How do I iterate and enter values from a mapped entrySet into an array?
  • Topic: Java
  • Thread starter Thread starter iamjon.smith
    Java
1 reply · 5K views · last reply
iamjon.smith
Using the following code:
Code:
Set<Map.Entry<String,JsonElement>> mySet = jsonObject.entrySet();
for(Map.Entry<String,JsonElement> singleItem : mySet)
	singleItem.getKey();
	System.out.println("Set values: " + mySet);
mySet gets printed to the console as:
Code:
Set values: [columnGridContainer="[[1,\"1\",\"Default Value\",\"Y\",\"N\",\"0\",\"Left\",\"Default Value\",\"Default Value\",\"Default Value\",\"Default Value\",\"Left\",\"Center\",\"Center\",\"Center\",\"#000056\",\"None\",\"Date/Time\",\"No Filter\",\"N\"]]", header_row_2_enabled="Y", header_row_3_enabled="Y", header_row_4_enabled="Y", col_widths_units="pixels", default_sub_rows_closed="Y", extjs_component="grid", refreshrate="181", title="everything works right", subtitle="except display for checkboxes...", autoheight="N", bottom_buttons="N", col_label_source="col_config_table"]
I need to iterate through the values and put them into an array. Please provide some direction as to how to iterate over this mapped entrySet and enter each value into an array.
You are printing out the whole set in your for loop, don't you want to look at each item? Like this:
Code:
System.out.println("mySet as 'key : value'");
	System.out.println(singleItem.getKey() + " : " + singleItem.getValue());
