How can space expand?
  • Level: Graduate
  • Thread starter Starship
    Expanding Space
42 replies · 29K views · last reply
Starship
This brought me to the question: How can space expand? Does it mean that i can push off the vacuum? Is space some kind of aether of energetic particles? Do we really know what gravity is (i mean except the curvature of spacetime by mass-energy)? If space has a finite shape but is unbound then what lies outside it?
Welcome to Physics Forums, Starship!
Perhaps the easiest way to answer your excellent (primary) question is to ask you another one - what is 'space'? It looks simple, doesn't it?
Let's take a closer look at what might be behind the question.
First, why do we say 'the universe is expanding'? Because there are lots of good observations showing that objects such as galaxies and quasars are moving away from us, and a quick bit of simple math shows that they are all very likely moving away from each other.
Next, in terms of how we understand physical reality - in the large, not at the microscopic, quantum level - what does 'moving away' mean? No matter how you gnaw on this, you quickly end up acknowledging General Relativity - whether you run with it, or rebel against it, the ideas you work with (in your head, or in equations) have GR in their bones. So, 'how can space expand?' becomes 'within GR, what does the concept of the expansion of space mean?' or 'apart from GR, what theoretical framework is there within which the expansion of space can be understood?'
As to whether 'we really know what gravity is', you quickly get into philosophy, or you get something like 'gravity is whatever GR says it is, because GR is a highly successful theory' or "'gravity' is a theoretical concept; it means whatever the theory you are looking at says is means; for example, in LQG, 'gravity' is [insert], in String Theory, 'gravity' is [insert]".
For the 'if space has a finite shapre but is unbound' question, please take the time to read some of the many threads here in PF on this topic.
Like you and me and I think many others are bothered by expansion of space. There are many questions related to space some of them are as follows:
a). What is means by space ?
b). In case the universe is finite what lies beyond it ?
c). Apart form the fact that matter or energy needs space for their existence is there any other meaning of space ?
I think there is no independent existence of space. It exists only with matter/energy, I mean whenever there is matter/energy there is space. I think there is no effect of non local space on any matter/energy.
im guessing he means space as the stars and their moons (planets), and their moons
all space is expanding
scientist thought at first it will expand, slow down due to gravity pull form all matter, and then stop, then it would again begin to move, but it would move backwords until all matter colided.
what would happen next? It does not matter, because galaxies are actually acellerating apart. After so long we will hit the speed of light. I heard that matter, when it goes the speed of light, converts to pure energy. So their is a place, X number of miles away from where all matter began to move, where a event-horizon lies. It might not be a perfect sphere for some 'areas' of the universe have more matter, so the pull of gravity will afect the accelleration.
Now i have a question pertaining to this. Does a event horizon have a with?
"Is space really expanding? " It depends how you measure distances. Edit: That is: "What standard do you define to be the measure of distance?"
The evidence for space expansion is the Hubble red shift.
Also the next question is: "What has it expanded from?" The expanding solution to Einstein's GR cosmological case teaches us that it has expanded from a singularity, or near singularity, called the Big Bang. Nucleo-synthesis in the BB then predicts that the universe should be 3/4 hydrogen and 1/4 helium with very little of anything else. This ties in with the observed cosmic makeup once the elements created in the nuclear furnaces of stellar cores have been taken into account. Also the Cosmic Microwave Background is good evidence of the radiation given off by that BB, now red shifted into the microwave region of the electromagnetic spectrum.
We can say that if our rulers, made of atomic material, are defined to be of fixed size, and this means defining the rest mass of their atoms to be constant, then the Hubble red shift is Doppler in nature and the galaxies are rushing away from us; the universe itself is expanding everywhere because the space in which all stars, galaxies etc. are embedded is itself expanding.
However if we instead choose a different ruler, then the universe may indeed be static in size and it is atoms that are shrinking within it. An expanding universe with fixed rulers is replaced, or interpreted equivalently, as a static universe with shrinking rulers.
A ruler, or rather the atoms it is made of, may shrink over time because they are gaining mass over cosmological time. Edit: (Because other things being equal, the radius of an atom is inversely proportional to its mass) Hubble red shift is then understood to be an effect caused by the increasing mass of the apparatus used to measure it rather than a Doppler effect.
A second effect of atomic rest masses increasing is that atomic clocks would speed up. Edit: (The frequency of an 'atomic' vibration is proportional to its mass) This would have the effect of projecting the BB back, as measured by this new time, into the infinite past.
