Live4eva_2
- Messages
- 28
- Reaction score
- 0
[SOLVED] Java LinkedListNode class
Hi..
I'm trying to understand a generic linked list...in Java.
I understand that I should have a LinkedList class containing a Node class.
The Node class should have an info variable and a link variable.These variables should be accesessed through the .dot operator.
Now my book has a huge chapter on it,but unfortunately introducing generics and Linked Lists with a million different interfaces isn't much use to a noob.
My biggest problem seems to be in understanding how a node is inserted into the list.
For example the book shows a Node constructor having the following parameters:
(T elem,LinkedList<T> ptr)...I understand that T can be anything except primitive type parameters.But what I don't understand is in what context will this method be used??
Most likely we will be required to squash an array of Integer or String values into a linked list...So assuming that I have this : Integer[] anArray={1},{2},{3},{4}
How would I go about constructing nodes with these values...The constructor has a parameter,LinkedList<T> ptr.Where am I intended to get this reference variable from.
Hi..
