How do I solve the equation e^(2x)-2=e^x?
  • Thread starter Thread starter Jaco Viljoen
    Function
The discussion revolves around solving the equation e^(2x) - 2 = e^x, which involves exponential functions and their properties. Participants are exploring the implications of rewriting the equation and the relationships between the terms involved.
  • Exploratory, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss rewriting the equation in a quadratic form and consider factoring it. There are questions about how to handle the terms involving e and the implications of logarithmic transformations. Some participants express uncertainty about factoring and the relevance of certain terms.
There is an ongoing exploration of different approaches to the problem, with some participants providing hints and suggestions. While some have proposed methods for solving the equation, there is no explicit consensus on the best approach, and various interpretations of the problem are being examined.
Participants note the constraint that e^x must be positive, which influences the acceptable solutions. There is also mention of the original poster's prior attempts and the need to review foundational concepts related to exponents.
Jaco Viljoen
h(x)=e^(2x)-2
a)Write down the Dh
b)Solve the equation e^(2x)-2=e^x
a)x∈ℝ[/B]
e^(2x)-2=e^x
((e^x)^2)-e^x-2=0I don't know what to do here:
Jaco Viljoen said:
h(x)=e^(2x)-2
a)Write down the Dh
a)x∈ℝ[/B]
e^(2x)-2=e^x
((e^x)^2)-2=e^x
Move the ex term to the left side. Your equation is quadratic in form, and can be factored. Keep in mind that ex > 0 for all x.
Hi Mark,
Thank you,
I initially did this but how do I factor e^(x2)
I also considered adding a ln to both sides to get rid of the e on both sides but the -2 is the problem.
Jaco Viljoen said:
Hi Mark,
Thank you,
You need to go back and review the laws of exponents. How does ##e^{2x}## relate to ##e^x##? Surely you must have had such material already, or else you would not have been asked to do this problem.
Jaco Viljoen said:
Hi Mark,
Thank you,
What you wrote in post #1 should be something of a hint.
Jaco Viljoen said:
e^(2x)-2=e^x
((e^x)^2)-e^x-2=0
If you have terms added together, taking the log is not any help.
((e^x)^2)-2=e^x
(k^2)-k-2=0 k=e^x
(k+1)(k-2)=0
k=-1 or k=+2
e^x=2
lne^x=ln2
x=ln2
Jaco Viljoen said:
((e^x)^2)-2=e^x
(k^2)-k-2=0 k=e^x
(k+1)(k-2)=0
k=-1 or k=+2
e^x=2
lne^x=ln2
x=ln2
This is correct, but you should say why your are discarding the other value of k.
1.a) Dh=
b)The solution can go through this path: (e^x)^2-e^x-2=0
If e^x=y i) then the equation is transformed like that: y^2-y-2=0
then the solutions are y=(1±3)/2 and from i) we get e^x=(1±3)/2 BUT since the function e^x can only give positive results for x∈ℝ the only acceptable solution would be the one with the +. So e^x=2 ⇔ x=ln2, there you go friend I hope this helps :)
NicolasPan said:
1.a) Dh=
The OP has already gotten all of this.
  • · Replies 24 ·
