How do I prove it is a diagonal?
  • Thread starter Zeroth
9 replies · 7K views · last reply
Zeroth
Inside of a square ABCD exists a point M such that |MA|=7 cm, |MB|=13 cm and |MC| = 17 cm. Calculate the area of the square
After a lot of formula searching I went and looked at the solution, there they proved that the point M i on the diagonal AC using the coordinate system and from there on it is easy to find the area. I need help in understanding the proof. They mentioned it is possible to do it using Pythagorean therorem but they didn't show how to do it and I don't see it. You can see my sketch in the picture. I know I am supposed to show my work and I have nothing to show, but can you at least give me some guidelines please?
  • Hand-drawn sketch on grid paper of square ABCD with corners labelled A, B, C and D, and an interior point M joined to each corner; the segments are labelled 7, 13 and 17 and the diagonal AC passes through M.
Have you tried the law of sines to determine all relevant angles or some Pythagoras by drawing the heights of your triangles?
However, the first seems to be easier.
Is this enough?
  • Handwritten geometry sketch on grid paper of a square ABCD with a diagonal drawn from A to C, with marked angles at the corners and a side labelled x, plus two side ratio fractions written to the left.
X/sin(γ) = 13/sin(α)
X/sin(δ)= 13/sin(β)
That is only possible if γ=δ and α=β
I hope the pic is understandable.
EDIT: Also.. I'm on the phone so it's a bit hard to write
  • Handwritten sketch of a square ABCD with diagonal AC drawn and a point O inside it, with a line from B to O. Angles are labelled alpha, beta, gamma, delta, and sides are labelled X and 13.
X/sin(δ)= 13/sin(β)
It does not follow from your equations that γ=δ and α=β.
Look at the picture , apply Pythagoras' theorem and find x, y. (The red lines go through the point M and are parallel to the sides of the square. )
Square ABC with side a, point M inside it joined to A and C; red lines through M are parallel to the sides, with lengths x, a-x, y and a-y marked on the edges.
https://www.physicsforums.com/attachments/103906
I realized the problem with the angles later. With that picture I had no problem doing it. In the solutions was essentially the same thing but the coordinate system made it very confusing. Thank you very much
After a lot of formula searching I went and looked at the solution, there they proved that the point M is on the diagonal AC using the coordinate system and from there on it is easy to find the area. I need help in understanding the proof. They mentioned it is possible to do it using Pythagorean therorem but they didn't show how to do it and I don't see it. You can see my sketch in the picture. I know I am supposed to show my work and I have nothing to show, but can you at least give me some guidelines please?
If you take their word for it, that "the point M is on the diagonal AC", then the Law of cosines can be used to find the length of a side.
However, it's not too difficult to use the Pythagorean Theorem to show that M is on diagonal AC. From that finding the length of a side is easy.
Place point, P, along segment MC a distance 5 cm from M . What can you determine about triangle MPB ?
I will be completely honest with you. I ddon't see eye to eye with geometry. I can't determine anything.
