How can the Cauchy integral and Fourier integral produce the same result?
  • Level: Graduate
  • Thread starter Thread starter nrqed
    Qft
317 replies · 90K views
meopemuk said:
I don't know of any experimentally verifiable prediction of QFT that would suggest that x can be measured as the position.
What about measuring electric and magnetic field strengths? These are given by Maxwell's equations as functions of x and t, and of course are well verified. Classical electric and magnetic fields have to be understood as coherent states of photons.
meopemuk said:
Moreover, in quantum theory (including QFT) each observable should have a corresponding Hermitian operator.
There is no time operator. In QFT, position is treated as an external parameter, like time, that labels operators. (Time labels operators in the Heisenberg picture.)
meopemuk said:
Why do you think that operators of observables should be written as integrals of a local density?
Because measurements are done locally. We never measure the total energy of the universe, only the energy of some local pieces. If energy were not the integral of a local density, this would not be possible.
meopemuk said:
I read this argument (particle localization = pair creation) very often, but I've never seen a detailed explanation or proof. Could you please clarify?
There is no proof because it's wrong. The construction of a single-particle position eigenstate works just as well in an interacting theory (with massive particles only). Even in an interacting theory, the one-particle states are well defined, because they form an isolated hyperboloid in energy-momentum space, given by [itex]E^2-\vec p^{\,2} = m^2[/itex]. (All multiparticle states have [itex]E^2-\vec p^{\,2} > m^2[/itex], and the ground state has E=0.) Once we have well-defined single-particle momentum eigenstates, we can take a Fourier superposition to get something that has all the properties we would want a position eigenstate to have.
But it is impossible to detect even a single particle (photon) in a static electric or magnetic field even if sensitive photomultipliers or photograhic plates are used. So, the relationship between fields and particles looks rather dubious in this case.
Yes, there is no time operator in QM and QFT simply because time is not an observable. Measured values of observables (position, energy, momentum, spin) normally depend on the physical system being measured and on its state. The value of time can be read off the clock (which is a part of the laboratory or reference frame rather than observed physical system) regardless on what system is observed or even if the system is not present at all. There is a fundamental difference between time (a numerical parameter) and position (a true observable represented by a Hermitian operator) which is correctly reflected in the formalism of quantum mechanics.
I already mentioned that the argument x in the quantum field [itex]\phi(x,t)[/itex] cannot be regarded as measured position of anything. It is also misleading to interpret parameter t as time of any event, because in QFT when S-matrix elements are calculated this parameter serves as an integration variable, so it is not present in any final result for scattering cross-sections. I haven't seen any QFT predictions of time-dependent processes that can be reliably compared with experiment.
Is local energy density also measurable? What is the energy density of a single electron? or single photon?
Eugene.
I am happy to tell that I agree with everything you wrote here. However, with one caveat. This doesn't apply to "bare" particles whose creation and annihilation operators are normally used in QFT. In most quantum field theories single "bare" particles are not eigenstates of the total Hamiltonian, so they even don't have well-defined energies. Your description is perfectly valid for "dressed" particles.
Eugene.
No, they're not. Exact expressions for single-particle states are only known for a few
very simple examples of interacting QFT (e.g: the Lee model, or certain non-4D theories).
There are no known existence proofs for any physically-interesting 4D interacting QFTs.
I am still trying to understand, if there could be in principle measurable superluminal quantum fluctuations, which could not be immediately used to transmit information with superluminal speed. How could such a purely statistical effect look like? Naively I would say, this is not possible.
Edit: If this is true, we know, that leaking out of the lightcone is something for virtual particles only. And we know, that they can do all kinds of weird stuff.
I don't think there exists an easy solution. I consider it well established that wave functions of real (not virtual) particles do "leak out of the lightcone". This leakage can be used to transmit information superluminally. However, I am not convinced that these facts can be used to build a machine that sends signals back to the past. If the possibility of such a machine can be proved, then we are in a deep trouble. Until then there is no need to worry.
Eugene.
If we could prepare a position eigenstate [itex]|x\rangle[/itex] (as defined earlier) at a definite time [itex]t[/itex], and if we had a detector that gave a signal if and only if the particle appeared at point [itex]x'[/itex] at time [itex]t'[/itex], and if we could arrange things so that no particle other than the one we prepared could possibly ever show up in the detector, then we could do this experiment repeatedly, and we would find that, in a fraction roughly [itex]\exp(-ms)[/itex] of the time, where [itex]s=(|x-x'|^2-(t-t')^2)^{1/2}[/itex] is the invariant separation between the points, the particle would appear at [itex]x'[/itex] before a speed-of-light signal could get there.
All big ifs, though.
If instead of releasing just one particle we release a large number of them from point x simultaneously, then the probability of registering the superluminal signal by the detector at x' will be much greater than [itex]\exp(-ms)[/itex]. By doing this we can guarantee that the superluminal signal arrives to the detector with almost 100% certainty.
