How Do You Calculate the Area Inside a Parametric Loop?
The discussion revolves around finding the area enclosed by a loop formed by the parametric equations x(t) = t³ - 3t and y(t) = t² + t + 1. Participants are exploring how to approach the integration required to calculate this area.
  • Participants discuss the need to integrate using y*dx but express uncertainty about how to determine the limits of integration and how to separate the loop. There are mentions of needing to identify the upper and lower portions of the loop and the corresponding functions for integration.
Some participants have provided insights on how to approach the problem, including suggestions about using functions for the upper and lower parts of the loop. However, there remains confusion regarding which values of t to use and how to set up the integrals correctly. Multiple interpretations of the problem are being explored.
Participants note specific intersection points of the parametric equations and the range of t values that correspond to the loop. There is an ongoing discussion about the implications of these points for setting limits in integration.
Sebobas
Hey Guys!
Find the area of the "loop" (I'm guessing it's called) formed by the set of parametrics:
--> x(t)=t3-3t and y(t)=t2+t+1
I've already drawn the graph and as said before the curve creates a "loop", I have to find the area insed that "loop" and I don't know where to start.
Here is the graph: http://www.wolframalpha.com/input/?i=Parametric+plot+(t^3-3t,t^2+t+1)
I know I probably have to integrate using y*dx..but I don't know where to separate the loop in order to integrate. I have no idea what the limits are.
Thanks in advance!
Sebobas said:
Hey Guys!
I've already drawn the graph and as said before the curve creates a "loop", I have to find the area inside that "loop" and I don't know where to start.
Thanks in advance!
Hello Sebobas. Welcome to PF !
Suppose that you know y as a function of x. In fact there would be one function for the upper portion of the "loop", call it f1(x), and another for the lower portion of the "loop", call it f2(x).
Let xL be the x value at the left-hand extreme of the "loop", and xR be the x value at the left-hand extreme of the "loop".
Then the area that you want is, of course,
[itex]\displaystyle \large {\int_{x_L}^{x_R}}{f_1(x)}\,dx-\large {\int_{x_L}^{x_R}}{f_2(x)}\,dx\ .[/itex]
Also notice that [itex]\displaystyle \int_{x_L}^{x_R}{f_2(x)}\,dx=-\int_{x_R}^{x_L}{f_2(x)}\,dx\ .[/itex]
And of course, as in integration by substitution, [itex]\displaystyle \int f(x)\,dx=\int g(t)\,\frac{dx}{dt}dt\,,[/itex] where g(t)=f(x(t)) .
Sebobas said:
Hey Guys!
Thanks in advance!
That graph looks like the x-y coordinates of the intersection point are ##(-2,3)##. You know ##t## is between -2.497 and 2.497. You can figure out the two values of ##t## by inspection.
Hey Sammy! Thanks, glad to have found the community (:
I get what you mean, I even tried what you said, but I found myself with a problem..
...and that was that when trying to find y in function of x, t gave me 2 different values, which one do I use?
Hey Kurtz.. well you are right the graphs do intersect at (2,3), when t = 1 and t =-2 ...but what do I do then? Separate the curves? in that case what are the upper and lower limits of those new integrals?
Well, you mentioned in your original post about integrating ydx as a line integral. What do you get if you integrate##\int_C -ydx + 0dy## counterclockwise around a loop? Think about Green's theorem. And you can do the line integral as a function of ##t##.
You don't need to use y as a function of x. I was just showing how one might think about the problem.
Basically the g(t) I mentioned in that last step gives y as a function of t: y = f(1 OR 2)(x(t)) = t2 + t + 1 .
dx/dt = 3t2 - 3 .
