How could something that is infinite (the Universe) expand?
  • Context: High School
  • Thread starter Thread starter alae
    Infinite Universe
The discussion centers around the concept of how an infinite universe could expand. Participants explore the implications of infinity in relation to physical expansion, mathematical definitions, and conceptual models of space. The scope includes theoretical considerations and conceptual clarifications regarding the nature of the universe and its expansion.
  • Some participants question how something infinite can expand, suggesting that if the universe is already infinite, it cannot get bigger.
  • Others propose that the expansion of space refers to a change in the scale of space rather than a physical expansion into something else.
  • Mathematical and physical interpretations of "expansion" are discussed, with some noting that any finite subset of an infinite space can grow over time.
  • One participant uses the analogy of stakes in the ground to illustrate local detection of expansion, regardless of whether the space is finite or infinite.
  • Another participant introduces the idea that the universe could be spatially finite, but the concept of expansion remains the same in either case.
  • Some contributions emphasize the distinction between finite and infinite, suggesting that they are fundamentally different concepts in the context of expansion.
  • Participants discuss the implications of measuring distances in an infinite universe and the challenges of conceptualizing an "infinitieth" point or stake.
  • There are references to mathematical models, such as the FLRW metric, and the potential for a Riemannian metric to change over time, affecting how distances are measured.
Participants express a range of views on the nature of infinity and expansion, with no consensus reached. Some argue for the possibility of an infinite universe expanding, while others maintain that the concepts of finite and infinite are fundamentally different, leading to ongoing debate.
Limitations include the dependence on definitions of infinity and expansion, as well as unresolved mathematical interpretations of how expansion applies to infinite spaces.
alae
how could something infinite expand?
expandig mean geating bigger but if its already infinite how could it get bigger
Space news on Phys.org
Expansion of space means a change in scale* of space, rather than the image you might have of "something expanding into something else".
*(you marked this thread as "A Level", in which case the relevant ideas are that of e.g. the FLRW metric scale factor, the expansion scalar, etc., but I don't think these will be helpful ideas for you right now).
Mathematically and physically "expand" might mean that any finite subset gets bigger over time. The "size" of an infinite space may not be not well-defined in any case.
ergospherical said:
*(you marked this thread as "A Level"...).
Corrected.
Imagine a potato chip of unlimited size, like a hyperbola. Now forget about the surrounding space, the chip alone is all we have.
Plant a row of stakes in the ground. If the stakes move apart, the ground is expanding - something you can detect locally whether there's an edge to the ground or it's infinite.
Done! Can confirm that the ground is not expanding. However, the gardener looks pretty miffed. :oldeyes:
  • Haha
You have to measure it at night after the last call. The expansion rate is ##Pub(G)=\dfrac{\dot{a}(G)}{a(G)}## where ##a(G)## denotes the amount of Guinness that you have had.
  • Haha
Infinite is not a large number which means you can't calculate with infinite as it would be a large number. E.g. 5 times infinite is still infinite. So if you watch an expanding infinite rubber band at a certain place you see locally that distances are growing while the rubber band is and stays infinite.
This is an important point, OP. In my stakes in the ground example it's very easy to wonder what happens to the infinitieth stake, but you can't do that. Any stake you are thinking of is a finite numbered stake, and there are always infinitely many stakes beyond it. There is no "infinitieth" last stake in an infinite chain of stakes (the Lego Movie notwithstanding).
Also, Buzz Lightyear notwithstanding
User2022 said:
Maybe because it isn't infinite.
While it is possible that our universe is spatially finite, the meaning of "expanding" for the universe, and in particular the fact that it does not mean expanding into some pre-existing surrounding space, is the same whether the universe turns out to be spatially finite or spatially infinite.
Think of the universe being modeled mathematically by a pair ##(M,h)##. The first part is the space, which can be the Euclidean three dimensional space, so it is infinite in the sense that you think it is. The second part is a Riemannian metric, which is something that tells you how to measure distances and angles. It need not be the Euclidean metric that you know from school geometry. It also can change with time. For example if it is ##h## now, and it becomes ##3h## in a billion years, then all distances have tripled in that time. In this sense the universe have expanded, three times in the example.
fresh_42 said:
Corrected.
Imagine a potato chip of unlimited size, like a hyperbola. Now forget about the surrounding space, the chip alone is all we have.View attachment 297370
I've never seen a Pringle used as an example. 🤣🤣
Even if they expand by an extremely small rate, the "intfintieth" stake would be moving away, well, at infinite speed. Would it not?
  • Skeptical
No, it wouldn't. Not in any meaningful sense.
Ok, thanks. I'm still thinking on it as pertains to uniform expansion of space, i.e. the further the distance, the faster the recession.
Yes, but finite will never be infinite
There's no such thing as the infinitieth stake - that's the point. Any stake is a finite numbered one, with infinitely many stakes beyond it.
Well, I get that you can't pick one stake to be the "infinitieth", so perhaps talking about limits rather than discrete would be useful.
Sorry, I'm off topic. I guess this is one of the many questions related to what space expands "into".
You can talk about a stake arbitrarily far away from you, which is receding arbitrarily fast, yes. The next stake is receding faster and the recession rate grows without bound, yes.
No. Space could be finite and expanding but still not expanding "into" anything.
Understood, but I don't think the original question is vastly different.
Huh? They are about two radically different things. Finite and infinite.
Well, I don't find it hard to conceive of an infinite universe. For example, one could conceive of an observer at the distant edge of our observable universe. Should they not see a similar observable universe of the same size? And that can be carried out ad infinitum in a single direction. So I don't see much difference between a finite or infinite universe expanding.
I was not referring to the expansion but to the size. Finite and infinite just can't be much different.
Fair point. But what I mean is that either way, the frequent question is, again, what does the universe expand "into". Infinite or not.
I think that's best answered by pointing out the 4d nature of spaetime. "Space now" is a 3d slice through it. "Space a moment later" is a different 3d slice - so nothing is actually expanding. You're looking at different parts of spacetime with different scale factors.
  • · Replies 65 ·
10K
  • · Replies 22 ·
  • · Replies 28 ·
  • · Replies 20 ·
