How do I numerically find eigenvectors for given eigenvalues?
6 replies · 19K views
hkBattousai
My aim was to numerically calculate eigenvalues and eigenvectors for a square A matrix.
I managed to find the eigenvalues by using QR algorithm. Now, I can find all of the eigenvalues for any given square matrix. But, for the next step, how do I find the corresponding eigenvectors? Is there any numerical method which calculates the eigenvectors for given eigenvalues?
Please guide me.
You write out the eigenvalue equation and find the vector that satisfies it for each value.
If [itex]Av_i = a_iv_i[/itex] for the ith eigenvector, then solve [itex](A-Ia_i)v_i = 0[/itex] normally.
Your idea was very useful, but I found an alternative solution (page 18).
The algorithm:
[itex]S_0=Q_0[/itex]
[itex]Defactorize: \, A_n=Q_nR_n[/itex]
[itex]A_{n+1}=R_nQ_n[/itex]
[itex]S_{n+1}=S_nQ_n[/itex]
As the algorithm converges, [itex]A_n[/itex] become a diagonal matrix, whose diagonal elements give the eigenvalues. And the column vectors of [itex]S_n[/itex] gives the corresponding eigenvectors.
This is an implementation example:
Code:
template <class T>
void Matrix<T>::GetEigens(std::vector<T> & EigenValues, Matrix<T> & EigenVectors) throw(MatrixNotSquare)
	// Initializations
	Matrix<T> A = *this, Q, R;
	if (!A.IsSquare()) throw(MatrixNotSquare(L"The matrix must be a square."));
	EigenValues.clear();
	EigenVectors = Matrix<T>(m_unRowSize, m_unColSize);
	// Find eigenvalues and eigenvectors
	A.QRDecomposition(Q, R);
	A = R * Q;
	EigenVectors = Q;
	for (uint64_t i=0; i<ITERATIONS; i++)
		A = R * Q;
		EigenVectors *= Q;
		if (A.IsDiagonal()) break;
	for (uint64_t i=0; i<A.GetRowSize(); i++)
		EigenValues.push_back(A(i, i));
This code is running successfully and giving correct results. A sample output is attached.
Yep - the algorith does what I described.
When you asked for a numerical method, you failed to specify your constraints.
Most programming math libraries have a defined function to find the eigenvalues and eigenvectors of a matrix.
For gnu-octave, there is a built-in function:
Code:
[b]Loadable Function: [V, LAMBDA] = eig (A)[/b]
     The eigenvalues (and eigenvectors) of a matrix are computed in a
     several step process which begins with a Hessenberg decomposition,
     followed by a Schur decomposition, from which the eigenvalues are
     apparent.  The eigenvectors, when desired, are computed by further
     manipulations of the Schur decomposition.
     The eigenvalues returned by `eig' are not ordered.
I used to use this to solve the Schrödinger equation in 1D.
Another approach is to use singular value decomposition. It's a beast to program, but because it is so very handy (so very, very, very handy), someone has inevitably done it for you already. Pick a language / tool and you will almost certainly find an SVD implementation -- even if you use a language such as Visual Basic and Cobol that is hardly ever used for scientific programming.
In practice that may be a slightly recursive answer, because the a popular way to calculate the singular values and vectors is actually using QR (adapted to solve that specific problem, of course).
(But D.H. is right that the easy answer to most "how to" questions in numerical linear algebra starts "First find the SVD.")
If you know an eigenvalue, the simplest way to find the vector is to use inverse iteration (a.k.a. the inverse power method with shifts) which will converge in one interation because you already know exactly what shift to use.
On the other hand for finding a few eigenpairs of a large matrix the most popular methods iterate to find the eigenvectors, and the eigenvalues are then be found from the Rayleigh quotient [itex]x^T A x / x^T x[/itex]. But a "goto" method like Lanczos iteration is also a beast to program so it works reliably in practice, even though the math looks deceptively simple.
eg. http://www.mathworks.com/help/techdoc/ref/svd-singular-value-decomposition.html .
There are libs for major programming languages and math scripts which provide all these methods.
In the QR method - the eigenvectors are the product of the orthogonal transformation in each iteration. Which is what the Olver (example code post #3) paper does.
