How Do I Calculate the Correct Percent Composition of Oxygen in a Compound?
  • Thread starter Thread starter limofunder
    Composition
The discussion focuses on calculating the percent composition of oxygen in a compound consisting of SiO2, Na2, K2O, and PbO. The correct approach involves using the molar masses of each oxide to determine the mass of oxygen contributed by each component. The user initially miscalculated the total oxygen percentage, resulting in an incorrect value of 141%. The correct method is to assume a total mass of 100 g for the compound and calculate the grams of oxygen based on the proportions of each oxide.
  • Understanding of stoichiometry
  • Familiarity with molar masses of compounds
  • Basic knowledge of percent composition calculations
  • Experience with chemical formulas and their interpretations
  • Learn how to calculate molar masses of compounds
  • Study percent composition calculations in chemistry
  • Explore stoichiometric conversions in chemical reactions
  • Review the principles of mass conservation in chemical compounds
Chemistry students, educators, and anyone involved in chemical analysis or laboratory work who needs to calculate the percent composition of elements in compounds.
limofunder
I am running an experiment in which I have a compound of SiO2 Na2 K2O PbO I am trying to figure out the percent composition of oxygen given that the percent composition of the compound is:
46% SiO2
5% Na2
4% K2O
and 45% PbO
46% SiO2
5% Na2
4% K2O
and 45% PbO
So I figured given the previous percentages, the compound is made of
.46 SiO_2 * \frac{2 mol O }{1 mol SiO_2} + .04 K_2O * \frac{1 mol O}{1 mol K_2O} + .45 PbO * \frac{1 mol O}{1 mol PbO} = .46*2+.04+.45 = 1.41
but this gives me 141% oxygen composition, what am I doing wrong here? Its been a while since I took general chem (about 3 years ago) and my stoichiometry is not at its best right now.
would it be more correct to say that the percent composition of oxygen is:
0.46* \frac{2}{3}O + .04* \frac{1}{2}O+ 0.45* \frac{1}{2}O
= .5516 = 55.2%?
or would it be easier if I do the calculation by breaking it down into atomic masses, add the total of oxygen mass divided by the total mass of the compound?
thanks fellas, once again, couldn't have done it without yall.
You are adding apples and oranges. Each of these oxides contains different amount of oxygen (mass of oxygen per mass of the oxide), you can't add them this way. As you have already (and correctly) noticed, that gives idiotic results (percentage above 100%).
Your last approach is correct. Think this way: SiO2 is 46% of the substance. Assume you start with 100 g of the substance. How many grams of SiO2? How many grams of O in these grams of SiO2? (That's where the molar masses come into play).
16K
  • · Replies 18 ·
