How do I find the tangent to this parametric curve?
The discussion focuses on finding the tangent line to the parametric curve defined by the equations x = (t^3) - 3t and y = (t^2) - 5t at the point where t = 4. To find the tangent line, the slope is calculated using the formula dy/dx = (dy/dt)/(dx/dt), resulting in m = (2t - 5)/(3t^2 - 3). The participants clarify that the values of t for horizontal and vertical tangents can be determined by analyzing the slope's behavior.
  • Understanding of parametric equations
  • Knowledge of derivatives and their applications
  • Familiarity with the concept of slope in calculus
  • Ability to manipulate algebraic expressions
  • Calculate the slope of the tangent line at t = 4 using the derived formula.
  • Determine the coordinates of the point on the curve at t = 4.
  • Identify the conditions for horizontal and vertical tangents by setting the slope to zero and undefined, respectively.
  • Explore further applications of parametric equations in calculus.
Students studying calculus, particularly those focusing on parametric equations and tangent line concepts, as well as educators seeking to clarify these topics for their students.
Randall
Let C be the curve given parametrically by x = (t^3) - 3t; y = (t^2) - 5t
a) Find an equation for the line tangent to C at the point corresponding to t = 4
b) Determine the values of t where the tangent line is horizontal or vertical.
slope = d/dx of f(x,y)
equation of a line: y-y1 = m (x-x1)
see attached - I know I need to solve for t, but I don't know how with these seemingly unsolvable equations because there is a t^3 and a t = 52 in the first equation and a t^2and a t = -4 in the second equation. Please help thanks!
slope = d/dx of f(x,y) View attachment 76854
It's not clear what your confusion is here. No, you don't need to solve for t; you are given the value of t for the point C on the curve. (Hint: t = 4)
For a) You have calculated an expression for dy/dx in terms of t. Use the given value of t to find the equation of the tangent line at C.
For b) For what value of m is the tangent line at C horizontal? For what value of m is the tangent line at C vertical? What are the values of t which give these two values of m?
I guess I'm not clear how to go about solving this problem then. Can you help me choose the correct procedure for finding the equation of the line tangent to the curve? Don't I have to take the derivative or something somehow? I'm not clear on what to do...
You've already determined dy/dt and dx/dt using the parametric equations of the curve. The slope of the tangent line is
m = dy/dx = (dy/dt) / (dx/dt) = (2t - 5) / (3t2 - 3)
You are given that t = 4 at point C. What is the slope of the tangent line at point C? [Hint: Plug and chug.]
As to the rest of the equation for the tangent line, once you have calculated m, you need one point (x,y) on the line to complete it. You can obtain the (x,y) of point C by using the parametric equations for x and y, knowing that t = 4 at point C.
This is not a difficult problem. It's intended to show you how to work with parametric expressions instead of directly with x and y.