These ideas were first mooted by Fred Hoyle in his 'Mass field theory', a conformal gravity theory, in which he tried to explain the microwave background in a steady state model. ( Hoyle, F. "On the origin of the microwave background" Ap. J. 196:661-670, 1975 March 15). They also appear again in Self Creation Cosmology
Garth
Well, that wasn't "the first" scientific cosmology, but yes, that "closed universe" model is losing ground vs. an eternally expanding universe (although the closed model is not out of the running yet!)
You're thinking of matter moving through space. The separation of galaxies due to the expansion of space itself is different. The galaxies are still moving through space at sub-light speeds, but their relative velocities compared to us will keep increasing until they're out of sight.
Um, i was talking about galaxies and all matter in them. are not they increasing in speed as they move from us.
Or maybe i just misread something.
expansion
We would not be knowing about the expansion of the universe if everything were expanding, however, we know that bound objects do not expand so we can feel the expansion of the universe. My question is that since gravity is scale free then how this scale comes, below
which objects do not expand.
I'm not sure what you mean by gravity being scale-free. In the Newtonian limit it goes as 1/r2, meaning it's stronger at smaller distances. As for the scale on which gravity is dominant over expansion, that depends on the age of the universe. In the CDM paradigm, as the universe gets older, more matter falls into gravitationally bound structures, making them larger, both in comoving units and physical units.
However, this depends on the parameters of the universe as well. If it continues to accelerate under the influence of a cosmological constant, then structure basically freezes into place and no further growth occurs, setting a sort of special scale for structure in the universe. I don't know what the currently predicted number is for this, but I suspect it's in the ballpark of 100 Mpc.
Plese look somewhere else this is an important propery
of grvaitational intercation unlike to other fundmental
intercations gravity shows this property.
I can't tell if you're a crackpot or just very poor at expressing yourself. Would you mind pointing me to some references that can show me what you mean?
I think i am wrong here. It is not "space" (by space i meant vacuum and not distance) which is expanding, it's space-time which is expanding. Since we can't visualize a four dimensional universe, Riemannian geometry and tensors are the only way to demonstrate it.
Space in theoretical physics has various definitions:
1. The structure defined by the set of "spatial relationships" between objects.
2. A manifold defined by a coordinate system where an object can be located.
3. The entity that stops all objects in the universe from touching one another.
4. The condition within the conceptual field of Existence that provides the 'ground' for any manifested form and as such it enables the movement and all physical dynamics.
We don't know what space-time is. Space-time has been treated as a question of geometry, in this case it's a Minkowski space.
No actually, space as a hypersurface within space-time is said to be expanding, space-time may suffer curvature, or not, depending on the average density of the universe, but it cannot itself expand as that is movement which requires the passage of time, and time is part of the space-time that you have said is expanding!
It depends on the perspective from which you look at it. We experience a (3+1)D universe which is expanding; a fully relativistic perspective is to 'see' 4D space-time, which has to be a static view.
Garth
Garth
Maybe something like http://people.hofstra.edu/faculty/Stefan_Waner/diff_geom/pics/LightCone.gif .
No one replied to this:
No, what we percieve as a recession velocity isn't a real speed. Its a manifestation of the expansion of space between the galaxies. Locally, galaxies are very nearly at rest.
More accurately, the metric space is the one which is expanding. Or when viewed as a Riemannian metric the distance in the metric is the one which is growing.
russ_watters said:
No one replied to this: No, what we percieve as a recession velocity isn't a real speed. Its a manifestation of the expansion of space between the galaxies. Locally, galaxies are very nearly at rest.
Just to help clarify this...
We're talking about two kinds of motion here. One, galaxies move through space based on gravitational interactions. Two, galaxies move apart from each other (except in local groups) due to the expansion of space.
lawtonfogle - When you were talking about the relativistic effects of moving at the speed of light, that applies to an object moving through space, not to the expansion of space itself. As an example, note that during the first instants of the universe, it appears that space expanded faster than the speed of light...this does not violate relativity, which applies to things moving through space.
What about the Unruh affect? Isn't this where accelerating frames feel a temerature? Then what about space very far away from us, aren't we accelerating with respect to that that frame? Shouldn't we see a temperature difference somewhere due to acceleration? Thanks.
SpaceTiger said:
cosmoboy said:
We would not be knowing about the expansion of the universe if everything were expanding, however, we know that bound objects do not expand so we can feel the expansion of the universe. My question is that since gravity is scale free then how this scale comes, below which objects do not expand.
