How do I compute jerk in 2D space for a mouse tracking task?
YoYojimbo
Hi everyone,
I am a graduate student in psychology and am working on a research project where I am trying to derive the kinematics of a mouse tracking task. I am currently writing a MATLAB script to do this, and I believe my equations for velocity and acceleration are correct, but I have very little background in physics/calculus and am having difficulty computing the 3rd derivative of position, jerk. I know this forum is for high school/undergraduate level students, but I believe this question is too simple to post in the other forum.
1. Homework Statement
I have calculated the euclidean distances between all xy samples and determined the sum of the euclidean distances to determine displacement for the entire movement and the displacement between each pair of xy coordinates.
With displacement:
I have calculated the average velocity with the formula "sum of euclidean distance/total time of movement.
I have calculated the velocity profile using the the euclidean distances between each pair of xy coordinates divided by the sample rate (the time between each sample, so .5ms).
In regards to calculating acceleration, I have used the same formulas as above, but replaced displacement with velocity (the rate of change of velocity)
However, in regards to jerk (the rate of change of acceleration), I am trying to make sure I am calculating this correctly. I keep finding different formulas, but I am not certain all of them apply to 2D kinematics. If jerk is the rate of change of acceleration, am I wrong in thinking it can be calculated by acceleration divided by the time between each xy coordinate pairs?
I think my main issue is digesting the formulas. I have read quite a bit about calculating the derivatives of position, but with my limited understanding of physics, it is difficult to determine if the formulas are applicable to above mentioned 2D coordinate plane situation.
I really appreciate the any advice/help anyone can offer!
Best
The only difference between 2D and "1D" Kinematics is you have x and y components. So anything that applies to 1 dimension should easily apply to 2 with the help of a little trig and geometry. What different formulas are your getting?
Hi,
Thank you for the reply! I am using the following formulas.
Equation v = d/t, with v on the left and a fraction d over t on the right, shown in a bold serif font.
Red text equation: Average Velocity = (A position / time) = (displacement / time), with "A position" struck through and "displacement" written above "time" in the second fraction.
Textbook excerpt giving the average acceleration equation, Ave. acceleration = change in velocity / time = (v_f - v_i) / t, and a worked example a = (50 m/s - 0 m/s) / 5 s = 10 m/s/s.
Here are the jerk formulas
Equation: vector j = d(vector a)/dt = d^2(vector v)/dt^2 = d^3(vector r)/dt^3, with the vector arrows over j, a, v and r and the derivative orders shown as superscripts.
I assume this is the same as above
Equation: jerk vector j(t) equals the time derivative of acceleration, which equals the dot notation a-dot, which equals the second derivative of velocity, the double-dot v, which equals the third derivative of position, the triple-dot r(t).
Those are the formulas I have found. The rest of the confusion comes from journal articles talking about jerk of arm movements. I am not sure if that is applicable to my situation. Does it seem like my thinking about the variables is correct?
Thank you.
  • Equations defining jerk as the time derivative of acceleration and of velocity, with vector notation: j = da/dt = d(a)/dt, then the second and third derivatives of velocity and position with respect to time.
YoYojimbo said:
Hi,
Thank you.
That all looks ok, though I advise caution when dealing with real data. Each step in the differentiation chain can turn small errors into larger ones. You could apply some smoothing, but if overdone that will understate the values. You need to be aware of the precision of the original data and what that says about the answers.
You mention conflicting information regarding jerk of arms, but don't indicate what the conflict is. Is it possible those are not using "jerk" in this formal sense?
