How Do You Calculate Point P3 in a Coordinate System with a 90-Degree Angle?
  • Thread starter Thread starter chuyler1
    Coordinate
To determine the coordinates of point P3 based on known points P1 and P2, with a 90-degree angle and a distance from P2 to P3 being one-fifth of the distance from P1 to P2, the solution involves vector algebra rather than calculus. The slopes of the lines formed by P1-P2 and P2-P3 are negative reciprocals, which simplifies the calculations. Specifically, the x-coordinate of P3 can be calculated by subtracting one-fifth of the vertical difference between P1 and P2 from the x-coordinate of P2. Similarly, the y-coordinate of P3 is obtained by adding one-fifth of the horizontal difference between P1 and P2 to the y-coordinate of P2. This approach effectively utilizes the properties of similar right triangles without the need for complex trigonometric functions.
chuyler1
See the attached image first. Given that I know points P1 and P2, what would the equation be to get point P3, given that the angle is 90 degrees and the distance from P2 to P3 is 1/5 the distance from P1 to P2?
Thanks in advance!
Welcome to PF!
Hi chuyler1! Welcome to PF! :wink:
Show us what you've tried, and where you're stuck, and then we'll know how to help. :smile:
I haven't a clue where to begin. It's been 8 years since the last time I had to think about calculus. I found some equations on how to rotate a point by 90 degrees but the only examples are to rotate around (0,0).
This calculation has to be performed hundreds of times in a short amount of time so if the equation is too complex i may just fudge it by increasing point P2's y by L/5. It simplifies the problem but doesn't provide desirable results in all situations.
Could you use the fact that the slopes of perpendicular lines are negative reciprocals of each other? I.e.:
m1 = -1/m2
What is m1 and m2 in your equation?
They are the slopes of the two lines you drew.
m1 = slope of line P1-P2
m2 = slope of line P2-P3
No calculus is needed here... just vector algebra.
(Will P1-P2 ever be vertical?)
Are you willing to use trig-functions?
Yes, P1 and P2 are arbitrary, they could be any angle or even reversed. I have trig functions available to me so a solution involving them isn't a problem.
I've had some more time to think about this. We won't even need trig!
In the figure, note that we form two similar right triangles, with a scale factor of 1:5.
To get the x-coordinate of P3, subtract (y2-y1)/5 from x2.
To get the y-coordinate of P3, add (x2-x1)/5 to y2.
Awesome! Works perfectly!
