How do entangled particles know what the other is doing?
  • Thread starter Thread starter BadgerBadger92
79 replies · 12K views · last reply
BadgerBadger92
How do a pair of particles via entanglement “know” what the other particle is doing? Any help is appreciated.
There is no consciousness here (I would argue). The entangled particle are correlated.
I am curious about other peoples theories of how they remain correlated even when separated by billions of miles. Most of what I have read just says, they act "as one particle". But, this is not satisfying to me because typically part of one particle is proximate to the other part of the "same particle" (locality).
One thought I came up with (but, perhaps others have too) is the entangled particles retain their relationship to their underlying quantum field. As a result, they remain correlated even when separated by billions of miles.
But, if there is research into this that throws additional light, I am interested too.
"I think I can safely say that nobody understands quantum mechanics."
"in mathematics you don't understand things. You just get used to them.”
-- Richard Feynman
Mathematically, they are one entity. If you are given that ##x^2 = 1##, then you know that there are two solutions, ##1## and ##-1##. When you are told that one solution is ##x_1 = -1##, you know instantly that the other solution, ##x_2##, is ##x_2=-1##. And the value of either ##x_1## or ##x_2## are not determined until the other is.
That is not one causing the other, and it is not a case of a "hidden variable". Simply, knowing one tells you what the other is.
'In mathematics, you don't understand things. You just get used to them.'
Which he got from his good friend John von Neumann
The exact context and wording were 'Young man, in mathematics, you don’t understand things. You just get used to them.' John von Neumann, to Felix Smith
In answer to the original question, in Quantum Field Theory, two particles are a two-particle excitation of the field, not two single-particle excitations (which is a special case of a two-particle excitation).
Thanks
Bill
Likes   Reactions: Roberto Pavani, FactChecker, BadgerBadger92 and 1 other person
Thanks
Bill
Bill, any additional thoughts or articles on how quantum fields may explain (non-local) entanglement would be much appreciated.
I tend to suspect this is the case. But, I have not found much literature explaining non-local entanglement by referring to QFT.
To me (non physicist enthusiast in this area), it seemed to make sense, since quantum fields are considered infinite (or about as close to infinite as we can consider in the physical universe we inhabit).
Different QM interpretations give different (and incompatible) answers to this question.
Please do not venture into personal speculation.
Because quantum fields are fundamentally non-local objects. Which many would say is not really an explanation, just a restatement of the problem.
This is really a QM interpretation question, and as I commented in post #8, different intepretations give different and incompatible answers.
That's because QFT adds nothing useful to the treatment of entanglement, as far as making predictions goes, that's not already contained in the math of non-relativistic QM, and QFT mathematically is a lot more complicated.
The QM interpretation literature in general does not seem to pay any real attention to QFT, but uses non-relativistic QM as its framework. That's probably because most physicists working in the field believe that non-relativistic QM is a valid approximation to QFT for all known experiments in which entanglement is significant.
@bhobba has given references in other threads that show that that belief about approximation is not as simple as it looks. But it doesn't seem like the literature on QM interpretations and foundations has picked up on that.
  • Love
Just a small note: von Neumann was actually very interested in the foundations of QM (collapse postulate, hidden variables proof, etc.). His quote was more about developing intuition through practice, not about giving up on understanding.
For a field theory, there are, in the first instance, no particles to be entangled. The idea that each record of an event in a detector must be caused by a particle is sufficiently problematic that it ought not to be axiom #1 for QM (as a Hilbert space~a 'system', largely unchanged since von Neumann). Axiomatic forms of QFT make no such assumption, and there is a tradition of 'algebraic QM' for which the same is true.
Discussions of Bell inequalities all too often begin 'consider two particles', but Bell's article "The theory of local beables" began a tradition of field theoretical discussions, to which I contributed in JPhysA 2006, "Bell inequalities for random fields" (or on arXiv). My more recent discussions focus more on the nontrivial algebraic structure than can be found there (as in §7.2 of my AnnPhys 2020, "An algebraic approach to Koopman classical mechanics" (arXiv)), however it is still unclear to me exactly how field theoretic and algebraic considerations can best be melded.
