How Do You Calculate Shaft RPM for Different Pulley Sizes?
  • Context: Automotive
  • Thread starter Thread starter jayjay
    Rpm Shaft
The discussion revolves around calculating the shaft RPM based on different pulley sizes in a mechanical setup involving a motor and pulleys. Participants explore the relationships between motor RPM, pulley diameters, and resulting shaft RPM, with a focus on practical application rather than theoretical derivation.
  • Homework-related
  • One participant presents a scenario involving a motor with specific horsepower and RPM, along with pulley sizes, to calculate the shaft RPM.
  • Another participant questions whether the inquiry is for schoolwork, suggesting a distinction in how such questions are treated.
  • Participants discuss the relationship between motor RPM, motor pulley diameter, pulley B diameter, and pulley B RPM, indicating that knowing three of these variables allows for the calculation of the fourth.
  • It is noted that if pulley B is fixed to the shaft, it must rotate at the same rate as the shaft.
There is no consensus on the specifics of the calculations, as participants are still exploring the relationships between the variables. Some participants agree on the mechanics of pulley rotation, while others focus on the calculation method without resolving the initial query completely.
Participants reference specific values and relationships but do not provide a complete mathematical derivation or resolution of assumptions regarding the system's setup.
jayjay
Hi guy here's an example in the picture for my project.
i need to find the shaft rpm to find what size pulley D will be.
Pulley B attached with a belt that come from a motor.
17.5 hp
3400 rpm
3 inch pulley
if I am right and pulley b is 8.4 inch
rpm 1214
torque 76 ft/lbs i think
the shaft pulley is 5/8
thanks
17.5 hp
3400 rpm
3 inch pulley
rpm 1214
thanks
Is this question for schoolwork?
no for myself why?
jayjay said:
no for myself why?
Because the drawing looks like it came from a textbook problem, and we handle schoolwork questions differently from project questions here at the PF.
Did you do that drawing yourself? It's pretty impressive. What drawing CAD package did you use? Is this for your snowblower project?
thats a picture from the internet as an example of the samething I am doing
Consider these four variables...
Motor rpm
Motor pulley diameter
Pulley B diameter
Pulley B rpm (=shaft rpm).
To work out anyone of these you need to know the other three.
Start by writing an equation that relates these four variables an rearrange to give you one for the pulley B rpm.
Motor rpm
Pulley B diameter
ok so the rpm for the pulley B will be the same for the saft if i understand
Correct. If pulley B is fixed to the shaft then it must rotate at the same rate. Same for pulley C.
Great that helps me for that part thanks a lot
  • · Replies 63 ·
10K
  • · Replies 20 ·
  • · Replies 19 ·
