How Do Matrix Valued Propagators Interpret Fermion Amplitudes?
  • Context: Graduate
  • Thread starter Thread starter Bobhawke
    Matrix Propagators
11 replies · 3K views
Bobhawke
For scalar fields the propagator is just a number that represents the amplitude for a particle to go from one space time point to another.
For fermions, the propagator is matrix valued. What then is the amplitude for a fermion to go from one point to another? How are the elements of the matrix to be interpreted in terms of probability ampltudes?
row-vector times matrix times column vector = number.
The fermion propagator involves the dot product of a 4 vector (momentum) and the gamma matrices. I am pretty sure the result is a matrix.
No, since the states are vectors... (4-spinors)
Have you never worked with relativistic quantum identities? What part of my first post did you not understand?
The signature :rolleyes:
shall I change it? :rolleyes:
But seriously, what is wrong with my explanation?
The fermion propogator IS a matrix, Bobhawke is correct. It is an outer product of spinors, not an inner product.
I think the answer he is looking for is [itex]S_{\alpha\beta}\equiv\langle T\psi_\alpha\bar{\psi}_\beta\rangle[/itex] is the amplitude for a fermion of polarization [itex]\alpha[/itex] to propagate to a fermion of polarization [itex]\beta[/itex].
Up to signs and whatnot!
Malawi_glenn: don't change your signature for anyone! :blushing:
I think we agree, there is not much more to this equation than what malawi_glenn was writing in "row-vector times matrix times column vector". It is also written in "the states are vectors... (4-spinors)".
yes, the propagator is matrix, but the amplitude is a number. And that was the question, if the propagator is a matrix, what will happen to the amplitude.
I think that is the question I answered. The matrix elements of the propagator are the amplitudes for the polarization states to propagate.
Thanks for the replies everyone!
Actually, the propagator is generally the propagation from a source.
So in QED the photon is propagated from the transition current (the interference
pattern caused by an electron in two momentum states) and the electron is
propagated from the interference term [itex]e\gamma^\mu\,A_\mu\psi[/itex]
It is indeed the amplitude per polarization state but there are some interesting
details about the interplay between SU(2) and U(1). For instance in a magnetic
field B the energy will be different per polarization state:
[tex]\binom{~~\exp(-i[E+\Delta E]t)~~}{~~\exp(-i[E-\Delta E]t)~~} ~~=~~ \binom{~~\exp(-i\Delta Et)~~}{~~\exp(+i\Delta Et)~~}~\exp(-iEt})[/tex]
At the RHS the energy is the same for both states but the spinor represents
a precessing spinor around the direction of the magnetic field. Note that:
[tex]x\uparrow=\binom{1}{1}, ~~y\uparrow=\binom{1}{i},~~x\downarrow=\binom{1}{-1}, ~~y\downarrow=\binom{1}{-i}[/tex]
(up to an overal factor of [itex]1/\sqrt{2}[/itex])
Regards, Hans.