My most recent attempt at a mixture of intuitive and formal discussion of what happens in an experiment that violates the Bell inequalities (specifically Gregor Weihs's Thesis experiment in the mid-90s) can be found in a video entry for a recent competition, "Explaining Quantum Field Theory as a Dataset&Signal Analysis formalism #CORE1" (starting at 1:21:29, for a little less than 20 minutes, slides 28-35). I believe it is essential to consider the internal degrees of freedom of the Electro-Optic modulators that enforce the detailed choice of polarization, not only the experimenters' binary choice of one of two orientations, which is natural in a field theoretic discussion but never enters into discussions of particles as causes of a violation of Bell inequalities.
I will offer below two slides from that talk for consideration. For the first slide, I emphasize in what I say that there are two reasons I particularly like Gregor's schematic of his experiment: 1) he says that the central source is a 'pump', so that instead of 'shoveling particles into the apparatus' I imagine Gregor modulating the noisy vacuum of the EM field elaborately enough that the experiment exhibits a violation of a Bell inequality; and 2) he presents explicitly what is stored in the experiment's datasets, which are exactly as one finds in the real data as I obtained them from him almost 20 years ago and for which I present a more explicit analysis than can be found elsewhere about such experiments, from the ground up, so to speak.
If we think in terms of particles, there are some aspects that fit so badly that the analogy is a mess, whereas I think a much better fit can be presented in a field theoretic discussion, which is why I have gone so far sideways from your initial question, @BadgerBadger92
[The complete slide set can be found here for a quick look instead of watching the video. A field theoretic discussion of QM/QFT is different enough from a discussion in terms of particles that it takes me 3h26m20s to give even a very incomplete account of how I think the pieces fit together.]
I apologize if my attempt here to thread between published work and more recent unpublished ideas has fallen too far on the wrong side.
I think I am saying the same thing Bhoppa is saying (and, I suspect, the book he linked). He said QFT treats two entangled particles as a single particle.
Since quantum fields are non-local (infinite, it is often said), the correlations within the two-particle structure remain even if they are billions of miles apart.
It follows that the two entangled particles have the same relationship to their underlying quantum field even if they are separated by billions of miles. This is basically saying the same thing.
This sounds to me like QFT nicely explains quantum entanglement, or least the "weird" part of quantum entanglement (non-locality).
Since quantum fields are non-local (infinite, it is often said), the two correlations within the two-particle structure remain even if they are billions of miles apart.
This sounds to me like QFT nicely explains quantum entanglement. (Or at least the reference to the non-local quantum field).
Art Hobson's "Fields and Their Quanta: Making Sense of Quantum Foundations" and his previous work, going back decades, has always seemed a little strange to me insofar as he advocates strongly for field theory but also talks a lot about particles. Although it can be helpful in elementary cases to talk about how particles (as localized systems) cause events, I find it's also helpful to back away from the assumption that events have simple causes a little more than he does. I think of a field theory as essentially introducing an infinity of incoming causes for every recorded event: which we can reasonably think is a massive overkill but which we can also think of as a natural consequence of saying "more than one" (if we subscribe to the saying "once is never, twice is always"). In field theory we sum over an infinite number of paths to obtain the S-matrix entries for each outcome for a given state preparation.
Measurements in quantum field theory are local in the sense of microcausality, so that we can collect data in multiple places that are space-like separated without considering measurement incompatibility, but recorded measurement outcomes are nonlocal in the sense that we can engineer correlations between those outcomes that are nontrivial at arbitrarily large space-like separation. Engineering such correlations at larger space-like separation does not have the same costs as at smaller space-like separation, however. We have to provide millions of miles of fiber optics, for example, with dispersion and absorption increasingly difficult to accommodate, or introduce increasingly elaborate corrections as free-space propagation is increasingly degraded by dust et cetera. Entropy rules eventually.
That said, discussing particle pairs instead of a pair of single particles can be made to work. The formalism for compound systems in terms of tensor products of Hilbert spaces works well, otherwise we would have moved on decades ago, but it requires even more elaboration when we have to introduce particle creation and annihilation to model more detailed effects. One guiding light for me is that when Feynman was not saying that “nobody really understands quantum mechanics,” he was, in contrast, saying, “The physicist needs a facility in looking at problems from several points of view” (I've lifted that from my article here.) I take that to heart when I say that when we can think in terms of particles without too many difficulties arising, we can and should do it, but when difficulties multiply, it can be worthwhile to take a step back into a field theoretic or more empiricist mindset.
