How come a liquids dynamic viscosity is not indicative of flowrate?
The discussion revolves around the relationship between a liquid's dynamic viscosity and its flow rate through a pipe, particularly in the context of an experiment involving a tank setup. Participants explore the implications of viscosity on the time it takes for different fluids to drain from a tank, questioning the expected outcomes based on theoretical models.
  • Experimental/applied
  • One participant describes an experimental setup using a tank and a pipe to investigate the effect of viscosity on drainage time, proposing a formula derived from the Hagen–Poiseuille equation.
  • The participant notes that while dynamic viscosity is expected to influence flow rate, their experimental results with rapeseed oil and water do not align with theoretical predictions, as the oil takes longer to drain but not proportionally to its higher viscosity.
  • Another participant clarifies that dynamic viscosity is distinct from density, which relates to kinematic viscosity, and emphasizes the importance of temperature in measuring viscosity accurately.
  • Further clarification is provided regarding the application of Poiseuille's formula, which does not include density unless expressed in terms of kinematic viscosity.
  • Participants discuss the sensitivity of flow rate to pipe radius, with one suggesting that the outlet pipe's diameter may be too large for the experiment, potentially affecting the results.
Participants express differing views on the relationship between viscosity and flow rate, with some asserting that the theoretical models do not adequately predict experimental outcomes. There is no consensus on the reasons for the discrepancies observed in the experimental results.
Participants note the potential impact of factors such as pipe diameter and temperature on viscosity measurements, which may not have been fully accounted for in the experimental design. The discussion highlights the complexity of fluid dynamics and the limitations of applying theoretical models to practical scenarios.
Zaxo3000
REWRITTEN:
Well if you're interested I have a tank (actually a PVC tube with an end cap) that has an interior diameter of 86 mm. It stands on its circular face. Coming out near the bottom of the tank at a right angle is a metal pipe 11 mm in diameter (interior) and 312 mm long (in total that is, note that some of the pipe is protruding within the tank and not just out of the tank to stabilise it). Here is a picture similar to what I did on page 3 http://seniorphysics.com/physics/ejp_sianoudis.pdf (I’m not doing the same experiment).
I fill the tank with water until enough water is in the tank so that it starts to flow out of the pipe (there is some space beneath the exit pipe's hole). I do this so then I know if I add another litre of water now, 1 litre should come out (no space inside the tank beneath the pipe hole now). My experiment is aimed at investigating the effect of viscosity on the time the tank takes to empty (not really empty because when the water level is beneath the top of the pipe the theory does not stand, so about there). First I would like a formula that can predict the volume of fluid in the tank at any time. I know that according to the Hagen–Poiseuille equation
ΔP=8μLQ/(πr^4 )
ΔP is the pressure drop
L is the length of pipe
μ is the dynamic viscosity
Q is the volumetric flow rate
r is the radius
π is the mathematical constant
This can be arranged for the flowrate:
ΔP(πr^4 )/8μL = Q
The pressure difference across the ends of the pipe is due solely because of the column of water in the tank right? This pressure equals:
P=hρg
P is the hydrostatic pressure (Pa),
h is the height of the water (m)
ρ is the fluid density (kg/m3),
g is gravitational acceleration (m/s2),
Thus substituting this in the flow rate equation:
Q = ΔP(πr^4 )/8μL and P=hρg
-> Q = hρg(πr^4 )/8μL
Q = hρgπr^4/8μL
The height of the water column in the tank can be related to the tank volume. Note the radius of the tank will be notated with [r2] as the other plain "r" is for the pipe radius:
Volume of a cylinder = hπr^2
V/(π[r2]^2)=h
Thus
Q = hρgπr^4/8μL
Q = ρgπr^4/8μL x V/(π[r2]^2)
Q = Vρgπr^4/8μLπ[r2]^2
Q = Vρgr^4/8μL[r2]^2
Or Q = kV where k = ρgr^4/8μL[r2]^2 <- These are all constant
Since Q = dV/dt
Thus dV/dt = kV <- Flipping this...
Or dt/dV = 1/k x 1/V Integrating with respect to V
Thus t=1/k x ln V + c
t-c=1/k x ln V
k(t-c)= ln V
e^[k(t-c)]=V
V=e^(kt-kc)
V=e^kt x e^-kc
when t=0 V =Vo
Thus Vo=e^-kc sub this back into V=e^kt x e^-kc
V=e^kt x Vo
Thus V=Vo x e^kt
So there we go I got a formula for volume at any time.
