How do particles become entangled and does information transfer instantly?
154 replies · 22K views · last reply
Thanks for the corrections on details, some
comments below:
vanesch said:
... it is not correct when you shine unpolarized light
onto a beam splitter and look at the two outcoming beams
(which DO have identical polarization at each instant of
course because being a split beam). When you perform this
experiment, you find rates which are INDEPENDENT of theta
(as well, independent rates individually, as coincident).
We wouldn't use a beamsplitter as the source, since we
wouldn't get coincidental detections this way. Would we?
vanesch said:
When the angle p_b is such that it is perpendicular to this
direction (L), NO counts are seen at B, so no coincidences are observed.
cd_AB only goes to 0 when p_a = MDR_a = MDR_b (with dr_a = dr_b
for corresponding p_a and p_b, and ranging from some maximum
count, mdr_a = mdr_b, to a minimum of 0.
If you offset L from p_a by some angle < pi/2 (and it has
to be < pi/2 because detection at A initiates the coincidence
intervals), then moving p_b through a 90 degree rotation away
from alignment with p_a, then p_b is never perpendicular to L.
So, if L is offset from p_a, then cd_AB never reaches the
max cd_AB (which it would if p_a was aligned
with L), and cd_AB never reaches 0 because when
p_b and p_a are perpendicular there will still be >0 probability
of detection at A and >0 probability of detection at B.
So we can see how the upper and lower limits of the range of
cd_AB are determined by how much L is offset from p_a.
vanesch said:
... for a randomly polarized beam (no L anymore) and a given p_a,
you will again find another function of theta. This time, however, by
symmetry, for a different value of p_a (but the same "kind" of random
polarization), you will find the same function of theta.
Ok, and there is a case where fixed polarization duplicates
the curve for random (entangled) polarization -- namely, when
p_a = MDR_a = MDR_b where dr_a and dr_b vary from
mdr_a = mdr_b to 0.
vanesch said:
However, that function of theta doesn't have to be the one
you found for a polarized source.
But it happens that it is the same function that we get
for a special case of a fixed source, using the
same formulation for fixed and random (entangled) setups.
(Question: since that special case of a fixed source
seems to violate a Bell inequality, and since violation
of Bell inequalities is sort of a rough entanglement
witness, then can we say that in the special case
of fixed source the results are entangled? According
to the usual ways of evaluating entanglement the
answer would seem to be no -- but, according to my,
admittedly hurried, calculation you do get a violation
-- following the CHSH method. I don't know how to think
about this -- maybe I just did it wrong.)
vanesch said:
... {the source polarization is relevant} in the derivation of cd_AB.
The relationship between L and p_a affects
the range of cd_AB for a fixed source.
But once we have set p_a, then the values
we get within the range determined by |L - p_a|
are completely determined by changes in
|p_b - p_a|.
The *variability* of cd_AB *within a given range*
is independent of the source polarization.
In the random entangled setup the source
polarization wrt a given coincidence interval
is unknown. But the range of cd_AB wrt a set
of runs is constant.
vanesch said:
Again, explain me the difference between:
1) the production of entangled states (which do give us a cos^2(p_a - p_b) dependence,
but that's a pure quantum prediction
2) a (polarized or unpolarized) classical beam, impinging on a beam splitter with the
transmitted beam sent to Alice and the reflected beam sent to Bob.
I don't see, in your approach, how we can arrive at DIFFERENT predictions for
the cases 1) and 2).
It wouldn't be applied to case 2). Beamsplitters (as the
single emitter between A and B) don't produce coincidental
photon detections (p_a and p_b wouldn't be analyzing the same
thing during a coincidence interval). The approach applies to setups
where crossed linear polarizers are analyzing light from a single
emitter -- setups where it might be said that p_a and p_b are analyzing
related or the same rotational properties of the incident light during
a given coincidence interval.
Anyway, I agree with you that modeling randomly
polarized entangled light in terms of a common source polarization,
L, seems impossible using extant geometric models of the emitted
light. (I've got some ideas on how this might be done without
the usual contradictions, but must take some time to explore them.)
But, have we not shown that (1) the cd_AB for the entangled
setup can be put into the form of the product of the
individual probabilities at A and B, corresponding to a
special case of the fixed setup, (2) that the global
variable affecting *range* of coincidental detection is
|Lambda - p_a|, and (3) that the global variable affecting
*rate* of coincidental detection within a given range is
|p_a - p_b|? (Note that p_a is the convention for the
polariizer setting at the end that initiates any, ie. all,
coincidence interval(s).)
There's nothing new here, just laying some groundwork.
And, thanks again for taking the time to talk through some
of this stuff. After reading up a bit on entanglement I'm
quite sure that I understand it much less than I thought
I did when I first jumped into this thread. :)
That's true (except for coincidental double events at high enough rates and slow enough detectors) of course, using a QUANTUM DESCRIPTION, but my point was: how is this situation with a beamsplitter different, semiclassically, from the "entangled photon pair" situation ? There is no difference in description if you use the Maxwellian description: you have IDENTICAL beams, with identical temporal evolution of the electric field vectors in the two beams. Identical polarizations, identical amplitudes as a function of time...
So as long as you stick to a semiclassical description to explain entangled pairs, you're supposed to find exactly the same results as with a beam splitter, no ? And once you admit that there's a DIFFERENCE (which there is, according to QM and which there is, experimentally), then you cannot place yourself anymore in a semiclassical frame to do the explaining, because it is hard to find out how to find two different explanations for the same beam descriptions :-)
What I calculated (the eff^2/8 (2 - cos 2 theta) ) was in fact using the "identical classical beams" and the assumption of a "square law detector": that is, a detector that has an independent probability of clicking per unit of time, proportional to the incident Maxwellian intensity.
cheers,
Patrick.
Yes, actually you've persuaded me a while back to drop a
semiclassical approach to understanding (quantum) entanglement. :)
:smile:
I have to say I feel a bit burned out on the subject for the moment...
cheers,
Patrick.
hello
Hello everyone. As you might have noticed by now, I'm daytripper. I started this thread last year when the subject matter was way over my head only to come back to see 158 replies. I'm pretty proud that I stirred up so much discussion on entanglement. Anyway, thank you all for entertaining my questions even if I don't take out time to read all 158 replies.