Regarding Feynman's view of QM, just before he died, he attended a seminar by his friend (and the guy in the office next door), Gell-Mann, on Gell-Mann's decoherent histories approach. At the end, Feynman stood up, and everyone thought they were going to witness a ding-dong between the two greats. Instead, he said I agree with everything that was said, and left. So I think it's safe to say that was his final view of quantum foundations.
It has been discussed on this forum the difference between Many Worlds and Decoherent Histories. The bottom line was that MW, as presented by David Wallace in his book, The Emergent Multiverse, is, except for some semantic subtleties, basically the same as Decoherent Histories. That book also incorporates QFT in the interpretation. I would say for the advanced reader it is the best source I know of the modern view of QM.
Art Hobson's book is not the final word; some have issues with it. However, as a starting point for understanding QFT, it is the best source I know and a great place to start after a first course in QM, serving as a bridge into QFT for later study. The thing to realise is that ordinary QM does not require an interpretation, because it is wrong. It is only an approximation to QFT. This has been known for many years now, even at the dawn of QM, because it predicts stationary states for the hydrogen atom, so it can not account for spontaneous emission, as explained in one of my favourite papers I am referencing a lot lately:
https://digitalcommons.usu.edu/cgi/viewcontent.cgi?article=3211&context=physics_facpub
Thanks
Bill
No, that's not what he said. He said they are a two-particle excitation of a quantum field. That's not the same as a one-particle excitation of a quantum field.
Also, there are many kinds of excitations of quantum fields that do not have a "particle" interpretation at all. QFT does not treat "particles" as fundamental objects.
No, it's not. "Particles" are not things separate from quantum fields that have "relationships" to them. They are particular kinds of excitations of quantum fields. The quantum fields are the only "things" that are there.
It doesn't "explain" non-locality; it just says non-locality is a property of quantum fields. You still have to accept that quantum fields are fundamentally non-local objects (just like wave functions are in non-relativistic QM); there's no underlying "explanation" for the non-locality, it's just a brute fact.
  • Agree
  • Love
The only out, if an out it is, is that it is just a computational device. It still is non-local, but of no concern. For quantum fields, that is a difficult position to take (but likely still possible) if the 'disturbances' are real. Since the classical limit of QFT is not ordinary QM, it is possible to think of the state as just a calculational device implied by Gleason's theorem. I am not sure if it's just a fine point or important.
In ordinary QM, the reason for non-locality is modelling the possible outcomes of an observation as the eigenvalues of an operator, so Gleason's theorem applies. Then, as shown in Ballentine, QM basically follows, including Schrödinger's equation from Galilean invariance.
Thanks
Bill
For me, even just the "standard QM" way of expressing an entangled state as explicitly one that is not a simple tensor product state already gives rise to notions in my mind of non separability. Monistic views of the wave function (as championed in the Everettian view by e.g. Sean Carroll's statements "there is only one universal wave function") do not really "require" the QFT picture to be put forward. Hence, for me, QFT doesn't add too much to the picture in that sense. You just trade a non local wave function of particles for a non local wave function of fields.
I suppose I have tended view a central component of QFT the (assertedly) infinite (but at least, non-local) nature of quantum fields. So, once I bought into QFT, it did not seem "weird" to apply it to entangled particles.
I am curious if any cares to comment on this statement:
Because QFT requires that fields interact locally—meaning particles can only interact directly with things immediately next to them in spacetime—the theory itself is technically local. However, the quantum states generated by these fields can be massively non-local (entangled). Therefore, QFT accommodates non-local measurement outcomes without breaking the fundamental relativistic rule that information cannot travel faster than light.
What are these "things"?
The quantum states in QFT are of the field. So, I don't understand what is meant by quantum states generated by the field.
I'm not sure I ever read a relativity book or paper that would say "the fundamental rule in relativity is that information (in particular) cannot travel faster than the speed of light". How would one define "information" here? The entire causal structure of relativity is defined by the light cones.
Information that would allow clock synchronisation.
Thanks
Bill
Thanks
Bill
Could you elaborate the point? For example, when I read "the fundamental relativistic rule"... And then the definition you gave, am I to infer that you would agree with the statement "the fundamental relativistic rule is we may not synchronize clocks at space like separated points"?
