How do walk-in freezers not give people hypothermia? [they do]
  • Context: High School
  • Thread starter Thread starter SpeedOfLightYagami
The discussion revolves around the safety and physiological effects of walk-in freezers, particularly why individuals do not typically experience hypothermia when briefly entering these environments. Participants explore personal experiences, safety regulations, and the conditions under which exposure becomes hazardous.
  • Some participants suggest that brief exposure to cold in walk-in freezers is manageable, as it takes time for the body to cool to dangerous levels.
  • Others emphasize that working in cold storage requires protective gear, and frostbite can occur even with small gaps in clothing.
  • A participant recounts a personal experience of extreme cold exposure in a freezer, highlighting the rapid onset of discomfort and danger.
  • There are claims that modern safety regulations require freezers to be operable from the inside, although some participants express uncertainty about specific compliance.
  • Statistics are mentioned regarding fatalities associated with walk-in freezers, raising concerns about safety features like panic buttons.
  • Some participants question the necessity of extremely low temperatures in freezers, linking it to the preservation of ice cores rather than food storage.
  • Discussions about the properties of ice, including its crystalline structure and behavior under pressure, are presented, with some participants correcting earlier misconceptions about ice being amorphous.
Participants express a mix of agreement and disagreement regarding the safety and physiological effects of walk-in freezers. While some acknowledge safety features and regulations, others raise concerns about their effectiveness and the risks involved in prolonged exposure.
Some claims about safety regulations and statistics on freezer-related incidents are not universally accepted, and there are unresolved questions about the specific conditions under which hypothermia may occur.
SpeedOfLightYagami
I'm always surprised that this never happens when I need to grab some meat at BJ's.
  • Skeptical
Because you aren't in there very long and it takes a while to cool down to the point you're in danger. You wouldn't want to be shut in one for long, though (I expect Health and Safety will require modern ones to be openable from the inside in reality, although I've never had occasion to check.
People who work in cold stores wear polar survival gear, and sometimes get frost bite because there is a small accidental gap in their clothing.
On one occasion, I stood still in a -40° cold store, wearing shorts and a T-shirt. Over the first minute I felt the cold penetrating to my bones, then when I lost sensation of my flesh and could only feel my skeleton, I escaped to 30°C. Being chilled to the bone took on a new meaning. I was young, and it was foolish, but anatomically enlightening. It is not something I would recommend others try.
It is absolutely a hazardous environment. If you were to remain inside for an extended time then you would suffer from exposure
Ibix said:
... I expect Health and Safety will require modern ones to be openable from the inside in reality, although I've never had occasion to check.
It is a standard safety requirement.
Please, see:
https://www.kasonind.com/index.php/products/latches_and_locks/walk_in/inside_realeases
Even if the mechanism fails or the door is blocked, building codes require that means to shutoff evaporator are accessible from inside the freezer.
Forensic scientist Howard Cannon says 60 people die from walk-in freezer incidents per year. He says some freezers do not have basic safety features, like a panic button to inform anyone outside of the freezer when someone is stuck inside.
https://www.insideedition.com/louis...-getting-trapped-inside-freezer-lawsuit-85922
I came across the above statistic while searching for the case last year or so of a young woman who died in a freezer, ( I think in a Walmart, but not exactly sure ).
At my first restaurant job (summer of '72 ?) we had a walk in, and it had a big plunger type knob to open the latch from inside. That was over 50 years ago, and the walk in was probably 10 or 20 years old then.
-40!!! .... Why do freezers have to be that cold? My understanding is that at freezing point all decomposition of meat ,or anything comes to halt.
Because they store ancient ice cores, not food.
Why do ice cores need to be so cold?
Because warmer ice flows, and bubbles of historical air in the ice can move.
Oh ... I understand glass is an amorphose solid , no molecular bonding , just a very very thick syrup ...
And a quick search reveals ice is also an amorphouse solid ...
Thanks ... that's something I've learnt today.
Old ice is not amorphous, it is a crystalline solid, like a rock made from crystals of H2O.
Glaciers flow, and skates glide, because ice melts where local pressure is applied. Colder ice requires higher local pressure, before it will melt, flow and recrystallise.
Ice in storage is subjected to a minimum contact pressure. That ice is most stable at lower temperatures, where those pressures will not be relieved by local melting.
I remember the 'regelation' demo at school when a wire is slowly pulled through a block of ice.
Like an idiot, when I was a lad I went into a freezer room and shut the door behind me. The fan kicked in and I was suddenly in an Antarctic storm. I was relieved to push the bar which released the door. Of course, the light had gone out which made it even worse.
  • · Replies 52 ·
  • · Replies 30 ·
