How Do Current Divider Rules Determine I1 and I2 in a Circuit?
10 replies · 3K views · last reply
DODGEVIPER13
Find the unknown current I1 and I2 in the circuit shown below. (Reference problem 7 on the PDF doc)
V=iR
i1=i(R4/(R12+R4))
i2=i(R12/(R12+R4))
I used V=ir where V=20v and R=2ohm so i=10A. Then plugging into i1 equation where R4=4 ohn, and R12=12 ohm. I get 2.5 A on i1 which makes sense because the resistance is higher and plugginf in i2 I get 7.5A again which makes sense because it has a lower resistance this also completes KCL rules. My question is did I do this right?
Hello it would not allow me to ask a second question using the same PDF so I figured I would ask a second on this post sorry if this is wrong.
Solve for the voltage Vx and ix?(Reference problem 8)
v=ir
0=i1+i2+3+...in
0=V1+V2+V3+...Vn
I suppose I am incorrect but this cirrcuit doesn't appear to be valid. When I do this 90V - 5A(8 ohm) = 50 volts. Then i10=50V/10 ohm = 5A well how can this be because due to KCL that would mean 5 amps and 5 out meaning no current would flow into the 4 ohm resistor. Ugh what have I done wrong.
The problems are separate from each other and both are on the PDF that was given
V=iR
i1=i(R4/(R12+R4))
i2=i(R12/(R12+R4))
The load that the 20V source sees is not just 2Ω, so your total current is not correct; the current that passes through the 2Ω resistor also must pass through the other resistors on its way back to the source. If you want to find the total current, you'll need to find the equivalent resistance presented by resistor network.
Circuit schematic with a 20 V source on the left in series with a 2 Ω resistor, feeding a node with a 12 Ω resistor down to ground and a 4 Ω resistor on the right branch; currents I1 and I2 are labeled downward through the 12 Ω and 4 Ω resistors.
  • Circuit schematic: a 20 V source on the left in series with a 2 Ω resistor, feeding a node that splits into a 12 Ω resistor and a 4 Ω resistor in parallel, with currents I1 through the 12 Ω branch and I2 through the 4 Ω branch.
Ahhh ok makes sense so when I put the 12 ohm adn 4 ohm resistor in parrallel and then in series with the 2 ohm resistor I will get 5 ohms which equates to a total aperage of 4 A. Then by me above equation for i1=1A and i2=3A. Is that correct?
Your result looks fine.
Ok thanks man do you think you could help with my second question I posted I know I prolly wasnt suppose to do that but it wouldn't let post two separate ones with the pdf.
There's nothing wrong with the circuit or your analysis so far. What does that tell you about the potential drop across the 4Ω resistor?
oh heck woops I get it now so it would be 50-0=50 volts then v=iR so i2=25A going out which means. 0=5-5-25+ix so ix=25A and Vx = 50 volts is that correct?
Yup. That's it.
