combined mass and acceleration. The second problem involves calculating the tensions in three cables supporting weights, with confusion about whether to sum the weights or use trigonometric functions for the angles. Participants clarify that the total force exerted by the woman is divided between the crates, and the correct approach to analyze the forces is essential for understanding. The thread emphasizes the importance of correctly applying Newton's laws and resolving forces in physics problems.
premed
Help please. Need help with these problems.
Hey. I'm really not good at physics and my professor only tells stories all day so I need help with these problems. Please be as descriptive as you can so I could understand the solution.
1) A woman pushes two crates across a frictionless horizontal floor. The crates mass 4kg and 20kg respectively. If the woman exerts a force of 36 N on the smaller crate, then approximately what force does the smaller crate exert on the larger crate. (The crates are next to and touching each other. I tried to draw a free body diagram but I'm confused because the answer is 30 N and i thought it was 36N)
2) There is a picture for this question that I need so I'll just describe it. Two cables, B and C, are at 60 degrees from the ceiling and are holding a 72 N weight attached to another cable A directed straight down that is holding a 150 N weight. I have to find the tension in cables A, B, anc C. I added a diagram that I made from paint but i don't know if it worked. Thanks a lot.
hey could someone please reply. I'm not getting anywhere with these problems
From what I know, please correct me if I am wrong.
F=ma where m = 4kg +20kg and F=36N
we solve for a which is 1.5m/s/s
now see what is the force on each block individually.
F=ma where m1 is 4 and a is 1.5 = 6N
F=ma where m2 is 20 and a is 1.5 = 30N
So the woman exerts a force of 36N in total which gets divided...so 6N on the first block by the woman and 30N exerted on the second block by the first block.
please correct me if i am wrong.
ya that sounds right. I never thought to add the masses. I kept trying to solve for different parts in f=ma seperately for each block. Thanks a lot. Now I am trying to solve the second problem. I trying to figure out if the Y component of the tension is the sum of the two hanging weights or if it is the sum multiplied by cos 60.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
