How Do I Balance Forces and Torques in Static Equilibrium Problems?
This discussion centers on solving static equilibrium problems involving forces and torques, specifically in the context of a physics homework assignment related to rods and tension. Key equations include the sum of forces (ΣF = 0) and the sum of torques (Στ = 0). Participants emphasize the importance of selecting an appropriate axis of rotation and correctly identifying forces acting on the system. The consensus is that analyzing the system as a whole, rather than isolating individual components, yields clearer insights into balancing forces and torques.
  • Understanding of static equilibrium principles
  • Familiarity with torque calculations and the cross product
  • Knowledge of forces acting on rigid bodies
  • Ability to interpret and analyze free-body diagrams
  • Study the concept of torque and its calculation using the right-hand rule
  • Learn how to construct and analyze free-body diagrams for complex systems
  • Explore the implications of choosing different axes of rotation in static problems
  • Review examples of static equilibrium problems involving multiple forces and components
Students studying physics, particularly those tackling static equilibrium problems, as well as educators seeking to clarify concepts of forces and torques in rigid body mechanics.
vivekfan
http://www.physics.upenn.edu/~jrk/p101/Homework/hw7_sp09.pdf
Here is the link. I am having trouble with questions 8 and 9. I posted the whole link because these questions have a diagram that go with it.
Sum of F = 0
Sum of torque=0
Well, I just considered rod B, because that's what they asked about.
So the Forces there are:
The normal force from the wall
An upward force to keep it from falling
And the tension force acting downward on rod b.
But the problem is, then how will the horizontal forces balance? I think I'm definitely missing something.
When I did the problem going straight to the torques with these forces,
I chose an axis of rotation at a and plugged in the corresponding torques for the forces listed above, and I got answer c.
But I know I'm doing something wrong in the first part because my teacher said to always start with the forces and then pick the appropriate axis of rotation, but my forces don't make sense. Please help.
Sum of F = 0
Sum of torque=0
Perhaps the best approach is to examine the Torque about point B?
You have 2 forces to consider, since any forces along BC may be ignored because they have no moment arm through the pivot.
Then you should be able to write an equation for the projection of those forces to the x and y.
mg projects at BC*Cosθ
And the Tension in AC projects as T*BC*sinθ ... This means then that
T*BC*sinθ = mg*BC*cosθ
Since the Tension in AC at the wall is +x, then there must be a corresponding -x force at the wall at the pivot at point B.
Why would I make the axis of rotation B, if I'm trying to solve for the normal force exerted on B? And which forces would I use in each direction in writing the sum of forces. I don't think I'm really understanding...are you considering the whole system or just rod B?
The simplest solution would be to consider rods AC and BC along with the hanging mass alone. That way the forces exerted on the wall become apparent. Then sum the torques about A. This equation gives an immediate answer. Also, the answer C is correct. This is because reaction forces are always opposite the member force.
I can show you the working if you need.
So does this mean that in the x-direction, there is the normal force from the wall on A and a normal force on the wall on B, and in the y-direction, there is the rope tension and the vertical forces from rod A and B? So then if you consider A the axis of rotation, then there would be no need to consider torque from the normal force on A or the vertical force of A? So then the torques would only be from the normal force of B, the Tension in the rope, and the vertical force of B?
surely you meant to say horizontal but you are correct. Also you can do the same procedure at B to find the answer to #9
Edit: I misread there but since the vertical force at B is acting at the point you are summing the torques by, its distance is 0 and this does not show up
Why isn't the vertical force of B acting at point B...how is it acting at Point A?
You should review torques. When summing the torques about A, what is the perpendicular distance acting between the point A and the line of action of the vertical component of force B?
Oh, I am pretty sure I understand now. Because torque can only act perpendicular by the definition of the cross product, right?
Would you mind working the problem out, so that I can make sure my work is consistent? Thanks! I just want to make sure everything is correct, so that when I review, I can remember exactly what to do.
So I will sum the torques about point A and will use the scalar definition of torques which is the perpendicular distance from the axis of rotation. For simplicity I will denote B_x as the horizontal force at B.
\sum \tau =0
-lmg+dB_x=0
B_x=\frac{l}{d}mg
(use the right hand rule to find whether the moment is positive or negative)
\sum \tau =0
-lmg+dB_x=0
B_x=\frac{l}{d}mg
So, you always look at the perpendicular distance from the axis of rotation?
Thank you so much for all of your help! I really appreciate it.
Yes look for the forces acting perpendicular to your displacement (vector) or distance from axis of rotation (or whatever you want to call it) to make your life easier. If its not so simple, use the vector method with the aforementioned displacement vector crossed with the force
