How do you calculate speed without taking mass into account?
  • Thread starter Thread starter GregoryG.
    Mass Speed
To calculate the speed of a baseball caught at the same height it was hit, gravitational potential energy (Ug) and kinetic energy (Uk) principles can be applied, neglecting mass. The potential energy at the peak height of 295 feet can be expressed as Ug = mgh, where g is the acceleration due to gravity. At the highest point, the ball's kinetic energy is zero, and all energy is potential. When the ball returns to the catcher's height, potential energy converts back to kinetic energy, allowing for the equation mgh = (1/2)mv^2, where mass cancels out. This approach simplifies the problem, showing that mass is not needed to determine the speed of the baseball.
GregoryG.
During the World Series a ball is hit straight up from the batter’s box and reaches a height of 295 ft. Neglecting air friction, what speed (mph) will the baseball attain if it is caught by the catcher at the same height it was hit?
The equation I pull out of this is the one for gravitational potential energy
Ug=M*G*H
G = 9.81 m/s
H = 295 feet = 89.9 m
It could also have something to do with the ball having no kinetic energy when it make contact with the bat, then having no gravitational potential energy when the catcher catches it but, I can't figure out how to put these two formulas together.
Uk=(1/2)*mv^2
3. An attempt at the problem
Ug = 9.81 m/s * 89.9m
Ug = 882m/s = 2030m/h (seems unlikely this ball will break mach 1)
This would only work if we disregard mass. We've done this in other problems, but it seems very important here.
Likes zahoor hashimi
What is the kinetic energy of the ball when it's at the highest point in its trajectory?
Ug=M*G*H
G = 9.81 m/s
Why did you choose this particular equation? It doesn't help you to answer the primary question, How fast will the ball be traveling when it is caught?
Uk=(1/2)*mv^2
You are making this problem much harder than it truly is.
If you drop something from the top of a building which is 295 feet high, how fast will that object be traveling when it hits the ground?
What if I told you the name of the player who hit the ball was Manny Suvat?
What are the units of g * h? (Hint: it ain't m/s).
Since you aren't given the mass of the baseball, that should be a big old hairy hint that PE or KE will not be very useful to answering the question here.
Likes GregoryG.
Have you taken calculus?
We know that ##V = V_0 - 9.8 t## What is the antiderivative of this formula? Do it on paper and keep track of your units.
Ug=M*G*H
G = 9.81 m/s
Check your units for G. It's an acceleration, not a velocity. Also, the conventional variable for gravitational acceleration is "g" (lower case). Capital G is usually reserved for Newton's gravitational constant.
Uk=(1/2)*mv^2
If you fix your units for "G" (should be "g"), then you'll see that the results of Ug would be ##m^2/s^2##, which is equivalent to ##J/kg## (that's Joules per kg). This is not a bad thing! (see below)
Conservation of energy will work here! If you don't know the mass you can leave it as a symbol and it will cancel out by the end if it's not an essential quantity for the problem.
In fact, it is sometimes practical to work with what are called "specific" quantities for energy related problems. This is particularly true in fields like astrodynamics where the masses of objects like comets or asteroids are not well known. A specific energy is the energy per unit mass, so the units would be J/kg for example. So we could write:
##PE_s = g h##
##KE_s = \frac{1}{2} v^2##
Likes GregoryG.
It would be zero right? The ball isn't moving anymore because of the energy imparted to it by the bat at the highest point of its trajectory.
I'm in Calc one now. We haven't discussed anti-derivatives, and this problem is from an intro algebra-based physics class. I don't think my teacher wants us to use Calculus.
Oh, sorry. Use the energy formulas then:
$$PE = gh$$
$$KE = \frac{1}{2}v^2$$
There is one point where the ball is not moving. That's when you can use the potential energy formula...
Right, so the total energy when the ball is that point (remember, total energy equals kinetic energy plus potential energy) would be ##mgh##.
When the ball is at its lowest position the potential energy is zero, so the total energy is ... ?
Set the two amounts of energy equal to each other. (When you do that ##m## cancels.)
Not to nitpick technicality, but Gregory, do keep in the back of your mind that you are calculating velocity, KE and PE relative to the ground.
