How can I speed up RUSTING STEEL?
The discussion revolves around methods to accelerate the rusting process of a 1/4" steel sheet within a timeframe of 2-3 weeks. Participants explore various techniques and substances that may enhance oxidation, including environmental conditions and chemical agents.
  • Exploratory, Technical explanation, Debate/contested
  • One participant suggests adding high heat and moisture as a simple method to speed up oxidation.
  • Another proposes using a salt solution to facilitate rusting.
  • A different participant combines high heat, salt, and coca cola for moisture, mentioning the potential use of acids to further accelerate the process, though questioning if that would still count as rusting.
  • There is a suggestion to use electrolysis to induce rusting by reversing the polarity of electrodes.
  • One participant expresses curiosity about the original intent behind the rusting process.
  • Another remarks on the challenge of making the observation of rusting interesting.
  • A participant reflects on their experience, noting that deep rust may not develop quickly and suggests that strong acids like hydrochloric or sulfuric acid could corrode the metal rapidly.
Participants present multiple competing views on effective methods to accelerate rusting, and the discussion remains unresolved regarding the best approach and the effectiveness of various techniques.
Some methods proposed may depend on specific conditions, such as the concentration of solutions or the environment in which the steel is placed. There are also unresolved questions about the definitions of rusting versus corrosion when using strong acids.
samadams
I want to make a sheet of 1/4" steel rust through completely in a short amount
of time (2-3 weeks).
What is the best way to accomplish this, if possible?
Chemistry news on Phys.org
add high heat and moisture. Simplest way to speed up oxidization.
Sprinkle it with salt solution.
high heat, salt, and coca cola for the moisture (there's probably some commercially available acid that will speed it up even more, although that might not count as rusting)
So a torch it, wet it with water, and/or salt and an acid, and repeat?
That will continue to oxidize and eat thru that much steel?
I wonder what your plan is...
whatever it is, if he can make watching metal rust interesting, he has succeeded
samadams, you might find this useful. http://en.wikipedia.org/wiki/Rust"
I'm beginning to believe that deep rust can't happen overnight,
as I'm only seeing surface rust with the different things I've tried.
But a strong acid, like hydrochloric or sulfuric would eat thru the metal
rather quickly?
  • · Replies 16 ·
  • · Replies 28 ·
35K
13K
11K