As far as I know, general relativity is scale invariant (conformally invariant, guv -> k guv) if no matter is included in the theory. If matter is considered and one wants to preserve conformal symmetry then there are some conditions to be imposed on the energy-momentum tensor, or one has to leave the framework of general relativity. Correct?
You can still detect a kind of doppler shift (that's where the idea of expanding space first came from), but that still doesn't mean its the same type of motion.
This is a pretty good explanation Nereid. I have a few questions though after reading everyone's posts. What are LQG and I've heard of string theory, but I don't know anything about it. Also didn't Einstein develop tensor analysis to help explain the way the universe is expanding (or contracting however you desire to view it) and the behavior for some of the cosmological phenomenon? Or am I completely off base and way out in left field?
The evidence for space expansion is the Hubble red shift. ..Garth
If one had another way to explain that, and CMB, what else is there??..
russ_watters said:
Welcome to PF. This is a very common topic, most recently discussed here: https://www.physicsforums.com/showthread.php?t=152773&highlight=space+expanding
I took a look at the thread, and found this.
"Additionally to redshift, there are other proofs for the expansion of space, as for example the cosmological time dilation of the supernova luminosity curves, the Tolman surface brightness test, the number density of galaxies and their evolution with distance, the variation of the temperature of the cosmic microwave background, the cosmic microwave background itself, the light elements abundances, etc. All of these are based on the validity of general relativity..."
Digging a little deeper, I see this.
"(1) Studies of relatively nearby Type Ia supernovae (SNe Ia) have shown that their intrinsic luminosities can be accurately determined; (2) New research techniques have made it possible to schedule the discovery and follow-up observations of distant supernovae, producing well over 50 very distant (z = 0.3 -- 0.7) SNe Ia to date. These distant supernovae provide a record of changes in the expansion rate over the past several billion years. By making precise measurements of supernovae at still greater distances, and thus extending this expansion history back far enough in time, we can distinguish the slowing caused by the gravitational attraction of the universe's mass density Omega_M from the effect of a possibly inflationary pressure caused by a cosmological constant Lambda"
http://xxx.lanl.gov/abs/astro-ph/9712212
It doesn't mention how the changes between the perceived 'several billion years' away, and the closer SN are determined.
Also, again, the Tolman surface brightness test is wholly dependent on the classical conception of what redshift is, and was caused by.
My original question was what ELSE do we have.
"In a simple (static and flat) universe, the light received from an object drops inversely with the square of its distance, but the apparent area of the object also drops inversely with the square of the distance, so the surface brightness would be independent of the distance. In an expanding universe, however, there are two effects that reduce the power detected coming from distant objects. First, the rate at which photons are received is reduced because each photon has to travel a little farther than the one before. Second, the energy of each photon observed is reduced by the redshift. At the same time, distant objects appear larger than they really are because the photons observed were emitted at a time when the object was closer. Adding these effects together, the surface brightness in a simple expanding universe (flat geometry and uniform expansion over the range of redshifts observed) should decrease with the fourth power of (1+z).
To date, the best investigation of the relationship between surface brightness and redshift was carried out using the 400-inch Keck telescope to measure nearly a thousand galaxies' redshifts and the 94-inch HST to measure those galaxies' surface brightness.[1] The exponent found is not 4 as expected in the simplest expanding model, but 2.6 or 3.4, depending on the frequency band"
http://en.wikipedia.org/wiki/Tolman_surface_brightness_test
I guess, then, aside form redshift based ideas, and the CMB, there is nothing else that says the universe is expanding. (?)
Fred Hoyle and others have suggested it could be due to atomic particles having less mass in the past, thus they would emit photons at lower energies and these would be observed as red shifted. See On the origin of the microwave background F. Hoyle, ApJ. 196, 661-670, 1975.
A recent theory that explains red shift in its Jordan conformal frame in the same way is http://en.wikipedia.org/wiki/Self-creation_cosmology (That Wikipedia article has not (yet) been trashed!)And yes the standard model does assume SN Ia are standard candles over cosmological distances, an assumption, which by it nature, cannot be tested unless there is another degeneracy free method of measuring their distances.
The surface brightness of distant objects is proportional to (1 + z)2. Only the first two effects you mention are significant, the third does not make sense, distant objects are at the distance they are! ("when the object was closer"?)
I hope this helps.
Garth
Interesting, but I have some very different ideas.