Eugene.
One thing, which makes me skeptical about the whole effect being real is, that obviously the leaking gets bigger, the lighter the rest mass of the particle is. But then for a particle with zero rest mass the effect disappears. Shouldn't there be a continuous change of the effect between zero restmass and very light restmass?
Eugene.
This was my thought as well. We also do not need to worry about, whether it is the same particle. A statistical effect is good enough. The concept of the identity of a particle does not make sense anyway in QM.
Eugene.
How does this go together with the axiom (or theorem?) of QFT, that two quantum operators separated by a spacelike distance commute?
Are you sure that the effect is absent for zero mass particles? As far as I know, the position operator and localized states have not been successfully defined for such particles yet.
Eugene.
Yes, people keep writing these things in textbooks, but I couldn't understand their logic.
Yes, there are quantum fields [itex]\phi(x,t)[/itex] in QFT and they (anti)commute at space-like separations. As shown in Weinberg's vol. 1 this property is important to ensure that interaction operators constructed as polynomials of quantum fields are relativistically invariant. But quantum fields do not correspond to any physical observable measured in experiment.
It is true that we can build some operators of total observables (total momentum, total energy, etc.) as integrals of certain field products. Then x is an integration variable, and the resulting operators have no dependence on x. So, it doesn't make sense to say "operators of total energy separated by a spacelike interval".
There are also operators of observables (position, momentum, energy, etc.) of individual particles. (For example in the 2-particle sector of the Fock space there are two distinct operators of particle momentum). These particle observables cannot be represented as functions of quantum fields. So, the idea of "spacelike separation" is not applicable to them as well.
Eugene.
Eugene.
I thought, we would only need the photon propagator presented by Hans earlier.
Also with m=0, hbar drops out of the KG equation.
Sorry if this is too simple minded.
EDIT: I remember, you did a different calculation with position Eigenstates with a slightly different result.
Propagators are great tools for calculating scattering cross-sections via Feynman diagrams, but they (propagators) are not designed to describe the evolution of one-particle wave functions in space and time. Avodyne wrote a good post #188 about that.
Eugene.
Eugene.
ok, but what would we put into the exponential?
Do you mean the exponential decay of photon's wave function outside the light cone?
I don't know about that. As I mentioned, the definition of the position operator and localized states for massless particles is a controversial issue. I have references to (at least) a dozen papers discussing this situation, but I don't think they found an acceptable solution yet.
Eugene.
meopemuk said:
It would all need to be re-done with 4-momentum integrals, and
4-positions, using [tex]\delta^{(4)}(k^2 - m^2)[/tex]
Why? Obeying the Poincare invariance (which is the true mathematical expression of
the principle of relativity) does not require you to perform all calculations in a
4-dimensional notation. A theory is relativistically invariant if and only if it has a
representation of the Poincare group of inertial transformations. In most cases the
3D notation is entirely appropriate for relativistic theories and their comparison
with experiment. The 4D notation is often (e.g., in this case) redundant and confusing.
Construct a (single-particle) vector space of states indexed by all the possible tuples
of 4-momentum. At this point we don't yet have a Hilbert space because we haven't
specified an inner product. It also does not yet carry a Poincare representation, and
hence doesn't represent the states of a physical particle type.
Now consider a spin-0 particle type of mass m. To turn the 4-momentum vector space into
a (single-particle) Hilbert space for this type of particle, we restrict to the subset consisting
of 4-momentum vectors which satisfy the usual relativistic mass formula. That's done via
multiplying by the familiar [tex]\delta^{(4)}(k^2 - m^2)[/tex] expression. Now (and only
now) we can turn our (restricted) vector space into a Hilbert space by specifying the inner
products between all states such that we only mention the 3-momentum:
[tex]<k'|k> = ... \delta^{(3)}(k'-k)[/tex], (and taking the completion, which I won't worry
about here).
But now, if we try to change from momentum basis to coordinate basis, extra care is
needed. If we start from the original 4-vector momentum space (non-Hilbert) we
can do the usual Fourier transformations and pass to a 4-vector coordinate space (like
Minkowski space), but this is not a Hilbert space of states. To get a Hilbert space
in a coordinate basis, we must start from the Hilbert space in momentum basis,
with the restriction [tex]\delta^{(4)}(k^2 - m^2)[/tex], and then do the Fourier-transform
stuff. Multiplication by [tex]\delta^{(4)}(k^2 - m^2)[/tex] in momentum space
corresponds to convolution with [tex]F_x(\delta^{(4)}(k^2 - m^2))[/tex] in coordinate space,
where [tex]F_x[/tex] denotes Fourier transform [itex]k\to x[/itex], hence the allowable
4-vectors from the full 4D coordinate space are restricted to those which are obtained
via this complicated convolution. Only those states are in our Hilbert space, so talking
about position states indexed by arbitrary 4-position coordinates is incorrect in
general, because they might not be in the Hilbert space of the relativistic particle.
