How do I Antidifferentiate e^r/2 using Integration by Parts?
  • Level: Undergrad
  • Thread starter afcwestwarrior
4 replies · 2K views · last reply
afcwestwarrior
how do i antidifferentiate that
I'm working on integration by parts problems and that little part of the problem has been bothering me, i figured that the indefinte integral would be the same but then my answer came out different
here's the whole proble, i know how to do these problems it's just that i forgot a lot of stuff about calculus and i just need to touch up on some things,
here's the problem if you want to get a clearer picture of it
∫re^r/2 dr
u=r dv =e^ r/2
du= dr v=? i just need to find v that's all
here's the formula for integration by parts just in case you forgot it
∫u dv= uv - ∫v du
So you need to evaluate [tex]\int e^{\frac{r}{2}}dr[/tex] correct?. You're aware that [tex]\int e^xdx = e^x[/tex] (plus a constant) correct? The connection between the two should be obvious... if not, make a substiution such as x=r/2.
ok, I'm aware of it, so when i make the substitution for x=r/2 what's next
