How do I get water vapor fraction and pressure?
The discussion focuses on calculating the vapor fraction and pressure of water in a thermochemical heat storage device using Matlab. The user seeks an empirical function or a comprehensive table for vapor fraction based on known parameters such as temperature (50°C - 500°C) and pressure (1-20 atm). A suggestion is made to utilize steam tables, which provide the relationship between pressure, temperature, and vapor content. Additionally, basic physics principles involving force and area are mentioned as a means to understand pressure changes when water is removed from the system.
  • Understanding of thermodynamics and steam tables
  • Familiarity with Matlab for numerical simulations
  • Basic physics concepts, including force and pressure calculations
  • Knowledge of thermochemical processes involving zeolites
  • Research steam tables for water to find empirical data on vapor fraction
  • Explore Matlab functions for thermodynamic calculations
  • Study the principles of thermochemical heat storage systems
  • Learn about pressure differentials and their impact on vapor states
Engineers and researchers involved in thermochemical systems, Matlab users developing simulations, and anyone interested in the thermodynamics of water vapor behavior in heat storage applications.
jason_85
Hi Guys,
I'm building a numerical Matlab simulation of a thermochemical heat storage device (using zeolites), and need to update the state of water vapor in the device at every time step. My question is, if I have an empty space with water in it, with temperature, pressure, density, etc. all known, how can I get the vapor fraction and pressure of that same boiler after removing x kilograms of water from it (and not replacing it with anything)?
The temperature range is about 50°C - 500°C and pressure should be between 1-20atm.
Ideally, I would love to get an empirical function for Vapor fraction of water - or at least a comprehensive table I can index in my simulation, so far I haven't been able to find anything myself.
Help would be greatly appreciated!
jason_85 said:
Hi Guys,
I don't really know the answer but maybe I can kind of give you some hints.
pressuve= force/area
force= Newton
if you are going to multuply you kilograms by 9.81m/s2(squered)= gravity, you are going to get Newtons.
if you are going to get rid of watter you are going to increase steam space (area).
so maybe using this somehow u can determin pressure differential.
Forse= Newton= kg x gravity.
from there you can maybe determin how mutch steam you got. that all will be under constant temperature.
I just started 4th class power engineering so I am not really sure what I am talking about.
when I will finish first year I will help out more.
Code:
by using steam table you can know the pressure on water and its corresponding temperature and amount of vapor generated.
you can find steam table on most thermodydamic books.
  • · Replies 0 ·
10K