So 3D notation is reasonably ok in momentum basis, because the relativistic constraint
is easy to keep in mind (and it's easy enough to convert a 4D integral containing a
[tex]\delta^{(4)}(k^2 - m^2)[/tex] into a 3D integral containing a [tex]1/E_k[/tex]).
The same cannot be said for the coordinate basis.
Yes, this 4D momentum-energy space is not suitable for describing single particle states. Then why do you begin your construction with this irrelevant space? From Wigner's theory of irreducible representations of the Poincare group we know that elementary particles are characterized by a single value of the Casimir invariant [itex]m = + c^{-2}\sqrt{H^2 - c^2 \mathbf{P}^2}[/itex]. Therefore the complete set of mutually commuting operators can be chosen as [itex](P_x, P_y, P_z)[/itex]. The fourth operator [itex]H[/itex] is redundant, because it is a function of the three components of momentum and the constant [itex]m[/itex]. Thus the single particle Hilbert space is a span of common eigenvectors of [itex](P_x, P_y, P_z)[/itex], i.e., the set of functions [itex]\psi( \mathbf{p})[/itex] in 3 dimensions.
[tex]<k'|k> = ... \delta^{(3)}(k'-k)[/tex], (and taking the completion, which I won't worry about here).
Yes, if you like, you can build the 1-particle Hilbert space as a set of functions confined to the mass hyperboloid.
Yes, this would be completely unphysical, because this would lead to "wave functions" localized in space and time like [itex]\delta^{(4)}(x-x') = \delta^{(3)}(\mathbf{r-r'})\delta(t-t')[/itex]. Such "wave functions" would describe particles that exist for an infinitesimally small period of time unlike any familiar particle in nature.
To me this indicates that the 4D formalism is not helpful at all. If we want to construct the position representation we can find the Newton-Wigner operator [itex]\mathbf{R}[/itex] as a function of 10 generators of the Poincare group. Then we can find the action of [itex]\mathbf{R}[/itex] on 3D momentum-space wave functions [itex]\psi( \mathbf{p})[/itex], find eigenvalues and eigenvectors of [itex]\mathbf{R}[/itex] and thus define the position-space basis.
Eugene.
Because I was trying to illustrate the non-obvious pitfalls that occur when one naively
tries to mix position-momentum Fourier transformation with relativistic QM.
But I ended up in essentially the same place as you.
[...] If we want to construct the position representation we can find the Newton-Wigner
operator [itex]\mathbf{R}[/itex] as a function of 10 generators of the Poincare group. [...]
Actually, I happen to share Haelfix's opinions about the N-W operator. I don't buy it.
I think one should start with the larger Heisenberg-Poincare algebra (15 generators)
rather than merely Poincare(10 generators), and try to construct a QFT from its
unitary irreps. But this is an unsolved task, and the H-P algebra also has the
possible problem of not being stable under small deformations. (I mention this only
as a possible research direction, not as established mainstream.)
The Poincare group has the clear advantage that it is composed of real physical transformations that we can easily observe in everyday life. Of course, one can assume that there is also some hidden reality and try to enlarge this group. Then one would enter the shaky ground of mathematical speculations.
I agree that Newton-Wigner position has some unusual properties, like boost non-invariance of localization and superluminal spreading. However, it hasn't been demonstrated that these properties are in contradiction with hard experimental data. So, I don't see any compelling reason to dismiss the Newton-Wigner position operator.
Eugene.
Hi Strangerep, I was thinking about the Reeh-Schlieder theorems. Actually the N-W operator was modernized in hopes of bypassing this theorem, but people still argue about that today. Its a tremendously thorny subject, and its also largely irrelevant, b/c no one hsa the faintest clue how to make a falsifiable experiment that could detect such a thing.
Anyway I view the N-W operator as a mathematical construct that probably has limited applicability. If there is such a thing as a position operator in qft then it would be the NW operator but alas its probably at best only well defined in simple free field theories with massive particles. (This leads into the tired debates about whether a photon really exists or not, etc)
On philosophical grounds I also somewhat object to these sort of inbetween meta constructs. You either introduce QFT with full mathematical rigor (alla Aqft or other axiomitized attempts) or you should be satisfied with sloppy physicist traditional field theory from textbooks that is largely experimentally and simplicity motivated.
Eugene.
Yes, that's what I mean.
I mean, just from dimensional analysis, not from a full blown calculation.
First of all, the exponent as a whole must be dimensionless. Obviously a spatial coordinate should appear. Then I think, there should be an hbar in it. And then you need something with dimensions energy. At the moment, I can not think of anything, that makes sense here.
