How Do Rate Constants Change with an Intermediate State in a Kinetic Model?
The discussion revolves around the rate constants in a kinetic model involving chemical reactions, specifically examining the impact of introducing an intermediate state (C) between two states (A and B). Participants explore the functional relationships between the rate constants of the original model and the modified model with the intermediate state, as well as the possibility of defining an effective rate constant in the new system.
  • One participant questions the functional relationship between the rate constants a1, a2, and a, suggesting a possible form of 1/a = 1/a1 + 1/a2.
  • Another participant asserts that there is no functional relationship and presents the system of differential equations that includes the intermediate state C, indicating that C cannot be eliminated to yield a system involving only A and B.
  • A later reply proposes the idea of an 'effective' rate constant between A and B in the new system, suggesting that if C is at quasi steady state, it can be expressed in terms of A and B, leading to new forms of the differential equations.
Participants do not reach a consensus on the existence of a functional relationship between the rate constants. There are competing views on whether an effective rate constant can be defined in the presence of the intermediate state C.
The discussion highlights the complexity introduced by the intermediate state, particularly regarding the inability to simplify the system to exclude C. The assumptions regarding the quasi steady state of C are also noted but not resolved.
phyalan
Hi everyone,
I have a question on the rate constant of a kinetic model(like the one we use in describing chemical reaction). Suppose we have the following model between two states A and B:
A--(a)-->B
A<--(b)--B
where a, b are the rate constant for the transition. So the corresponding differential equation will be
[itex]\frac{dA}{dt}=-aA+bB[/itex]
[itex]\frac{dB}{dt}=-bB+aA[/itex]
If now I add an intermediate state C, so that if we just measure the amount of A and B, the two models gives basically the same description (i.e. the overall rate constant from A to C then to B is equivalent to a and the same for reverse direction)
A--(a1)-->C--(a2)-->B
A<--(b1)--C<--(b2)--B
What is the functional relationship between the rate constant a1,a2 and a and similarly for b1, b2 and b? I am confused on how to find out the functional form. Is it just simply
[itex]\frac{1}{a}=\frac{1}{a1}+\frac{1}{a2}[/itex]?
phyalan said:
Hi everyone,
A--(a)-->B
A<--(b)--B
There is no functional relationship. What this system gives you is
[tex] \frac{dA}{dt} = -a_1A + b_1 C, \\<br /> \frac{dB}{dt} = -b_2 B + a_2 C, \\<br /> \frac{dC}{dt} = a_1 A + b_2 B - (a_2 + b_1) C.[/tex]
There is no way to eliminate [itex]C[/itex] from this system in order to end up with a system involving only [itex]A[/itex] and [itex]B[/itex]. The complication comes from the fact that you also have [itex]A \to C \to A[/itex] and [itex]B \to C \to B[/itex], so not all [itex]A[/itex] turns to [itex]B[/itex] before turning back to [itex]A[/itex] and vice-versa.
Maybe I change my question, is there any 'effective' rate constant between A and B in the new system
[tex] \frac{dA}{dt} = -a_1A + b_1 C, \\<br /> \frac{dB}{dt} = -b_2 B + a_2 C, \\<br /> \frac{dC}{dt} = a_1 A + b_2 B - (a_2 + b_1) C.[/tex] ?
If C is short-lived so that it is at quasi steady state, then
[tex]C=\frac{a_1 A + b_2 B}{(a_2 + b_1)}[/tex]
If we substitute this into the other differential equations, we get:
[tex]\frac{dA}{dt}=\frac{-a_1a_2A+b_1b_2B}{(a_2 + b_1)}=-a_3A+b_3B[/tex]
[tex]\frac{dB}{dt}=\frac{a_1a_2A-b_1b_2B}{(a_2 + b_1)}=a_3A-b_3B[/tex]
Chet
  • · Replies 67 ·
  • · Replies 42 ·
  • · Replies 32 ·
  • · Replies 38 ·
