How can the inequality hold for an injective function?
9 replies · 16K views
waht
This is something I understood before, but for some reason I forgot it. How do you prove this inequality holds, if f is injective?
[tex]A_0 \subset f^{-1}(f(A_0))[/tex]
If x is not in A, then f(x) is not in f(A) (injectivity) so x is not in f^-1(f(A))
Proofs of set algebra identities tend to be rather formulaic. If you look at the definition of "subset", then two proofs should immediately suggest themselves:
Let x be an element of A_0 ... Therefore x is in f^{-1}(f(A_0))​
and
Suppose x is not an element of f^{-1}(f(A_0)) ... Therefore x is not in A_0​
And from there, you simply have to fill in the missing steps. And again, the missing steps are usually obvious from unwinding the definitions.
Yes, but that doesn't say anything about what happens if x IS A, which is the whole point.
what, the standard way of proving "[itex]A\subset B[/itex] is to start "If x is in A" and then conclude "then x is in B".
If x is in A_0, you know that f(x) is in f(A_0). Now, what does the fact that f is injective say about x and f-1(f(A_0)).
HallsofIvy,
I'm not sure what you mean. I showed [tex]f^{-1}(f(A_0)) \subset A_0[/tex] which is the other half of the equality what was asking for.
Nolen Ryba said:
HallsofIvy,
Yes, I understood that. That was why I said, "If x is in A_0"- because that's the direction you want to prove.
Am I reading this incorrectly?
I'll assume you're starting from: f:A -> B and A_0 is a subset of A.
The inclusion relation you've written holds regardless of whether f is injective or not.
However, if f is injective, then the relation can be written as an equality.
Proof is nothing more than working the definitions, as has already been suggested.
Finally, it dawns on me. I was reading the whole thing backwards. I thought the question was to prove that if f is injective, then... Sorry, everyone.
