How can one know the initial state from measurements?
The discussion revolves around the challenge of determining the initial state of a quantum system from measurements, particularly focusing on the implications of measurement theory and state preparation. It explores theoretical aspects, measurement techniques, and the conditions under which the initial state can be inferred.
  • One participant questions how to determine the initial state ψ0 of a quantum system, noting that repeated measurements can only provide the probabilities |ak|², leaving the relative phases unknown.
  • Another participant suggests that the initial state can be created through preparation based on knowledge of experimental arrangements that yield specific states.
  • A different participant introduces the concept of quantum tomography and references the Pauli problem, indicating that measurements of position and momentum do not suffice to determine the wave function.
  • It is mentioned that for finite-dimensional systems, the current best result indicates that five orthogonal basis measurements are sufficient to determine the state, assuming it is pure.
  • Another participant clarifies that determining the state of an unknown source, which may be in a mixed state, requires at least N²-1 binary test statistics.
  • One participant emphasizes that their previous statements were specifically about pure states.
Participants express differing views on the methods and requirements for determining the initial state of a quantum system, with no consensus reached on a singular approach or solution. The discussion remains unresolved regarding the best methods for various types of states.
The discussion highlights limitations related to the assumptions of state purity and the types of measurements required, as well as the complexity of determining states in infinite-dimensional systems.
pellman
Theoretical problems often begin with "given a system in state ψ0" For example, the 2-slit experiment begins with the assumption of a plane wave incident on the slits. I had always understood to this mean some prior set of measurements had been made to determine the initial state. But how can this be done in principle?
For simplicity, suppose our system is such that a single observable O is sufficient for a complete description, and the eigenvalues of O have discrete spectrum. Let ϕk be the orthonormalized eigenstate corresponding to the kth eigenvalue of O. Then any initial state of the system has the form
ψ0 = ∑ ak ϕk
To know the initial state ψ0 is to know all the ak . But repeated measurements of O can only give us |ak|2. So how can we ever know the relative phases?
I expect there must be some way of making measurements so as to take advantage of "interference effects" to get the phases. Can someone else explain further?
In the case of spin 1/2, I derived a way of getting the relative phases of the up and down coefficients by making measurements of the spin along the other two axes, and using the resulting amplitudes to calculate the relative phase along the desired axis. This works. But what about the general case?
One creates the initial state by preparation, using the knowledge about which kind of experimental arrangement produces which state.
What you did was akin to linear inversion, one of the methods for doing quantum tomography which is what you need in general.
The problem of determining pure states ("wave functions" as opposed to mixtures) came to be known as the Pauli problem. Pauli originally asked whether the measurements of position and momentum suffice to determine the wave function, and the answer is no. Weigert 1992 discusses the problem, for example. For finite-dimensional systems and general measurements, the problem of minimal measurements was solved by Flammia et al. (up to a set of measure zero, later addressed by Finkelstein). If you restrict yourselves to orthogonal basis measurements, I believe the current best result is that five bases are enough in an arbitrary finite dimension.
For an infinite-dimensional system, doing homodyne measurements for all phase space angles (essentially the observables ##x\cos \theta + p\sin \theta##) is one way to determine the wave function.
... but only if you know (or assume) that the system is in a pure state. To get the state of an unknown source (which is in general a mixed state) you need at least ##N^2-1## binary test statistics, and this many suffice.
Yes, the last two paragraphs of my reply were all about pure states.
  • · Replies 24 ·
  • · Replies 0 ·
  • · Replies 16 ·