Taking the dynamic viscosity out of k we get:
k = ρgr^4/8L[r2]^2
and
V = Vo x e^(kt/μ)
So according to this if I doubled μ the graph of "V" would be stretched in the x direction away from the y-axis by a factor of 2. So if it originally took 20 secs to half empty the tank, doubling the viscosity should make it take 40 seconds to empty the tank right? Yet rapeseed (canola) oil and most things are hundreds of times as viscous as water even at room temperature, yet just from experience we know they do not flow 100 times slower nor would drain from a tank taking 100 times longer.
Using my tank setup I tested rapeseed oil (μ = 160 mPa•s ) and water at 20 degrees Celsius (μ - 1mPa•s) and rapeseed oil (just roughly looking at it now) took maybe 6 times as long. I thought it might be because when viscosity changes so does the density values, but they are fairly similar so that can't be it. What’s worse the equation V=Vo x e^(kt/μ) doesn’t seem to fit my data or even appear realistic, although I haven't checked this last part. So what’s going on? Do I lack understanding? Am I just doing it wrong? Can anyone explain this?
Good morning, Zaxo.
It is a good idea to use breaks and paragraphing in your text. It makes it considerably easier to read.
First to clear up some misconceptions.
Dynamic viscosity has nothing to do with density. That property is called kinematic viscocity, which equals dynamic viscocity divided by density.
Poiselles formula does not contain a density factor, unless it is presented in terms of kinematic viscocity and is applicable to pipes.
For a pipe of length L and radius r with a pressure difference between the ends the discharge Q is
[tex]Q = \frac{{\pi ({p_1} - {p_2}){r^4}}}{{\eta L}}[/tex]
where [tex]\eta[/tex] is the dynamic viscocity.
The kinematic viscocity,[tex]\nu[/tex] is
[tex]\nu = \frac{\eta }{\rho }[/tex]
Now I do not have figures for rape seed oil but here is a comparison between water and castor oil
Water Dynamic viscosity 1.79; 1.00; 0.65 centipoise
Castor oil dyn viscosity 6400; 973; 227 centipoise
Taken at 0oC; 20oC; 40oC
You can see how dramatically the oil viscosity reduces with temperature, relative to the water.
So when you do this experiment it is vital that you record the temperature to obtain an accurate viscosity value.
Studiot said:
Good morning, Zaxo.
Thanks for the response. I've corrected my question now, i actually meant the density that was substituted into Poiselles formula with water colum height and gravity in place of pressure difference. Ill insert some paragraph breaks too. Also even your figures show the castor oil is hundreds times more viscous even at room temperature of testing. I would still appreciate an explanation as to why the time taken for the different fluids to (for instance) reach half the tank volume is not hundreds of times greater for the thicker oil, even though viscosity is.
If you were to post some details of your experiment I might be able to comment more.
I added a lot of additional information into the original question. You now know as much as I do about this. Can you figure it out?
Experimentally your method should 'work'.
Hoever I wonder if your outlet pipe bore (r=5.5mm) was not too large?
Your reference article notes extreme sensitivity to pipe radius (r4) and the max radius in their tests was less than half yours at 2.5mm
This experiment is normally conducted with small bores pipes (capilliaries).
Incidentally you can use the X2 and X2 icons on the main reply box to obtain powers and indices.
Thanks a lot for going to the trouble of reading all my work and helping me. At current what you say seems like the most logical explanation. And thanks for the tip.
Studiot said:
Read here about turbulence and calculate the Reynolds Number for your flows.
http://www.frca.co.uk/Documents/100308 Physics of flowLR.pdf
Hey so since Reynolds Number = pvD/μ
and in this case
p=Density of water = 1000 kg/m³
the pipe diameter D = 0.011 m
The dynamic viscosity of water is 1.002 mPa•s 20 °C (the temperature of testing)
and the velocity that was initially measured of the water exiting the pipe was 0.856 m/s this goes to:
Reynolds Number = 1000 * 0.856 * 0.011 / 0.001 = 9416
This is greater than 4000 and 2000 so is my experiment not laminar flow but actually turbulent flow? That is until v = .364 when the flow will become transitional and then when v = 0.182 when the flow becomes laminar?
Also is there any way to calculate the theoretical volume at any time either which does take into account viscosity and pipe length?!?
15K
12K
