What causes the mysterious eclipses in Epsilon Aurigae?
  • Context: Undergrad
  • Thread starter Thread starter zuz
    Stars
The discussion revolves around the concept of independent star systems and the proximity of stars to one another, particularly in the context of gravitational binding and observed star collisions. Participants explore theoretical limits, observational evidence, and the dynamics of star interactions, including those in globular clusters.
  • Some participants argue that "independent systems" relates to velocity and gravitational binding, while "close" pertains to position, suggesting these criteria cannot be directly compared.
  • There is a theoretical possibility for stars to be very close yet remain independent if they are on hyperbolic paths, although this is complicated by gravitational interactions.
  • Participants note that while stars have collided, such events are rare and may not fit the criteria of being unbound at the time of collision.
  • Some suggest that blue stragglers may be evidence of collisional events, but the specifics of these formations and their implications for independence remain debated.
  • Questions arise about the minimum observed distance between stars and the challenges in measuring such distances accurately due to observational limitations.
  • There is a discussion about the dynamics in globular clusters, where star density is higher, potentially leading to more frequent interactions, although no current observations of unbound star collisions are cited.
Participants express differing views on the definitions of independent systems and the implications of star collisions. There is no consensus on the minimum distance observed between stars or the nature of star interactions, indicating ongoing debate and uncertainty.
Limitations include the difficulty in observing star collisions and the challenges in accurately measuring distances in three dimensions. The discussion also highlights the complexity of gravitational interactions in clusters versus isolated systems.
zuz
The closest star tp the sun is 4 light years away. Are there any stars that are closer that are not part of a multi=star system? How close close can stars get to each other and still be independent systems?
Astronomy news on Phys.org
"Independent systems" is a statement about velocity and gravitational binding. "Close" is a statement about position. They cannot be directly compared.
Gliese 710 will pass 0.2 light-years from Sun in 1.3 mln. years from now.
No.
The fact that the Centauri system is a trinary says nothing about the fact that its the closest star system to us.
In theory, they can get close enough to distort each other and still be independent - if it were a flyby on a hyperbolic path. 😉
With the exception one little part, they aren't really being compared, they are simultaneous but separate criteria. Reading between the lines, the answer would be there is no limit. A follow up might be; what has been observed?
The difficulty is time: gravitational binding is a long term phenomena whereas a flyby or collision happens fast and is easy to miss.
If stars were points, that would be true. You tell me how close you want it, and I'll tell you how fast it needs to be going.
The OP isn't asking about theory, he's asking about reality. Again, reading between the lines (I shouldn't have to), the answer I'm seeing is "arbitrarily close to zero". So, how close have we observed in reality? I suspect the answer due to the timing issue is not very close at all.
Stars have collided. That's pretty close.
  • Haha
Have we observed stars that were not gravitationally bound collide? It must be an extremely rare thing to observe.
Still, this violates the OP's criteria, so while I'd be interested to know, it doesn't answer the question.
Blue stragglers (at least some of them) are thought to be collisional. This is a complicated business, but the velocity distributions of at least some subsamples are different than that of typical stars, which is not what you'd expect if the sole formation source was mass transfer from pre-existing binaries.
Does this "count"? Well, Star A is not bound to Star B, but both are bound to their globular cluster as a whole. But I maintain that if that doesn't count, no stars in galaxies count, and that's practically all of them.
How independent? In fact what do you mean by the word? Orbits (two body) that are circular or elliptical could be called not independent but when the orbits are hyperbolic, the kinetic energy is greater than the potential energy at the closest point. A close approach perhaps but the two could be called independent.
But the point has already been made that stars tend to appear in galaxies or clusters and there is a multi-body solution.
I'd say it's a fair assumption that the OP is considering 'independent' to mean not part of a stable binary or trinary system, like in his example of A. centauri.
Sorry for the discrepancy. Yes, I meant not part of a binary system, and yes I meant what has been observed. I know all stars are moving around in space. I just wondered what was the minimum distance observed between two stars was right now. Also, is the Centauri system moving toward or away from us? Thanks.
In that case, the minimum distance is zero because stars (rarely) collide.
"... the mean radial velocity has been determined to be around 22.4 km/s towards the Solar System."
https://en.wikipedia.org/wiki/Alpha_Centauri#Kinematics
That gives you about ... (...furlongs in a cubit ... carry the one...) 57,500 years to cover your roof in reflective paneling.
It’s less uncommon in globular clusters, where the density of stars is much greater.
No, because can you point at observed star collision?
Not a blue straggler suspected to have formed by collision some time before observation (and it is argued whether blue stragglers might form by inspiral of binaries previously bound) - no, actual observed collision, constellation, year, date, properties of each precursor and resulting star?
And even that would not be distance between two stars right now because a past observed collision is one star now. Are there any stars observed on collision course that are now unbound (not on inspiral course)?
Globular cluster - Wikipedia
The typical distance between stars in a globular cluster is about 1 light year, but at its core, the separation is comparable to the size of the Solar System (100 to 1000 times closer than stars near the Solar System). Globular clusters are not thought to be favorable locations for the survival of planetary systems.
So looking at nearby globular clusters today, we don't see any stars colliding. But it should be possible to calculate the average time between collisions which result in mergers. Yes, these are thought to be so-called blue stragglers. (The straggler part is that stars that blue and bright could not have formed when the rest of the globular cluster did. Assuming that they were created recently in collisions works.)
