How Do You Calculate Acceleration from a Velocity-Time Graph?
10 replies · 3K views · last reply
rashad764
Velocity-time graph of vx in m/s against t in s: velocity is constant at 4 from t=0 to 2 s, then decreases linearly to 0 at t=4 s, passing 2 at t=3 s.
find the accleration at t=3 seconds
vf-vi/tf-ti
velocity at 3sec is 2 m/s and at 0 sec is at 4m.s
time is 3-0
2-4/3-0, [/B]
rashad764 said:
1. The problem statement, all variables and g iven/known data
find the acceleration at t=3 seconds
vf-vi/tf-ti
time is 3-0
2-4/3-0, [/B]
Your answer of ##2 - \frac{4}{3} - 0 = 0.66667## is incorrect. Even if you put in parentheses (which you should always do) you would get ##(2-4)/(3-0) = -0.66667##, which is still incorrect. Can you see where your error lies?
is it suppose to be -2?
You tell me.
Ray Vickson said:
You tell me.
well since the line is going downwards, it has to be negative velocity
No the _velocity_ is still positive at t=3 sec. If you meant negative acceleration you would be correct.
i still can't see what's wrong
velocity at 3seconds is 2 and at 0 seconds its 4
time is 3 seconds minus 0
The problem is that in post #3 you just asked if the answer was -2m/s without showing your working. That's what Ray meant by you tell me.
The acceleration at t=3 is the slope of the line at t=3. Does the slope start at t=0?
or look at it this way...
The slope/acceleration is the same at t=2.5 and 3.5sec right. Does your method give the same answer?
i was saying if the the velocity was -2 so it would be -2-4/3
acceleration begins at t-2 and and ends at t=4
so it would be( 2-4)/(3-2)
The velocity is never -2m/s. The velocity is positive at all times.
The _change_ in velocity is -2. Is that what you mean?
Sorry for editing this reply. (2-4)/(3-2) = -2 is correct.
