How Do You Calculate Resultant Displacement and Direction in Vector Problems?
  • Thread starter Thread starter r-soy
    Car
7 replies · 15K views
r-soy
Hi all
A car travels 20 km due north and then 35 km in a direction 60 degree west of north. Find the magnitude and direction of the car's resultant displacement.
How I can solve like this question ?
I try to solve :
the magnitude = R = A + B
= 55 km
is north
Do you understand what displacement is?
If I go 1km north and then 1km east, my final displacement is the distance (magnitude) and direction I am from my starting position. So the answer to this problem would be 45o East of North with a distance of [tex]\sqrt{2}[/tex]km.
can I solve this question by this two rule for
magnitude = R = sqrt(A^2 + B^2)
dircaion = tan = y/x
Yes but you have to think a little more about the problem to set it up into a right-triangle so you can use those formulas.
I would not do it as a right triangle problem. You have a triangle with two sides of lengths 20 and 35. Since the first leg is "due north" and the second leg is "60 degrees" west of north", the angle between the two legs has measure 180- 60= 120 degrees. Since you have two sides of the triangle and the angle between them, use the "cosine law": [itex]c^2= a^2+ b^2- 2ab cos(C)[/itex] where a and b are two sides of the triangle, C is the angle between them, and c is the third side, opposite C.
Here, [itex]c^2= 20^2+ 35^2- 2(20)(35)cos(120)[/itex]
Moderator's note: this thread has been moved from General Math to the Homework & Coursework Questions area of the forum.
thank you but c (third side ) mean magnitude ??
and now how to find the dircaion ??
Since you are given 2 sides of the triangle (and can calculate the third) and one angle, you could use the sine law to find the other angles: If A, B, and C are three angles in a triangle and a, b, and c are the lengths of the sides opposite each side, respectively, then
[tex]\frac{sin(A)}{a}= \frac{sin(B)}{b}= \frac{sin(C)}{c}[/tex]
