How do I apply the fundamental theorem of calculus?
5 replies · 2K views
ardentmed
Hey guys,
View attachment 2777I'm confused as to how these work. For instance, I'm assuming that the FTC must be used, where the formula used would be f(b)-f(a), correct?
If so, I got 4x^3 radical(2-x^4) -2 for the first one. The second one is 3x^2 (sin(x^3)) + sincosx * cosx.
Thanks in advance.
Let's take a look at the first one:
$$f(x)=\int_{-2}^{x^4}\sqrt{2-u}\,du$$
Let's define a function:
$$G(u)$$ such that $$G'(u)=g(u)=\sqrt{2-u}$$
Now, by the anti-derivative form of the FTOC, we know:
$$f(x)=G\left(x^4\right)-G(-2)$$
Now, differentiate both sides with respect to $x$, making sure to use the chain rule where applicable. What do you get?
I used v=2-u as the substitution and ended up getting (-2/3)(2- x^4 )^(3/2) + (2/3)(8)
Thanks.
Edit: Also, I got cos(cos(x)) - cos( x^3 ) for the second one.
Thanks.
You shouldn't need to use any substitutions or actually integrate. Let's look at:
Now, differentiating with respect to $x$, we get:
$$f^{\prime}(x)=G^{\prime}\left(x^4\right)\left(x^4\right)^{\prime}-G^{\prime}(-2)(-2)^{\prime}$$
Now, using the fact that:
$$G^{\prime}(u)=g(u)=\sqrt{2-u}$$
we obtain (recalling the derivative of a constant is zero):
$$f^{\prime}(x)=\sqrt{2-x^4}\left(4x^3\right)-\sqrt{2-(-2)}(0)$$
Simplify:
$$f^{\prime}(x)=4x^3\sqrt{2-x^4}$$
Try the second problem in the same manner and post what you get. :D
Simplify:
So 3x^2 (sin(x^3) + sin(cosx)sinx is what I computed for the second one after following your advice. Am I on the right track?
Thanks again.
Thanks again.
Good job! :D
I think you just have an extra bracketing symbol in there, but if you got:
$$g'(x)=3x^2\sin\left(x^3\right)+\sin(x)\sin\left(\cos(x)\right)$$
(which I think you did) then you are correct.
