How do I calculate the length of a chemical bond?
The discussion focuses on calculating the length of a carbon-carbon bond in the molecule C6H8, specifically 1,3,5-hexatriene. The method involves treating the valence pi electrons as particles in a one-dimensional box, using the energy level equation E = n²h²/(8mL). The transition from the third to the fourth energy level, triggered by the absorption of ultraviolet light at a wavelength of 357 nm, allows for the calculation of the bond length. By determining the energy of the transition using E = hc/λ and solving for L, the bond length can be approximated by dividing L by 6, given the equivalence of the carbon atoms.
  • Understanding of quantum mechanics principles, specifically energy levels and electron behavior.
  • Familiarity with the concept of particles in a one-dimensional box model.
  • Knowledge of the Bohr radius and its application in atomic calculations.
  • Basic understanding of light absorption and its relation to energy transitions.
  • Learn about the one-dimensional particle in a box model in quantum mechanics.
  • Study the relationship between wavelength and energy using E = hc/λ.
  • Explore the concept of conjugated systems and their electronic properties in organic chemistry.
  • Investigate the significance of energy level transitions in molecular spectroscopy.
Chemistry students, particularly those studying quantum chemistry and molecular structure, as well as researchers interested in the properties of conjugated organic compounds.
fizzicsdummy
“In C6H8, the carbon atoms are connected in a chain. In a rough approximation, some electrons can be viewed as confined to a line with the length of this chain. C6H8 absorbs ultraviolet light with wavelength 357 nm, which causes an electron to change from the third lowest allowed energy to the fourth lowest allowed energy. Use this information to estimate the length in pm of a typical carbon-carbon bond in C6H8.”
I do know that radius = (n^2)(Bohr radius).
I assume I could just calculate the radius of a carbon atom and multiply it by 2 to find a rough estimate of the length of a carbon-carbon bond. However, I don't know how to do this and I don't know the importance of the energy level change described in the problem. I'd really appreciate help understanding this. An equation (if one exists) would also be appreciated. Thanks!
This is a popular question that comes up in intro quantum chem classes. The idea here is to take your conjugated 1,3,5-hexatriene molecule and approximate its valence pi electrons (very roughly) as particles in a 1D box of length L. The energy levels are
$$E = \frac{n^2h^2}{8mL}$$
and the hexatriene molecule has 6 conjugated pi electrons. Given the fact that electrons are fermions, this means the lowest 3 levels of the box are filled, so the first electronic transition possible is between the 3rd and the 4th level. You're told that the molecule absorbs light at ##\lambda## = 357nm, which you can plug into
$$E = \frac{hc}{\lambda}$$
to find the energy of the transition. You can then find the difference of energy between the 3rd and 4th box levels and solve for L to get the total length of the box. Since all 6 carbons are (very roughly) equivalent, you can divide this L by 6 to get the C-C bond length.
36K
20K
11K
16K
