How do I find where (4 - 4x²)/(x² + 1)² > 0?
10 replies · 4K views · last reply
mathdad
How do I find the range of [(4 - 4x^2)/(x^2 + 1)^2] > 0 algebraically?
Do I set the numerator to 0 and solve for x?
Do I set the denominator to 0 and solve for x?
You want that the fraction is greater than zero.
A fraction is positive either when both numerator and denominator are positive or when both are negative.
In this case the denominator is positive for each $x$. So, you have to find for which values of $x$ the numerator is also positive.
Are you saying to find the range I must set the numerator to = 0 or do I set the numerator > 0 and then solve for x?
We want to find the values of $x$ that satisfy the inquality $\frac{4 - 4x^2}{(x^2 + 1)^2} > 0$.
When we multiply both sides of an inequality by a negative number, the direction of the inequality changes ("<" becomes ">" for example).
In this case $(x^2 + 1)^2$ is always positive. So, multiplying the inequality by $(x^2 + 1)^2$ the direction of inequality does not change.
So, we have the following: \begin{align*}&(x^2 + 1)^2\cdot \frac{4 - 4x^2}{(x^2 + 1)^2} > (x^2 + 1)^2\cdot 0 \\ & \Rightarrow 4 - 4x^2> 0 \end{align*}
We have to solve the last inequality for $x$ to find the desired values of $x$.
Are you saying that solving the last inequality for x will yield the range of the original inequality? I am trying to find the range.
Okay, then, what do you mean by "range" of a rational inequality? Normally, "range" refers to the set of all values of a function, but an inequality is not a function. Mathmari has told you how to solve the inequality- to find all values of x that satisfy the inequality. Is that what you mean by "range"?
Again, I found this question online and posted as typed.
- - - Updated - - -
At another math site, someone responded by saying that the domain is (-infinity, infinity) and the range is [(-1/2), 4].
How is this found? Is this correct? If so, why?
RTCNTC said:
...At another math site, someone responded by saying that the domain is (-infinity, infinity) and the range is [(-1/2), 4].
Consider:
$$f(x)=\frac{4-4x^2}{\left(x^2+1\right)^2}$$
By looking at the above function definition, we can see that no real values of $x$ can cause $f$ to become undefined or complex, and so we may state that the domain is:
$$(-\infty,\infty)$$
To find the range, let's arrange the definition as follows:
$$fx^4+2(f+2)x^2+(f-4)=0$$
Hence:
$$x^2=\frac{-2(f+2)\pm\sqrt{4(f+2)^2-4f(f-4)}}{2f}=\frac{-(f+2)\pm2\sqrt{2f+1}}{f}$$
Now, we know:
$$0\le x^2$$
Thus:
$$0\le\frac{-(f+2)\pm2\sqrt{2f+1}}{f}$$
If we consider the case where $0<f$, then we must have:
$$f+2\le2\sqrt{2f+1}$$
$$f^2-4f\le0$$
$$f(f-4)\le0$$
So, we find:
$$0<f\le4$$
If we now consider the case where $f<0$, then we observe that the radicand cannot be negative:
$$2f+1\ge0$$
$$f\ge-\frac{1}{2}$$
And so, putting these together, we obtain:
$$-\frac{1}{2}\le f\le4$$
MarkFL said:
Consider:
Hence:
Now, we know:
$$0\le x^2$$
Thus:
$$f^2-4f\le0$$
$$f(f-4)\le0$$
So, we find:
$$0<f\le4$$
$$2f+1\ge0$$
You are amazing. Thank you. Thank you also for being patient with me.
Yes, MarkFL is amazing! And do you realize that your problem, as originally stated, to find the range of [(4 - 4x^2)/(x^2 + 1)^2] > 0, is NOT the same as the problem MarkFL solved, finding range of the function, f(x)= [(4 - 4x^2)/(x^2 + 1)^2]?
HallsofIvy said:
Yes, MarkFL is amazing!...
Aw...shucks. (Blush)(Worried)