In my opinion, historically, a number of interpretation difficulties have
unfortunately led people to the NW position operator. Most of all there
is the velocity operator which seems wrong when it produces +c/-c.
But it's not wrong, it's right. the interpretation is wrong.
It gives -c for the left chiral and +c for the right chiral component, this
is just a one step further subdivision of the physical process as the series:
[tex]\frac{1}{p^2-m^2}\ =\ \frac{1}{p^2}+\frac{m^2}{p^4}+\frac{m^4}{p^6}+\frac{m^6}{p^8}+...[/tex]
Where all the right hand terms propagate on the light cone. To see this
we can write down the linearized chiral Klein Gordon equation:[tex] \left[\ \left( \begin{array}{ll} 0 & 1 \\ 1 & 0 \end{array} \right) \frac{\partial }{\partial t} + c \left( \begin{array}{cc} 0 & 1\ \\ -1\ & 0 \end{array} \right) \frac{\partial }{\partial r}\<br /> \right] \left( \begin{array}{c} \psi_L \\ \psi_R \end{array} \right) = \frac{mc^2}{i\hbar} \left( \begin{array}{c} \psi_L \\ \psi_R \end{array} \right)[/tex]
The operator between the brackets becomes the d'Alembertian when squared.
Put sigma's in the second matrix and you've got the Dirac equation. So the
velocity operator gives us:
[tex]\vec{v}\ =\ \frac{\partial\vec{r}}{\partial t}\ =\ \frac{i}{\hbar}[\ H,\vec{r}\ ]\ =\ -c\ \mbox{for}\ \psi_L,\ \ \ +c\ \mbox{for}\ \psi_R[/tex]
The role of m in the equation is that it reflects the two counter propagating
components back and forward into each other. The average speed is v.
This whole process is actually pretty classical. It occurs in a simple mass/
spring transmission line described by the Klein Gordon equation like here:Klein Gordon mass/spring system
Where the 'm' masses cause the reflections of the left and right propagating
waves into each other. I've been doing some lattice simulations lately of the
above linear chiral Klein Gordon equation and get very nice results, see:
Propagating particle
Well, that's pretty much unitary isn't it... and guess, no propagation
outside the lightcone. :approve:Regards, Hans
So, the correct relativistic velocity-density operator is:
[tex]\vec{v}\ \ =\ \ \bar{\psi}\ \frac{i}{\hbar}[\ H,\vec{r}\ ]\ \psi[/tex]With the plane wave solution,
[tex]\left( \begin{array}{c} \sqrt{E-p} \\ \sqrt{E+p} \end{array} \right)[/tex]we get for the velocity-density v=p, which, when integrated over the entire
(Lorentz contracted) wave function gives v for the speed of the particle.
Edit(2x): The formula holds as well for the full Dirac equation, since:
[tex]\frac{i}{\hbar}\ [\ H,x^i\ ]\ = \ c\gamma^i[/tex]Regards, Hans
It's easy to do my calculation of the propagation of a localized particle (in post #188) for the massless case, ignoring the potential complications of what it means to have a single massless particle, etc.
In d space dimensions, we have
[tex]\langle \vec x{\,}'|e^{-iHt}|\vec x\,\rangle<br /> =\int {d^d k\over(2\pi)^d}\,e^{-ikt}e^{i\vec k\cdot(\vec x{\,}'-\vec x{\,})}<br /> \propto {it\over(r^2-t^2)^{(d+1)/2}}[/tex]
where [itex]r=|\vec x{\,}'-\vec x{\,}|[/itex]. (To get this I did the integral in euclidean time, and then continued back.) This formula shows no exponential suppression outside the lightcone.
Those are exactly the reasons for my interest in the Heisenberg-Poincare algebra (or
some stabilized deformation thereof).
The basic H-P algebra is of the following form (I won't write out all the indices):
[ J , J] = ...terms in J only...
[ J , P] = ...terms in P only...
[ J , X] = ...terms in X only...
[P, X] = ...E...
Here, J is the 6 Lorentz generators, P is the 4 momentum generators,
so that part is just the Poincare algebra. X is the 4 position generators,
and E is a central element, so the last equation above is just the usual
Heisenberg commutation relation. So there's 15 generators in total.
The X generators have perfectly reasonable physical foundations.
The central element E is just from elementary QM. So there's nothing
physically wrong with this as a starting point. No "hidden reality"
is involved.
However, it turns out that the algebra is not stable under small deformations,
and this leads one to consider stabilized variants of the algebra, but I won't
delve into that here (because I don't yet understand it very well).
What are these foundations? Other generators are related to well-known inertial transformations of reference frames (space and time translations, rotations and boosts). What finite transformations are generated by X?
Eugene.
[P, X] = ...E...
Interesting, I always felt that the x,p relations were somehow
missing from the commutation prescription.
Regards, Hans