I would certainly agree that such a thing is impossible in relativity. But I don't know if I agree that such a thing is "fundamental". I would think locality means a lot more than that.
Only if you think correlations that violate the Bell inequalities is of no concern. Which is certainly a possible point of view, but it doesn't appear to be a very common one.
Using such a method would violate the constant light speed in SR. Eddington showed the natural method of syncronysation, slow clock transport is equivilant to light signal syncronysation.
https://www.mathpages.com/home/kmath769/kmath769.htm
I agree it is a bit of a tricky issue in relativity that has been a point of discussion over the years.
If anyone wants to pursue it further:
Questions like this are why my preferred path to SR is based more on symmetry.
Thanks
Bill
Perhaps worth noting: the "information" that cannot travel FTL is not just the measurement outcome, it's the outcome plus its spacetime location. Alice may know what Bob would get, but not when or whether he measured. Without that classical side-channel (which travels at ≤ c), no usable information is transmitted.
What you are asking shouldn't possibly exist in a classical-physics universe. But science hasn't settled on a particular interpretation because such a one doesn't currently exist.
The quantum world is quite unlike the classical world. There is only fields. And the classical world appears from the quantum. Consistently and roughly predictably.
Aside from this, the strongest clue about what is going on comes from the violation of Bell's inequalities. The universe cannot be both local and having pre-existing properties and values. And most think certain of your intuitions about how the world works must be wrong.
And this is the best guess you will get.
It's work in progress.
Sorry, Peter, badly worded. I meant a concern as an actual physical process FTL.
Thanks
Bill
I wouldn't want to claim that the following is an 'underlying "explanation" for the non-locality', but quantum nonlocality can be thought of as similar enough to thermal nonlocality that I think they are only at a similar level of concern. [Also @bhobba.]
For a random field generally, there are nonlocal correlations at space-like separation in any thermal state. For the vacuum state of a quantum field there are also nonlocal correlations at space-like separation, but their characteristic difference (in terms of symmetry group properties) is that those 'quantum' nonlocal correlations are Poincaré invariant.
For a quantum field theory, furthermore, we can think of the Unruh effect as "the vacuum state Lorentz invariant 'quantum' noise in an accelerating frame of reference" ≃ "QFT's version of a thermal state", and I suppose that such an equivalence —merely through a change of coordinates— suggests that quantum noise and thermal noise cannot be all that different.
For a Gaussian Klein-Gordon QFT, we can explicitly compute the structure of a vacuum state and of a thermal state (as a thermal state appears in QFT) in terms of their 2-point VEVs, as
where the ##k_0## in the second line indicates a specific choice of time-like direction. For the traditional classical thermal state of the Klein-Gordon random field, which is also Gaussian, we take just the term of degree ##k_BT## in an expansion of the factor ##\coth(\hbar k_0/2k_BT)## and remove the ##\theta(k_0)## factor that projects to positive frequency components. Though it's not a very pretty article, I presented this mathematics in “A succinct presentation of the quantized Klein–Gordon field, and a similar quantum presentation of the classical Klein–Gordon random field”, Phys. Lett. A 338 (2005) 8–12 (arXiv).
If we accept that somewhat detailed argument, we can more intuitively just say that solutions of the heat equation are nonlocally dependent on initial and boundary conditions and that noise will in general introduce a nonlocality for which classical mechanics can be too naïve.
As well as considering the difference between thermal noise and quantum noise, we also have to consider the role of contextuality, which is modeled in quantum mechanics by noncommutativity of the measurement operators we use as mathematical models for the datasets we obtain from experiments. I have now been arguing for almost a decade (so not well enough, clearly) that contextuality can easily be added to classical mechanics by using the full power of the Poisson bracket to make classical measurement theory also noncommutative, which makes it as possible to model the violation of Bell inequalities using that more powerful version of classical mechanics as it is in quantum mechanics. That's a story that I present at some length in the video I linked to above, starting at 0:46:48, so I will not parade it here.
The correlations associated with "thermal nonlocality" can't violate the Bell inequalities, so no, I would not say they're "similar enough", since Bell inequality violations are the key issue that undermines intuitive "classical" explanations of the correlations.
