How Do Black Holes Affect Photons and What Mysteries Remain?
This discussion centers on the interaction between black holes and photons, specifically addressing how black holes can affect massless particles like photons. Participants clarify that black holes do not attract photons in the traditional sense; rather, their immense gravity warps spacetime, causing photons to follow curved paths toward the black hole. The conversation also touches on the visibility of black holes, noting that they are observed indirectly through their accretion discs, which emit X-rays. Additionally, the notion of black holes as "anti-matter" is dismissed as an unconfirmed hypothesis.
  • Understanding of general relativity and spacetime curvature
  • Familiarity with the concept of relativistic mass and energy
  • Knowledge of black hole physics and accretion processes
  • Basic grasp of photon behavior in gravitational fields
  • Research the principles of general relativity and spacetime curvature
  • Study the concept of relativistic mass and its implications for massless particles
  • Explore the mechanisms of black hole accretion discs and their emissions
  • Investigate current theories regarding the nature of black holes and their relationship to antimatter
Astronomy enthusiasts, physicists, and students of astrophysics seeking to deepen their understanding of black hole dynamics and photon interactions.
dany74q
Hello everyone,
I have a question that bothers me quite some time now,and it would be great to get an answer.
I have been reading some time now about black holes,and photons,and how black holes attract photons and different theories says it can or cannot escape the black hole,and there`s some things that aren`t clear to me:
1.How can a black hole attract a massless particle?
2.How can we see the black hole if he "swallows" the photons ?
3.quite general - are black holes confirmed as "anti - matter" or is it an unconfirmed hypothesis?
So many thanks,
if the question is not appropriate to this section I would be grateful if one of the moderators could move it.
Danny.
Astronomy news on Phys.org
you can't see a black hole directly only by how it interacts on its surroundings and it dose not atract a particle the black holes immense gravity pulls it in
Thanks,though I`m still confused about the quoted sentence -
I understand that the high value force of black holes gravity pulls the photons in,but how it can affect the photons if they are massless ?
I know that when calculating the force of gravity between 2 objects when one of the masses valued zero (which it is in this case),the equation itself equal zero = no force applied on neither objects.
Am I not correct?
well if you believe in string theory they say graty may be causesd by gravitons and the transfer of these particle causes force if they somehow are transferred between photons you can see how gravity only depends on its mass by the amoput of particles available to give off gravitions
DavidSullivan said:
Photon have relativistic mass. See the FAQ here on the forum: https://www.physicsforums.com/showthread.php?t=104715
-David
Thank you for sharing that source,some very interesting FAQ.
Though if I understood correctly the formula,then their relativistic mass is also 0,
as m-rel = gamma * m0 (rested),as m0 equal zero then m-rel will be zero as well,
plus - if m-rel is "gain in mass" and equivalent to the value of the velocity increment it will always be zero with photons,as theoretically they move in the same velocity,
or maybe I understood it wrong?
Thank you so much for your answers,
I really appreciate it.
I don't know - I'm not a physicist and simple questions in physics seem always to have long and difficult explanations.
I found the explanation in the FAQ to be a good conceptual starting point and should narrow your search if you chose to continue digging.
Good luck!
-David
mass or energy creates a gravitational field as stated in relativity . we know that light has energy E=hf
A photon it self has its own gravitational field.
It doesn't. Gravity is not an attraction; it is a curvature of spacetime.
All massive objects - planets and BHs alike - warp spacetime. All objects - massive or massless - follow the curve of spacetime. Around a BH, spacetime is so curved that photons follow their straight path through curved spacetime to the BH.
We do not see a BH itself. But they tend to acquire an accretion disc of infalling matter. This matter gets compressed and shines brightly, especially in X-rays.
I know of no such hypothesis. Where did you read this?
  • · Replies 17 ·
  • · Replies 27 ·
