How can you actually measure the electron position?
The discussion centers on measuring the position of electrons in quantum mechanics, specifically referencing the Born rule, which states that the probability of finding a particle in a certain region is given by the equation $$ |\Psi ({\bf r},t)|^2d^3r $$. Participants describe various experimental methods for measuring electron position, including using a photographic plate to detect impacts and employing slits to determine passage. The conversation also touches on the complexities of measuring photon positions, emphasizing that while localization is possible, obtaining an exact position remains problematic.
  • Understanding of the Born rule in quantum mechanics
  • Familiarity with experimental techniques in particle physics
  • Knowledge of the Heisenberg Uncertainty Principle (HUP)
  • Basic concepts of Quantum Electrodynamics (QED)
  • Research experimental setups for measuring electron positions using photographic plates
  • Study the implications of the Heisenberg Uncertainty Principle on measurement techniques
  • Explore Quantum Electrodynamics and its treatment of photon position measurements
  • Review academic papers on electron localization experiments
Physicists, quantum mechanics students, and researchers interested in experimental methods for measuring particle positions, particularly in the context of electrons and photons.
Tomishiyo
Standard quantum mechanics text-books discusses Born rule, which states that the probability of finding a particle in a certain region in space is given by
Thing is, I never have seen a discussion about how you can actually measure the particle position in a given system. Do you use x-rays? How the experiment actually works? Can you refer me to papers about it or describe the experiment with details?
You can let the particle run into a photographic plate which produces a dot at the point of impact. Or you can shine light on the particle and look for reflections/scattering. That sort of thing.
Likes bhobba
As has been stated, you let an electron hit a screen that will leave a mark or a signal. I can also make a very small slit, and if I detect a signal after the slit, I know that the electron passed through that position where the slit is. The uncertainty in the position corresponds to the width of the slit.
Zz.
Zz.
I think the OP meant the position of the electron in an atom.
This is the OP's post (my emphasis)
Nowhere in there is there any indication that this is only for within an atom.
Zz.
Zz.
That is why I said I think, because he said "in a given system", atoms being the more interesting case. But anyway the OP himself can clarify if he wishes.
"Interesting" is subjective. Electrons in a Luttinger Liquid system is more interesting to me. Yet, I try not to impose what I find "interesting" to the question.
Zz.
Zz.
And yet, if you let a photon go through the same slit and detect it, you haven't measured its position. Or so I'm told.
I have too! At the moment that photon passed through that slit, where do you think it is? 20 miles away?
I have dealt with this in my explanation of the HUP in another post
https://www.physicsforums.com/threads/misconception-of-the-heisenberg-uncertainty-principle.765720/
... or so I'm told.
Zz.
Likes bhobba
He is referring to the fact in QED for a photon position is not an observable.
http://arnold-neumaier.at/physfaq/topics/position.html
'The POVM does not allow one to talk about the position of a photon - which could exist only if the corresponding operator existed -, but only about the measured position: The photon is somewhere near the range of values established by the measurement, without any more definite statement being possible.'
In other words you can localise its field but getting an exact position is problematical.
Thanks
Bill
Thanks
Bill
But within the context of this thread, i.e. the OP is asking how one actually measures the position of a particle, it is the act of measurement and the experiment that matters. As I've said, I can localize the position of a photon or an electron when it passed through such a slit. A whole slew of experiments depend on that being true. Otherwise, a lot of things will go wrong with our measurements.
Zz.
Likes bhobba
Hi Zapper
For sure.
Thanks
Bill
Why 20? ...if he were wrong, then one would have been enough... :oldeyes:
Thank you all for your answers, and apologies for my delayed answer.
I was not thinking only about atoms, but it would be interesting to know how the experiment is done in this case. Also, does anyone knows any paper describing one of such experiments?
  • · Replies 36 ·
  • · Replies 96 ·
