High School How do physicists know if limits exist, things are integrable, etc?
The discussion centers on the challenges physicists face in determining the validity of limits, integrability, and the reliability of mathematical expressions in physical contexts. Participants express concern about the assumptions made in physics, particularly regarding the existence of limits when differentiating or integrating functions. The conversation highlights the importance of experimental validation in confirming mathematical models, emphasizing that a model's accuracy is judged by its alignment with observed phenomena. There is also a recognition of the historical evolution of calculus foundations, such as through Fourier series and Lebesgue integration, which have influenced modern physics. Ultimately, the dialogue underscores the balance between theoretical rigor and practical application in the field of physics.
DrBanana
My last thread had too many questions, so I was told to make a new one. The question in this thread does not seem the same as the ones in the last thread, but I supposed that this is the root of my problems, so I started here. Also I wasn't sure whether to put this in the physics section or the maths section, sorry if I made a mistake.
So in a standard undergraduate mechanics textbook, a lot of limits may be taken, a lot of things may be differentiated, and some things might be integrated. How do we know that it is always safe to do this and that we don't get the wrong expression for a physical quantity? For example the practice of 'breaking up something into small parts and then summing' is common, how do we know that this integral we're taking doesn't diverge? When we 'divide by a small change in time ##\Delta t## and take the limit as ##\Delta t## goes to zero', how do we know that that limit exists?
Are you speaking physically or mathematically?
Or in practice? o0) Beacuse from my experience, most of physicists that I have met in my life didn't care that much about that. It was always driving me crazy, that's why I ended specializing in mathematical physics.
Well, I’ve never derived an expression for a physics problem or any problem without fretting over it. Do its limits make sense? The units check out? On and on. Certainly not epsilon delta proofs but I don’t just accept the result. I’m just too fallible.
One can argue that fourier series opened up a whole series of questions about the foundations of calculus that mathematicians spent the next century resolving, culminating with Lesbesgue integration. These concepts are addressed in a real analysis course.
Both, I suppose, but more emphasis on the correct prediction of the physical aspect by the derived mathematical formula (well as far as you can go without resorting to experiment). I guess if you study more advanced physics of course you have to get experimental results but my main focus is on kinematics and Newtonian mechanics here.
Can you expand on making sense of the limits?
I don't know why but I always thought real analysis was detached from reality (well the most exposure I've had to that is by reading the first four chapters of Spivak's calculus so it makes sense). Can you recommend books with eventually come back to proving the physics formulas?
Partially, I guess, by adjusting/trial and error , as you go. However tempting, a strict bottom-up development or buildup is overall very inefficient, imo.
You cannot go anywhere in physics without resorting to experiments. That Newtonian physics are more intuitive to you does not give it a carte blanche. The limits that you are talking about are part of the mathematical model and ultimately observation and experimentation is the judge. If it describes observation well, then it is a good model. If it doesn’t then it isn’t.
Problems in physics and engineering are usually approached with a general understanding of how things work. For example if I work out a lumped element circuit model impedance and I want a sanity check on the result I might look at the limits of the expression for infinite frequency. In this limit all capacitors can be replaced with conductors and all inductors removed. If the derived expression doesn’t agree with the limiting circuit, it’s wrong. I know I’ve made a mistake.
I know this is straying away from the topic of the thread, but don't there come times when you need to predict things that can't be tested beforehand but are mission critical?
Fortunately, I’m retired so nothing is mission critical. During my working life, several things I worked on fit your description. The approach I used was first make a computational model based on assumptions and approximations that could be directly applied to the full problem. I then developed laboratory tests and fixtures that also could be predicted with this computational model. This allowed direct verification of the modeling.
Sure, but we already know from extensive experimentation that the continuum limit is a very good description. So good that we are willing to trust it with mission critical predictions.
Certain things in physics are mostly assumed, like the ability to expand a function in a power series.
This whole issue is examined in some fascinating lectures by Karl Bender:
The bottom line is problems can become intractable if you don't.
However, there are Mathematical Physicists who are very rigorous.
It is two different styles, each with its own insights.
Thanks
Bill
  • · Replies 16 ·
  • · Replies 20 ·
  • · Replies 24 ·
  • · Replies 53 ·
