How Do You Calculate the Angle of Reflection in Optics Problems?
  • Thread starter Thread starter parcerita
    Angle Reflection
The discussion revolves around calculating the angle of reflection in an optics problem involving a beam of light directed at a flat surface of fused quartz. The original poster presents a specific scenario with given parameters, including the index of refraction and an angle of refraction, while seeking clarification on the procedure to find the angle of reflection.
  • Participants discuss the application of Snell's law and the law of reflection, with some expressing frustration over not being able to derive the angle of reflection despite understanding the relevant laws. Questions arise regarding the correctness of the index of refraction provided and its implications for the problem.
The conversation reflects a mix of attempts to clarify the problem and explore the implications of the index of refraction on the solution. Some participants suggest that the provided index may be incorrect, while others emphasize the need to adhere to the assignment's parameters. There is no explicit consensus on the correct approach, but several lines of reasoning are being explored.
Participants note that the index of refraction given in the problem may not be accurate, and there is a discussion about the implications of this on the calculations. The original poster indicates that they cannot alter the parameters of the assignment, which adds a layer of complexity to the discussion.
parcerita
I have an assignment to due and it asks for the angle of reflection, but I don't know how to get it. This is the question:
"A beam of light is directed on the flat surface of a block of fused quartz (n=1.92). Part of the beam is refracted with an angle of refraction of 30°. What is the angle of reflection?"
The answer is 46.9°. What's the procedure? Thanks.
Hint: It is assumed that if it doesn't specify what medium the light is coming from then it is air (n=1.00).
Look up Snell's law of refraction and the Law of reflection. You'll need them both.
Doc Al, I know Snell's Law and the law of reflection, but still can figure how to get the angle of reflection. I asked this with knowledge on the topic so your answer didn't help whatsoever.
Snell's law and the law of reflection are all you need to solve this kind of problem. Unless you show what you've done, there's no way to tell what you know and don't know.
That value for the index of refraction of fused quartz is incorrect.
The index of refraction is not meant to be correct, it probably just made up. With Snell's Law I was able to find the angle of incidence, but I don't know what to do next. Also I thought the angle of refraction had to be at least 90° for there to be reflection, that's why I'm stuck.
If you use the correct value, you'll quickly get the stated answer.
Use the law of reflection to find the angle of reflection (this step is trivial). But you won't get the given answer without correcting the index of refraction.
No. Perhaps you are confusing this with total internal reflection.
Yeah, you are right that's total internal reflection. I can't change the index of refraction because it's a question in the assignment. It's kind of like it is what it is because the question was written that way (hope you know what I mean). Anyway thanks for trying to help ;)
If you found the angle of incidence using Snell's law, then you have the angle of reflection (as described above). It just won't agree with the given answer, for the reasons stated.
Just for fun: Look up the index of refraction of fused quartz.
Well ends up that the answer my teacher provided was wrong and that my initial answer of 74° was indeed correct. Again thanks for your help.
That's the correct answer using the information given in the problem.
But if you look up the index of refraction for fused quartz, you'll get something like n = 1.46. Use that corrected value and you'll get an answer of 46.9°. :wink:
  • · Replies 16 ·
11K
