How do I prove it is a diagonal?
  • Thread starter Thread starter Zeroth
9 replies · 2K views
Zeroth
Inside of a square ABCD exists a point M such that |MA|=7 cm, |MB|=13 cm and |MC| = 17 cm. Calculate the area of the square
After a lot of formula searching I went and looked at the solution, there they proved that the point M i on the diagonal AC using the coordinate system and from there on it is easy to find the area. I need help in understanding the proof. They mentioned it is possible to do it using Pythagorean therorem but they didn't show how to do it and I don't see it. You can see my sketch in the picture. I know I am supposed to show my work and I have nothing to show, but can you at least give me some guidelines please?
Is this enough?
X/sin(γ) = 13/sin(α)
X/sin(δ)= 13/sin(β)
That is only possible if γ=δ and α=β
I hope the pic is understandable.
EDIT: Also.. I'm on the phone so it's a bit hard to write
X/sin(δ)= 13/sin(β)
It does not follow from your equations that γ=δ and α=β.
Look at the picture , apply Pythagoras' theorem and find x, y. (The red lines go through the point M and are parallel to the sides of the square. )
https://www.physicsforums.com/attachments/103906
I realized the problem with the angles later. With that picture I had no problem doing it. In the solutions was essentially the same thing but the coordinate system made it very confusing. Thank you very much
After a lot of formula searching I went and looked at the solution, there they proved that the point M is on the diagonal AC using the coordinate system and from there on it is easy to find the area. I need help in understanding the proof. They mentioned it is possible to do it using Pythagorean therorem but they didn't show how to do it and I don't see it. You can see my sketch in the picture. I know I am supposed to show my work and I have nothing to show, but can you at least give me some guidelines please?
If you take their word for it, that "the point M is on the diagonal AC", then the Law of cosines can be used to find the length of a side.
However, it's not too difficult to use the Pythagorean Theorem to show that M is on diagonal AC. From that finding the length of a side is easy.
Place point, P, along segment MC a distance 5 cm from M . What can you determine about triangle MPB ?
I will be completely honest with you. I ddon't see eye to eye with geometry. I can't determine anything.