"In SCC there are two frames of interpretation of observational data, which depend on whether energy or energy-momentum is to be conserved and whether photons or atoms respectively are chosen as the invariant standards of measurement. In the former frame the universe is stationary and eternal with exponentially shrinking rulers and accelerating atomic clocks, while in the latter, and more familiar, frame the universe is 'freely coasting', and expands linearly from a Big Bang with rigid rulers and regular atomic clocks." (your link)
So it depends on the starting assumptions. My concern is beyond assumption, and in regards to what we actually, really do know.
Bingo. And does redshift have something to do with determining those distances?
If so, again, my concern is only things other than redshift, and CMB. I have other explanations for that.
So, where the z equals the redshift. Again, all depends on the explanation for the redshift.
I hope this helps.
Garth
Well, still, cool , but at least an attempt at getting warm. Thanks.
It does not depend on assumptions but the definition of the method of measurement.
What we actually do know is what we can observe and measure.
So, how do we measure mass, length and time at the far reaches of the universe to say whether we "actually really do know" that the universe is expanding or not?
Measurements are a comparison of the properties of those far objects with some set of laboratory defined standard units of M, L, & T that does not change across the intervening millions of light years of space and millions of years of time. In other words we need a conservation principle, something that is conserved and does not change over cosmological distances.
The standard GR model conservation principle is that of energy-momentum, or in other words, 'rest' mass. The mass of an atom, and therefore its size and atomic frequencies, is defined to be constant and atomic rulers and clocks are thus defined to be standard 'rigid rulers' and 'regular clocks'. In this frame the universe expands around a fixed ruler.
However in a mass field theory, such as Hoyle's, the ruler itself changes size, and clocks 'speed up', relative to the laboratory standard. In SCC in the Jordan conformal frame where the conservation principle is that of energy, an eternal universe is static with exponentially shrinking rulers and 'speeding up' clocks. The ruler shrinks in a static universe.
"Is space really expanding?" - It depends on how you measure it.
So, is it possible to actually measure such a change in the standards of measurement? In SCC this is possible by comparing the atom against a representative photon, such as one sampled from the CMB.
Such a photon when measured by such an atom will appear to exhibit red shift, not because the photon has lost energy but because the atom has gained mass.
I have included this in answer to the title question of this thread, however, further discussion on the theory I restrict to the Self Creation Cosmology thread.
Garth
You can observe the redshift, but the assumptions are in what it really means. The other things, as I pointed out, depend on those assumptions, whatever the measurements!
Good question. Since it is claimed it is expanding I assume there would be an answer?
The millions of years of time come in the assuming a constant past, and future, when science also claims that the present is the key to the future, and the past. The calculations rest on that premise, I think. In other words, IF things were the same, THEN this means that, and it woulda, could have should have taken so long for this or that to happen, etc.
This is why I was wondering what else, besides redhift, and the CMB, and things based on them, science had to support claims such as the universe expanding.
Right, and I assume it does. But to also assume it will in the future, for example, would only be speculation. To assume it did since creation, also, is assumption, since we really deal only with how it now is, and has been since the hundreds, or thousands of years we have observed.
Right, there are various theories, all are, of course based on the same basic precept. The constant future and past. - With which, all things are attempted to be explained
To Dad:
I am not exactly sure what you are trying to dispute, perhaps you could organize your responses in a more logical manner? You seem to display the mentality that everything is assumed, speculated and conjectured without evidence. If one wants to dispute the notion of past and future, one should evaluate the logic.
It is perfectly natural to assume that the physics in the past are causally related to the physics of today and the physics of the future, because it requires an additional assumption to consider otherwise.
You would actually have to construct an additional postulate, in that the physics of the universe were some how different than they are today and then engineer a model which describes this. We are merely inducing from observation (from several different methods) that the physics are the same.
However, if you want to dispute the notion of causality altogether, that is a philosophical discussion of science initiated by the great David Hume and not relevant to the discussion of pure science. If you are merely asking for the causal relations between the scientific discoveries and theories, that is perfectly acceptable and I am sure you will receive more than enough information from our knowledgeable PFers!
complexPHILOSOPHY said:
To Dad:
I am not exactly sure what you are trying to dispute, ..
It was mentioned that it was not assumptions but calculations. I pointed out that it was assumptions, and that really isn't disputable. Consider it a correction.
So, you assume that it was the same, I see. Also, you prefer no additional assumptions. OK.
Oh, that is easy, but I prefer to stick to what we do know, rather than get too much into theories.
Well, as far as space expanding, I guess that redshift, and the CMB just about all science has at the moment to base a claim of an expanding universe on, then. (?)
Interesting.
