How do I compare specific heat capacity between two spheres?
4 replies · 2K views · last reply
fabrc
How do I know which one of these two spheres have more specific heat capacity?
  • Diagram of a transparent box containing ice labelled Gelo, with a copper sphere labelled Cu and an aluminium cylinder labelled Al placed on top of or inside it.
First, I am afraid you are gluing the words of two different concepts...probably because they are directly related, but you need to keep in mind that they are two separate concepts.
To be sure, there is no "Specific Heat Capacity"; instead, you have two concepts:
"Specific Heat", this is a property of matter.
"Heat Capacity", this is an attribute on an object that depends on its "specific heat" and on its mass.
Once you understand these two concepts and how they relate to each other (go back to read the textbook or google...I got a few links right away), you should be able to explain what experiment you can do to answer the correct question.
I googled it, as you suggested. This is the first link: http://en.wikipedia.org/wiki/Heat_capacity
Taken from the second paragraph on that page: '. . . and the specific heat capacity, often simply called specific heat, is the heat capacity per unit mass of a material.'
If you take the question at face value... The specific heat capacity depends only on the material the sphere is made of and that's stated on the image.
However I suspect there is more to the question.
