How Do You Calculate Rocket Propulsion and Acceleration?
  • Thread starter Thread starter redred7
    Impulse Momentum
redred7
A small 120kg rocket is fired vertically, propelled by an engine with a thrust of 6500N. The engine ejects gas at a rate of 4.5kg/s.
a) Calculate the change in velocity of the gases relative to the engine
b) after 20 s what will be the rockets acceleration.
F * delta T = m * delta V
(6500-1176)(1) = (120-4.5)delta V
5324= 115.5V
V= 46 m/s
I am not sure if I acceleration the correct force (because I am not sure if I should subtract Ff), correct mass (because I believe that mass is contant in this formula as there isn't delta M)
Hi redred7,
5324= 115.5V
V= 46 m/s
Yes, the mass is changing. The problem states that every second the mass changes by 4.5kg. So in your equation keep the term that has the change in mass.
