How do I find rotational energy for a pulley system?
The discussion centers on calculating gravitational potential energy (GPE), translational energy, and rotational energy for a pulley system involving a 0.2 kg mass and a 0.25 kg wooden block. The GPE is correctly calculated as 1.5 Joules using the formula GPE = mgh. The translational energy calculation is incorrect; it should be 0.5 * 0.25 kg * (0.92 m/s)^2, which equals 0.11 Joules. The participants clarify that the pulley has rotational energy if it has mass, and the moment of inertia (I) can be calculated as I = 0.5 * M * R^2, where R is the radius of the pulley (0.02 m). The discussion emphasizes the importance of knowing the mass of the pulley to accurately compute its rotational energy.
  • Understanding of gravitational potential energy (GPE) and its formula: GPE = mgh
  • Familiarity with translational kinetic energy and its formula: KE = 0.5mv^2
  • Knowledge of rotational dynamics, specifically moment of inertia (I) and angular velocity (ω)
  • Basic principles of pulley systems and their mechanics
  • Learn about calculating rotational energy in systems with mass, focusing on the formula: Rotational Energy = 0.5Iw^2
  • Study the effects of friction in pulley systems and how it impacts energy calculations
  • Explore the concept of angular momentum and its relation to rotational motion
  • Investigate the role of mass distribution in determining the moment of inertia for different shapes
Students studying physics, particularly those focusing on mechanics, as well as educators seeking to clarify concepts related to energy in pulley systems.
Preptopro
So I have a horizontal pulley positioned at the edge of table with a mass of .2kg hanging down from a height of .76meters, the other end of the string is attached to a wooden block of mass .25kg that when the .2kg weight is dropped the wooden block is pulled towards the pulley .8 meters at a velocity of .92m/s. Now I need to find the GPE, translational, and rotational energy of the system. The objective is to have all 3 types of energies in the system.
GPE = mgh
Translational energy= .5mv^2
Rotational energy = .5Iw^2 ?
GPE would just be (.2kg)(9.8m/s^2)(.76m) = 1.5 Joules right?
Translational energy = .5(.25kg)(.92m/s)= .11 Joules, this doesn't seem right I'm guessing I have to account for friction or something else? Any ideas?
And for Rotational energy I have no idea where to begin, I is .5MR^2 and then since w is (v/r) does that mean I could use .5(.5MR^2)(w^2) which is .25(MR^2)(v/r)^2 and then simplifying further it'd be .25(M)(v^2)? Am I on the right track?
Someone else I asked said that this does not even have rotational energy, so I'm very lost and I'd greatly appreciate any input! Thank you very much!
Yes.
They were wrong. Often, pulleys will be assumed to be ideal without mass and, consequently, with zero moment of inertia, leading to zero rotational energy. But if the pulley is massive and rotates with the string, then it will have rotational energy.
This is not at all clear.
The pulley is on a horizontal axis, yes?
Is the wooden block initially resting on the floor, more than .76m below, but the .2kg mass is dropped from table height? And the .2kg mass falls .76m before the string becomes taut? If not, I don't understand the rest of the question.
Since no mass or radius is given for the pulley, you have no way to take the pulley's rotational inertia into account, so you should probably treat it as massless. (But the question ought to make this clear.)
I apologize, what I meant was that the pulled is hooked on the edge of a table and the wooden block is .8meters away from the edge of the table where the pulley is positioned, the wooden block is initially .8meters from the pulley and the .2kg mass is dropped from the table height or .76meters so when the .2kg mass is dropped the wooden block slides across the table .8 meters to the point of the pulley at a velocity of .92m/s. The radius of the pulley is .02meters and its mass is not known but assuming that I did know it, how would I go about finding the rotational energy then? and I apologize again, this is my first time dealing with pulleys.
Ok, that's clearer.
.92m/s is the speed when it reaches the pulley, yes? What else is moving at that time? (You should consider the moment before the mass reaches the floor.)
You do not seem to have executed the limear KE formula correctly.
If there is both frictional loss and rotational energy in the pulley then you do not have enough information.
haruspex said:
Ok, that's clearer.
Yes correct .92m/s is the speed when the wooden block reaches the pulley.
The .2kg mass is also falling down at that time, do I need to calculate the the speed at which it falls? and if so how?
How can I correct this then?
I do not really have much prior experience with rotational kinematics or with pulleys really, and I've just started learning physics so I apologize if I seem really lost because I sort-of am
Yes. Is the string changing length during the fall? What does that tell you about the relative speeds of the two objects?
You correctly quoted the linear KE as ##\frac 12 mv^2##, but you seem to have forgotten to square the velocity in the calculation.
  • · Replies 21 ·