No. It is very tricky since, observing from Earth we can measure two dimensions very accurately, but the third dimension will have an error of light years. If two stars are orbiting each other, that allows us to determine both that they are bound, and give a better estimate of distance.
Would it be possible to work out all the gravitational interactions in a globular cluster, and predict which stars will collide when? Not today. Quantum computers with millions of qubits might make it possible.
snorkack said:
No,
No what?
No, the minimum distance is not zero? Or no, stars don't occasionally collide?
So what?
Not having observed such an event doesn't negate anything Vanadium asserted.
Not sure what your case is here.
Nope. I can't point to a living Tyrannosaurus Rex either. However, I can point to their remnants.
As of present, we have catalogued ~200 million of the ~200 billion stars in our galaxy alone, or roughly 1/1000 them. Not seeing a remnant of a star collision in those catalogued stars merely puts an upper limit on the number of star collisions that could have occurred in the galaxy but does not eliminate their existence entirely. (so for example, if there is, on average, 1 collision per 100 million years or so, then our galaxy might have 130 collision remnants and the odds of one of those being in our 200 million star sample are fairly low. )
Lack of evidence is not always evidence of lack.
There have been a number of observed inspirals in a few years. One of them formed a kilonova. That was two neutron stars merging.
Do collisions between main sequence stars cause any brightening?
But they were gravitationally bound to each other, and furthermore, don't seem to address your earlier point of "no". Could you answer Dave's question?
I agree with that, but am not sure it's the very best example. First, how would we know a given star had been in a collision? It's not like it would have a dent in it or would be patched with Bondo. Second, if one compares the volume swept out by stars over a couple of billion years to the volume of the disk, it's much less. So we don't expect any collisions in the disk. Maybe the core, but things are both more uncertain calculationally, but also harder to see.
All of these problems go away when one looks at blue stragglers (BSSs). These stars are in globular clusters (GCs) and they are brighter and bluer than their neighbors, and by implication, younger. GCs are very dense collections of very old stars - star formation has stopped billions of years ago. There is both strong evidence for them being collision remnants and weak evidence. The stronger evidence is that if they were main sequence stars, they are much younger than their GC. BSSs are of varying calculated ages, so are not the product of some "microburst" of star formation. For at least some of them, their velocity distribution differs from stars in the cluster, as if they had an event that transferred a lot of momentum to them in the past. The weaker evidence is that they tend to be about twice as large as their neighbors and rotate faster: just what you expect from collisions, but also a purely statistical measure. One can find heavy stars and fast rotating stars in our own galaxy, where we don't think they have collided. So I cast this argument as weaker, since it is purely statistical.
Can we determine the cause of a collision when we look at remnants? For example CK Vulpeculae, can we be sure that was a binary merger? I realize that the odds of a binary merging are much much higher than a random impact. What would look different if the rare event did take place?
Yes, a great deal of brightening. Then the source should be snuffed out by dust and clouds.
There should be a very large range of possible outcomes from a hyperbolic collision. If you really lined them up "dead nuts" core-to-core it should make an exceptionally large explosion. Fusion already happens in the cores and perfect collision will add temperature and pressure. You could also have a situation that would be a near miss if stars were billiard balls. Suppose, for example, two G-stars have their center of masses exactly 2 solar radii away from each other at perihelion. They would still exchange matter and some material would be flung out of orbit. Or flung into orbit and then blown out on the solar wind. The impact would be effected by the star's rotation rate, direction of travel, and composition. Even if two stars completely missed and did not exchange material there should be some strong tidal effects. Just elongating a star should make it brighter because of increased surface area.
The outer surface of a star is much hotter than the interior. Anything that causes extreme turbulence and mixing should bring hot material outward. Gasses cool when they expand like in red giants but that is still an increase in brightness.
If we just dropped a 1 kg brick into the Sun it should be moving at 617 km/s. Energy is 1.9 x 1011 J. That is less than the core of nuclear bomb but would still be very hot. 10s of millions of degrees K. Any fusion that takes place during the impact would add energy. Meteors are white hot even though they are just falling into Earth's gravity.
  • Skeptical
Spica is an example.
Nitpick: the above passage seems to suggest that a meteor's velocity is in large part due to falling.
The change in velocity of a meteor due to Earth's gravity is a very small component of its orbital velocity.
Meteors have velocities between 10 and 70 km/s whether or not Earth is nearby to deflect their path.
https://www.physicsforums.com/threa...imming-ready-to-supernova.982440/post-6281405
Craig Wheeler of The University of Texas at Austin has found evidence that the red supergiant star may have been born with a companion star, and later swallowed that star. As Vanadium 50 mentioned in a previous post, that's pretty close.
https://www.ifa.hawaii.edu/~barnes/research/stellar_collisions/index.html
https://en.wikipedia.org/wiki/Stellar_collision
V1309 Scorpii: merger of a contact binary
https://www.aanda.org/articles/aa/pdf/2011/04/aa16221-10.pdf
https://arxiv.org/abs/1012.0163
Another system that has intrigued me over 5 decades is Epsilon Aurigae
https://en.wikipedia.org/wiki/Epsilon_Aurigae
  • · Replies 0 ·
  • · Replies 48 ·
  • · Replies 28 ·
  • · Replies 0 ·
  • · Replies 49 ·
  • · Replies 109 ·
