How Do I Calculate Angle BAC if Angle CBA is 69 Degrees?
  • Thread starter Thread starter Natasha1
    Angle
To calculate angle BAC when angle CBA is 69 degrees, the discussion reveals that angle BAC is determined to be 48 degrees. The confusion arises from misinterpreting the marked angles, particularly regarding angle CBD. The inscribed angle theorem and properties of quadrilaterals inscribed in a circle are referenced to support the calculations. It is noted that the length of chord DA does not affect the solution for angle BAC. Ultimately, clarity is achieved by confirming that angle CBA is indeed the 69 degrees in question.
Natasha1
The diagram shows a circle with centre O.
A, B, C and D lie on the circumference of the circle. Work out angle BAC
Please see attached drawing which I have written my work (in colour).
Despite spending 1h on it I still can’t understand how to find angle BAC.
I found it! It’s 48 degrees
1) For a quadrilateral inscribed in a circle, the sum of opposite angles equals to 180 degrees.
2) Inscribed angle theorem
Likes Delta2
In that case BD would be parallel to BA which it is plainly not. There is a 48 degree angle where you've marked 58. I'm not sure we can solve for BAC since chord DA's length can be shrunk or stretched without materially affecting the rest of the given geometry. Sum of angles BAC and ABD should be 48 by exterior angle thm.
Not by moving A because that would change ABC, and if you move D then BAC doesn't change anyway.
How do you deduce that? I agree with 48 degrees.
Maybe I am misinterpreting the marked angles ? Why has the OP marked 58 degrees when the other 2 angles in the triangle are 63 and 69 degrees. I think the confusion arises because I thought (and it looks like the OP also initially thought) that the measure of angle CBD was 69 degrees. But now I see it's CBA which is 69 degrees. Then the 48 degree answer makes sense.
If a person thought CBD was 69 degrees, he/she would also mark CAD as 69 degrees as appears to be the case.
Yes.
  • · Replies 22 ·
