How do I proceed with two different trig functions containing x on the left?
8 replies · 2K views · last reply
DerbisEternal
The problem is this: two 10 g balls hang from 1 m strings attached to the same point on the ceiling. They are both charged with 100 nC. What angle are they separated to?
Fe=(k*q1*q2)/(r^2)
Given the total angles in the x direction, I set up this:
(mg/cos(x))*sin(x)-Fe=0
then isolated for x:
mgtan(x)=(kq^2)/(2*sin^2x)
sin^2(x)*tan(x)=(kq^2)/(2mg)
From here I am stuck. How do I go forward when x is contained in two different trig functions on the left?
you should start by drawing a force diagram and using a variable not x for the angle.
wrt to the trig functions sin^2 is the same as (1-cos^2) and tan is sin/cos so you could change it to a sin cos term and from there find other Trig identities To reduce it further.
DerbisEternal said:
Homework Statement:: The problem is this: two 10 g balls hang from 1 m strings attached to the same point on the ceiling. They are both charged with 100 nC. What angle are they separated to?
Relevant Equations:: Fe=(k*q1*q2)/(r^2)
You can express all the trig in terms of tan, but it will give you a nontrivial cubic. So you could try a small angle approximation for both sin and cos, giving a trivial cubic instead. Having solved it, you can figure out whether the angle is small enough to justify the approximation.
Btw - magnetic??
I believe you have a small mistake here, it should be $$mg\tan x=k\frac{q^2}{4\sin^2 x}$$ as I think the distance between the two balls is ##2\sin x## if I have done the figure correctly myself. ##x## here is half the angle between the two strings.
That trigonometric equation might be hard to solve exactly (unless you use the small angle approximation as @haruspex suggested). I plugged this trigonometry equation at wolfram and I get very long and complex solutions. A workaround for this is the follow:
Using similarity of triangles (sorry i should have posted a figure) I seem to get the purely algebraic equation
$$k\frac{q^2}{4mgy^2}=\frac{y}{\sqrt{1-y^2}}$$
where ##y ## is half the distance between the two balls. (it is ##y=\sin x## to connect it with the previous post).
Letting ##a=k\frac{q^2}{4mg}## and after some algebra we seem to get $$y^6+a^2y^2-a^2=0$$ which can be reduced to a regular cubic equation using the substitution ##z=y^2## which can then be solved exactly using typical formulas. After solving for z , you get ##y=\pm\sqrt{z}## and ##x=\arcsin y##.
I got the cubic from the equation in post #1 by writing t for tan(x) and using ##\sin^2(x)=\frac {\sin^2(x)}{\cos^2(x)+\sin^2(x)}=\frac{t^2}{1+t^2}##.
I see, interesting, probably the two equations are equivalent. Do you agree on my post#4?
haruspex said:
Almost certainly.
Well, they turn out to be equivalent if we consider positive values of tangent and sine. Because in my equations it is ##y=\sin x## while in yours, ##y^2=\sin^2x=\frac{t^2}{1+t^2}## which if we solve for ##t## we get for the positive value of t ##t=\frac{y}{\sqrt{1-y^2}}## and then your equation becomes $$t\sin^2x=\alpha\Rightarrow \frac{y}{\sqrt{1-y^2}}y^2=\alpha$$ which is my equation :D
